comm = MPI.COMM_WORLD
for l in range(2):
    ngmesh.Refine()
import petsc4py.PETSc as psc
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec);
gfu = c[:]["gfu"]
Draw (gfu[0])
a.Assemble();
[stdout:0] CG iteration 1, residual = 0.16164512752020263
CG iteration 2, residual = 0.031719000639885774
CG iteration 3, residual = 0.0041981282302640185
CG iteration 4, residual = 0.0006197236145500284
CG iteration 5, residual = 8.61326941932483e-05
CG iteration 6, residual = 1.0597037303146737e-05
CG iteration 7, residual = 1.5632460635611623e-06
CG iteration 8, residual = 1.8524653796564332e-07
CG iteration 9, residual = 2.4048716218910356e-08
CG iteration 10, residual = 3.636976854484255e-09
CG iteration 11, residual = 5.028734007489749e-10
CG iteration 12, residual = 7.216444760596406e-11
CG iteration 13, residual = 9.633723107277888e-12
CG iteration 14, residual = 1.1338850753451693e-12
CG iteration 15, residual = 1.5325469731847722e-13
gfu = c[:]["gfu"]
Draw (gfu[0]);
