5.3.2 NGSolve - PETSc interface
c = Client(profile='mpi')
c.ids
[0, 1, 2, 3]
comm = MPI.COMM_WORLD
if comm.rank == 0:
    ngmesh = unit_square.GenerateMesh(maxh=0.1).Distribute(comm)
    ngmesh = netgen.meshing.Mesh.Receive(comm)
for l in range(2):
    ngmesh.Refine()
Make sure that the ipyparallel server can import the module, e.g. by starting the cluster in the current directory.
import petsc4py.PETSc as psc
pass
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec)
pass
gfu = c[:]["gfu"]
Draw (gfu[0])
PETSc preconditioner for NGSolve
pass
inv = CGSolver(a.mat, pre, printing=comm.rank==0)
[stdout:0]
iteration 0 error = 0.16186373090106865
iteration 1 error = 0.03225633463475834
iteration 2 error = 0.00418734333654368
iteration 3 error = 0.0005968449121709168
iteration 4 error = 8.46191898805545e-05
iteration 5 error = 1.0980502894984626e-05
iteration 6 error = 1.6480728786493365e-06
iteration 7 error = 2.0479915322434306e-07
iteration 8 error = 2.615215383748639e-08
iteration 9 error = 3.3832956106055766e-09
iteration 10 error = 4.183121870187323e-10
iteration 11 error = 5.703654006011637e-11
iteration 12 error = 7.79793339014583e-12
iteration 13 error = 9.331741996768944e-13
iteration 14 error = 1.2343443410749943e-13
gfu = c[:]["gfu"]
Draw (gfu[0])
