c = Client(profile='mpi')
c.ids
[0, 1, 2, 3]
comm = MPI.COMM_WORLD
if comm.rank == 0:
    ngmesh = unit_square.GenerateMesh(maxh=0.1).Distribute(comm)
    ngmesh = netgen.meshing.Mesh.Receive(comm)
for l in range(2):
    ngmesh.Refine()
import petsc4py.PETSc as psc
pass
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec)
pass
gfu = c[:]["gfu"]
Draw (gfu[0])
pass
inv = CGSolver(a.mat, pre, printing=comm.rank==0)
[stdout:0]
iteration 0 error = 0.16186373090106865
iteration 1 error = 0.03225633463475849
iteration 2 error = 0.004187343336543694
iteration 3 error = 0.0005968449121709242
iteration 4 error = 8.461918988055641e-05
iteration 5 error = 1.0980502894985229e-05
iteration 6 error = 1.6480728786500893e-06
iteration 7 error = 2.0479915322434306e-07
iteration 8 error = 2.6152153836992176e-08
iteration 9 error = 3.383295612038133e-09
iteration 10 error = 4.18312188467041e-10
iteration 11 error = 5.70365407239947e-11
iteration 12 error = 7.797930962237855e-12
iteration 13 error = 9.331737770006758e-13
iteration 14 error = 1.2343363523858606e-13
gfu = c[:]["gfu"]
Draw (gfu[0])
