comm = MPI.COMM_WORLD
for l in range(2):
ngmesh.Refine()
import petsc4py.PETSc as psc
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec);
gfu_global = gfu.Gather() # collective: whole solution on rank 0
Draw (c[0]["gfu_global"]);
a.Assemble();
[stdout:0] CG iteration 1, residual = 0.16382612002351396
CG iteration 2, residual = 0.027373937768903456
CG iteration 3, residual = 0.0036601528999104806
CG iteration 4, residual = 0.0005548170017970381
CG iteration 5, residual = 7.667854834945699e-05
CG iteration 6, residual = 9.670196229577511e-06
CG iteration 7, residual = 1.2629673173311087e-06
CG iteration 8, residual = 1.6142762112595095e-07
CG iteration 9, residual = 2.2068877895529492e-08
CG iteration 10, residual = 2.8974855975491523e-09
CG iteration 11, residual = 3.820066653170552e-10
CG iteration 12, residual = 5.5339475573588247e-11
CG iteration 13, residual = 7.366151832710624e-12
CG iteration 14, residual = 9.20742995361898e-13
CG iteration 15, residual = 1.1924248823662496e-13
