5.3.2 NGSolve - PETSc interface
comm = MPI.COMM_WORLD
for l in range(2):
    ngmesh.Refine()
import petsc4py.PETSc as psc
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec);
gfu = c[:]["gfu"]
Draw (gfu[0]);
PETSc preconditioner for NGSolve
a.Assemble();
[stdout:0] CG iteration 1, residual = 0.16041526777634654
CG iteration 2, residual = 0.028306403086995436
CG iteration 3, residual = 0.003947966389044443
CG iteration 4, residual = 0.0006335668128747396
CG iteration 5, residual = 9.657130316829537e-05
CG iteration 6, residual = 1.464430194070165e-05
CG iteration 7, residual = 1.9864979667346706e-06
CG iteration 8, residual = 2.598975368283638e-07
CG iteration 9, residual = 3.765327009288398e-08
CG iteration 10, residual = 5.476981570216701e-09
CG iteration 11, residual = 7.724855037241065e-10
CG iteration 12, residual = 1.2182289607549798e-10
CG iteration 13, residual = 1.6541638237373097e-11
CG iteration 14, residual = 2.2422295418142376e-12
CG iteration 15, residual = 3.0930988805879636e-13
CG iteration 16, residual = 4.4616325920175887e-14
gfu = c[:]["gfu"]
Draw (gfu[0]);
