5.3.2 NGSolve - PETSc interface
comm = MPI.COMM_WORLD
for l in range(2):
    ngmesh.Refine()
import petsc4py.PETSc as psc
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec);
gfu = c[:]["gfu"]
Draw (gfu[0])
PETSc preconditioner for NGSolve
a.Assemble();
[stdout:0] CG iteration 1, residual = 0.1616451275202026
CG iteration 2, residual = 0.03171900063988575
CG iteration 3, residual = 0.004198128230264013
CG iteration 4, residual = 0.0006197236145500266
CG iteration 5, residual = 8.613269419324215e-05
CG iteration 6, residual = 1.0597037303144394e-05
CG iteration 7, residual = 1.5632460635603687e-06
CG iteration 8, residual = 1.85246537964527e-07
CG iteration 9, residual = 2.4048716217835478e-08
CG iteration 10, residual = 3.636976853595832e-09
CG iteration 11, residual = 5.028734000461942e-10
CG iteration 12, residual = 7.216444620674048e-11
CG iteration 13, residual = 9.633723762360763e-12
CG iteration 14, residual = 1.1338842057010308e-12
CG iteration 15, residual = 1.5325373218078118e-13
gfu = c[:]["gfu"]
Draw (gfu[0]);
