c = Client(profile='mpi')
c.ids
[0, 1, 2, 3]
comm = MPI.COMM_WORLD
if comm.rank == 0:
ngmesh = unit_square.GenerateMesh(maxh=0.1).Distribute(comm)
ngmesh = netgen.meshing.Mesh.Receive(comm)
for l in range(2):
ngmesh.Refine()
import petsc4py.PETSc as psc
[stderr:1] [1f72a6a4480f:19600] Read -1, expected 33408, errno = 1
[stderr:0] [1f72a6a4480f:19599] Read -1, expected 48512, errno = 1
[stderr:2] [1f72a6a4480f:19601] Read -1, expected 12576, errno = 1
pass
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec)
pass
[stderr:3] [1f72a6a4480f:19602] Read -1, expected 16964, errno = 1
[1f72a6a4480f:19602] Read -1, expected 67856, errno = 1
[1f72a6a4480f:19602] Read -1, expected 6992, errno = 1
[stderr:0] [1f72a6a4480f:19599] Read -1, expected 12552, errno = 1
[1f72a6a4480f:19599] Read -1, expected 50208, errno = 1
[stderr:2] [1f72a6a4480f:19601] Read -1, expected 8204, errno = 1
[1f72a6a4480f:19601] Read -1, expected 19168, errno = 1
[1f72a6a4480f:19601] Read -1, expected 32816, errno = 1
[1f72a6a4480f:19601] Read -1, expected 76672, errno = 1
[1f72a6a4480f:19601] Read -1, expected 7144, errno = 1
[1f72a6a4480f:19601] Read -1, expected 5720, errno = 1
[1f72a6a4480f:19601] Read -1, expected 8832, errno = 1
[stderr:1] [1f72a6a4480f:19600] Read -1, expected 9540, errno = 1
[1f72a6a4480f:19600] Read -1, expected 16204, errno = 1
[1f72a6a4480f:19600] Read -1, expected 38160, errno = 1
[1f72a6a4480f:19600] Read -1, expected 64816, errno = 1
[1f72a6a4480f:19600] Read -1, expected 5512, errno = 1
[1f72a6a4480f:19600] Read -1, expected 6704, errno = 1
[1f72a6a4480f:19600] Read -1, expected 6512, errno = 1
gfu = c[:]["gfu"]
Draw (gfu[0])
pass
inv = CGSolver(a.mat, pre, printing=comm.rank==0)
[stdout:0] WARNING: printing is deprecated, use printrates instead!
CG iteration 1, residual = 0.16186373090106865
CG iteration 2, residual = 0.032256334634758486
CG iteration 3, residual = 0.0041873433365436944
CG iteration 4, residual = 0.0005968449121709221
CG iteration 5, residual = 8.461918988055599e-05
CG iteration 6, residual = 1.0980502894984023e-05
CG iteration 7, residual = 1.6480728786485835e-06
CG iteration 8, residual = 2.0479915322333332e-07
CG iteration 9, residual = 2.6152153836992176e-08
CG iteration 10, residual = 3.383295610844336e-09
CG iteration 11, residual = 4.183121875015019e-10
CG iteration 12, residual = 5.703654028140915e-11
CG iteration 13, residual = 7.797932580843257e-12
CG iteration 14, residual = 9.331733543242658e-13
CG iteration 15, residual = 1.2343363523858606e-13
gfu = c[:]["gfu"]
Draw (gfu[0])
