5.3.2 NGSolve - PETSc interface
100%
4/4 [00:05<00:00, 5.82s/engine]
comm = MPI.COMM_WORLD
for l in range(2):
    ngmesh.Refine()
Make sure that the ipyparallel server can import the module, e.g. by starting the cluster in the current directory.
import petsc4py.PETSc as psc
[stderr:2] [e278b3a455ef:67171] Read -1, expected 4096, errno = 1
[stderr:1] [e278b3a455ef:67170] Read -1, expected 4096, errno = 1
[stderr:3] [e278b3a455ef:67172] Read -1, expected 4096, errno = 1
[stderr:2] [e278b3a455ef:67171] Read -1, expected 15168, errno = 1
[stderr:0] [e278b3a455ef:67169] Read -1, expected 48832, errno = 1
[stderr:1] [e278b3a455ef:67170] Read -1, expected 35488, errno = 1
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec);
[stderr:2] [e278b3a455ef:67171] Read -1, expected 9904, errno = 1
[e278b3a455ef:67171] Read -1, expected 18176, errno = 1
[e278b3a455ef:67171] Read -1, expected 39616, errno = 1
[e278b3a455ef:67171] Read -1, expected 72704, errno = 1
[e278b3a455ef:67171] Read -1, expected 8072, errno = 1
[e278b3a455ef:67171] Read -1, expected 5904, errno = 1
[e278b3a455ef:67171] Read -1, expected 8416, errno = 1
[stderr:3] [e278b3a455ef:67172] Read -1, expected 19700, errno = 1
[e278b3a455ef:67172] Read -1, expected 78800, errno = 1
[e278b3a455ef:67172] Read -1, expected 4352, errno = 1
[e278b3a455ef:67172] Read -1, expected 7392, errno = 1
[stderr:1] [e278b3a455ef:67170] Read -1, expected 8672, errno = 1
[e278b3a455ef:67170] Read -1, expected 16948, errno = 1
[e278b3a455ef:67170] Read -1, expected 34688, errno = 1
[e278b3a455ef:67170] Read -1, expected 67792, errno = 1
[e278b3a455ef:67170] Read -1, expected 4432, errno = 1
[e278b3a455ef:67170] Read -1, expected 5040, errno = 1
[e278b3a455ef:67170] Read -1, expected 6104, errno = 1
[e278b3a455ef:67170] Read -1, expected 5776, errno = 1
[stderr:0] [e278b3a455ef:67169] Read -1, expected 11384, errno = 1
[e278b3a455ef:67169] Read -1, expected 45536, errno = 1
gfu = c[:]["gfu"]
Draw (gfu[0])
PETSc preconditioner for NGSolve
a.Assemble();
[stdout:0] CG iteration 1, residual = 0.1616451275202024
CG iteration 2, residual = 0.03171900063988554
CG iteration 3, residual = 0.004198128230263991
CG iteration 4, residual = 0.0006197236145500212
CG iteration 5, residual = 8.613269419324584e-05
CG iteration 6, residual = 1.0597037303146737e-05
CG iteration 7, residual = 1.5632460635603687e-06
CG iteration 8, residual = 1.85246537964527e-07
CG iteration 9, residual = 2.4048716218910356e-08
CG iteration 10, residual = 3.6369768538179375e-09
CG iteration 11, residual = 5.028733998453997e-10
CG iteration 12, residual = 7.216444708125522e-11
CG iteration 13, residual = 9.633723762360763e-12
CG iteration 14, residual = 1.133884901416395e-12
CG iteration 15, residual = 1.5325405389402187e-13
gfu = c[:]["gfu"]
Draw (gfu[0]);
