5.3.2 NGSolve - PETSc interface
comm = MPI.COMM_WORLD
if comm.rank == 0:
    ngmesh = unit_square.GenerateMesh(maxh=0.1).Distribute(comm)
    ngmesh = netgen.meshing.Mesh.Receive(comm)
for l in range(2):
    ngmesh.Refine()
Make sure that the ipyparallel server can import the module, e.g. by starting the cluster in the current directory.
import petsc4py.PETSc as psc
[stderr:2] [d8c32f2f330d:70582] Read -1, expected 18256, errno = 1
[stderr:0] [d8c32f2f330d:70580] Read -1, expected 48352, errno = 1
[stderr:1] [d8c32f2f330d:70581] Read -1, expected 36240, errno = 1
pass
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec)
pass
[stderr:1] [d8c32f2f330d:70581] Read -1, expected 7992, errno = 1
[d8c32f2f330d:70581] Read -1, expected 16864, errno = 1
[d8c32f2f330d:70581] Read -1, expected 31968, errno = 1
[d8c32f2f330d:70581] Read -1, expected 67456, errno = 1
[d8c32f2f330d:70581] Read -1, expected 4800, errno = 1
[d8c32f2f330d:70581] Read -1, expected 4424, errno = 1
[d8c32f2f330d:70581] Read -1, expected 5288, errno = 1
[d8c32f2f330d:70581] Read -1, expected 4752, errno = 1
[stderr:2] [d8c32f2f330d:70582] Read -1, expected 11692, errno = 1
[d8c32f2f330d:70582] Read -1, expected 16364, errno = 1
[d8c32f2f330d:70582] Read -1, expected 46768, errno = 1
[d8c32f2f330d:70582] Read -1, expected 65456, errno = 1
[d8c32f2f330d:70582] Read -1, expected 4480, errno = 1
[d8c32f2f330d:70582] Read -1, expected 8960, errno = 1
[d8c32f2f330d:70582] Read -1, expected 6056, errno = 1
[d8c32f2f330d:70582] Read -1, expected 8464, errno = 1
[stderr:0] [d8c32f2f330d:70580] Read -1, expected 10588, errno = 1
[d8c32f2f330d:70580] Read -1, expected 42352, errno = 1
[stderr:3] [d8c32f2f330d:70583] Read -1, expected 22384, errno = 1
[d8c32f2f330d:70583] Read -1, expected 89536, errno = 1
[d8c32f2f330d:70583] Read -1, expected 8848, errno = 1
gfu = c[:]["gfu"]
Draw (gfu[0])
PETSc preconditioner for NGSolve
pass
inv = CGSolver(a.mat, pre, printing=comm.rank==0)
[stdout:0] WARNING: printing is deprecated, use printrates instead!
CG iteration 1, residual = 0.1618787001637246
CG iteration 2, residual = 0.031964365197057684
CG iteration 3, residual = 0.0038382478132801567
CG iteration 4, residual = 0.0005682457460902592
CG iteration 5, residual = 7.955315146595152e-05
CG iteration 6, residual = 9.69973926871051e-06
CG iteration 7, residual = 1.506979765740051e-06
CG iteration 8, residual = 1.9165943622353623e-07
CG iteration 9, residual = 2.1994160499159513e-08
CG iteration 10, residual = 3.07497795766873e-09
CG iteration 11, residual = 4.036559613950331e-10
CG iteration 12, residual = 5.060126382357107e-11
CG iteration 13, residual = 6.544183941928793e-12
CG iteration 14, residual = 8.105132987384289e-13
CG iteration 15, residual = 1.0541648005905821e-13
gfu = c[:]["gfu"]
Draw (gfu[0])
