comm = MPI.COMM_WORLD
for l in range(2):
ngmesh.Refine()
import petsc4py.PETSc as psc
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec);
gfu = c[:]["gfu"]
Draw (gfu[0]);
a.Assemble();
[stdout:0] CG iteration 1, residual = 0.16164512752020258
CG iteration 2, residual = 0.03171900063988583
CG iteration 3, residual = 0.004198128230264022
CG iteration 4, residual = 0.0006197236145500274
CG iteration 5, residual = 8.613269419324092e-05
CG iteration 6, residual = 1.0597037303145331e-05
CG iteration 7, residual = 1.5632460635611623e-06
CG iteration 8, residual = 1.8524653796536425e-07
CG iteration 9, residual = 2.4048716219447795e-08
CG iteration 10, residual = 3.636976855594784e-09
CG iteration 11, residual = 5.028734011505638e-10
CG iteration 12, residual = 7.216444743106111e-11
CG iteration 13, residual = 9.63372343481933e-12
CG iteration 14, residual = 1.133884901416395e-12
CG iteration 15, residual = 1.5325341046686516e-13
gfu = c[:]["gfu"]
Draw (gfu[0]);
