c = Client(profile='mpi')
c.ids
[0, 1, 2, 3]
comm = MPI.COMM_WORLD
if comm.rank == 0:
    ngmesh = unit_square.GenerateMesh(maxh=0.1).Distribute(comm)
    ngmesh = netgen.meshing.Mesh.Receive(comm)
for l in range(2):
    ngmesh.Refine()
import petsc4py.PETSc as psc
pass
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec)
pass
gfu = c[:]["gfu"]
Draw (gfu[0])
pass
inv = CGSolver(a.mat, pre, printing=comm.rank==0)
[stdout:0]
WARNING: printing is deprecated, use printrates instead!
CG iteration 1, residual = 0.16186373090106865
CG iteration 2, residual = 0.03225633463475834
CG iteration 3, residual = 0.00418734333654368
CG iteration 4, residual = 0.0005968449121709168
CG iteration 5, residual = 8.46191898805545e-05
CG iteration 6, residual = 1.0980502894984626e-05
CG iteration 7, residual = 1.6480728786493365e-06
CG iteration 8, residual = 2.0479915322434306e-07
CG iteration 9, residual = 2.615215383748639e-08
CG iteration 10, residual = 3.3832956106055766e-09
CG iteration 11, residual = 4.183121870187323e-10
CG iteration 12, residual = 5.703654006011637e-11
CG iteration 13, residual = 7.79793339014583e-12
CG iteration 14, residual = 9.331741996768944e-13
CG iteration 15, residual = 1.2343443410749943e-13
gfu = c[:]["gfu"]
Draw (gfu[0])
