5.5.2 Discontinuous Galerkin for the Wave Equation
\[b(p,v) = \sum_{T} \Big\{ \int_T \nabla p \, v + \int_{\partial T} (\{ p \} - p) \, v_n \, ds \Big\},\]
  • universal element-matrices for the differntial operator \(B\)
  • cheaply invertible mass matrices (orthogonal polynomials, sum-factorization)
from time import time
sp = Sphere((0.5,0,0), 0.2)
shape = box-sp
geo = OCCGeometry(shape)
h = 0.1
mesh.Curve(3)
Draw(mesh);
order = 4
gfu = GridFunction(fes_u)
gfp = GridFunction(fes_p)
gftr = GridFunction(fes_tr)
ndof_p =  575225 + 520545 , ndof_u = 1725675
p = fes_p.TrialFunction()
v = fes_u.TestFunction()
phat = fes_tr.TrialFunction()
Bel.Assemble()
Btr.Assemble();
gfu.vec[:] = 0
scene = Draw (gftr, draw_vol=False, order=3, min=-0.05, max=0.05);
dt = 0.3 * h / (order+1)**2
tend = 1
op1 = dt * invmassu @ B
op2 = dt * invmassp @ B.T
cnt = 0
        t = t+dt
        gfu.vec.data += op1 * gfp.vec
        gfp.vec.data -= op2 * gfu.vec
        cnt = cnt+1
        if cnt%10 == 0:
Time-stepping on the device
from ngsolve.gpu import *     # cuda, metal, or the host reference device
print ("gpu backend:", backend)
gpu backend: metal
gfu.vec[:] = 0
tend = 0.1
cnt = 0
        t = t+dt
        devu += op1 * devp
        devp -= op2 * devu
        cnt = cnt+1
        if cnt%10 == 0:
            gfp.vec.data = devp
print (op1.GetOperatorInfo())
ProductMatrix, h = 1725675, w = 575225
  ScaleMatrix, scale = 0.001, h = 1725675, w = 1725675
    SumMatrix, h = 1725675, w = 1725675
        DeviceBlockDiagonalMatrixSoA<float>, h = 1725675, w = 1725675
        ProductMatrix, h = 1725675, w = 1725675
          ProductMatrix, h = 1725675, w = 7038
            Transpose, h = 1725675, w = 7038
              DeviceConstantEBEMatrix<float> (blocks=153, 46x35), h = 7038, w = 1725675
            DeviceBlockDiagonalMatrixSoA<float>, h = 7038, w = 7038
        ProductMatrix, h = 1725675, w = 7866
          Transpose, h = 1725675, w = 7866
            DeviceConstantEBEMatrix<float> (blocks=171, 46x35), h = 7866, w = 1725675
          DeviceBlockDiagonalMatrixSoA<float>, h = 7866, w = 7866
  SumMatrix, h = 1725675, w = 575225
      DeviceConstantEBEMatrix<float> (blocks=8228, 105x35), h = 1725675, w = 575225
      DeviceConstantEBEMatrix<float> (blocks=8207, 105x35), h = 1725675, w = 575225
      SumMatrix, h = 1725675, w = 520545
        DeviceConstantEBEMatrix<float> (blocks=8228, 105x60), h = 1725675, w = 520545
        DeviceConstantEBEMatrix<float> (blocks=8207, 105x60), h = 1725675, w = 520545
      ProductMatrix, h = 520545, w = 575225
        DeviceDiagonalMatrix<float>, h = 520545, w = 520545
        SumMatrix, h = 520545, w = 575225
          DeviceConstantEBEMatrix<float> (blocks=8228, 60x35), h = 520545, w = 575225
          DeviceConstantEBEMatrix<float> (blocks=8207, 60x35), h = 520545, w = 575225
ts = time()
steps = 10
for i in range(steps):
    devu += op1 * devp
    devp -= op2 * devu
te = time()
ndof =  575225 + 1725675 , time per step = 0.0011214256286621095
On the A-100:
ndof = 651035 + 1953105 , time per step = 0.0023579835891723634
Time-domain PML
tend = 15
tau = 2e-4
i = 0
sigma = 10   # pml damping parameter
        t += tau
        i += 1
        if i%20 == 0:
          ConstantEBEMatrix (blocks = 497, bs = 20x15), h = 18560, w = 13920
          ConstantEBEMatrix (blocks = 431, bs = 20x15), h = 18560, w = 13920
            ConstantEBEMatrix (blocks = 497, bs = 20x15), h = 18560, w = 7165
            ConstantEBEMatrix (blocks = 431, bs = 20x15), h = 18560, w = 7165
            ConstantEBEMatrix (blocks = 497, bs = 15x15), h = 7165, w = 13920
            ConstantEBEMatrix (blocks = 431, bs = 15x15), h = 7165, w = 13920
