5.3.2 NGSolve - PETSc interface
comm = MPI.COMM_WORLD
for l in range(2):
    ngmesh.Refine()
Make sure that the ipyparallel server can import the module, e.g. by starting the cluster in the current directory.
import petsc4py.PETSc as psc
[stderr:1] [4860d8c30022:61806] Read -1, expected 33824, errno = 1
[stderr:0] [4860d8c30022:61805] Read -1, expected 48864, errno = 1
[stderr:2] [4860d8c30022:61807] Read -1, expected 17328, errno = 1
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec);
[stderr:0] [4860d8c30022:61805] Read -1, expected 12480, errno = 1
[4860d8c30022:61805] Read -1, expected 49920, errno = 1
[stderr:1] [4860d8c30022:61806] Read -1, expected 9512, errno = 1
[4860d8c30022:61806] Read -1, expected 15980, errno = 1
[4860d8c30022:61806] Read -1, expected 63920, errno = 1
[4860d8c30022:61806] Read -1, expected 38048, errno = 1
[4860d8c30022:61806] Read -1, expected 5200, errno = 1
[4860d8c30022:61806] Read -1, expected 5672, errno = 1
[4860d8c30022:61806] Read -1, expected 5680, errno = 1
[stderr:2] [4860d8c30022:61807] Read -1, expected 11312, errno = 1
[4860d8c30022:61807] Read -1, expected 16740, errno = 1
[4860d8c30022:61807] Read -1, expected 45248, errno = 1
[4860d8c30022:61807] Read -1, expected 66960, errno = 1
[4860d8c30022:61807] Read -1, expected 4392, errno = 1
[4860d8c30022:61807] Read -1, expected 5640, errno = 1
[4860d8c30022:61807] Read -1, expected 8784, errno = 1
[4860d8c30022:61807] Read -1, expected 7664, errno = 1
[stderr:3] [4860d8c30022:61808] Read -1, expected 22316, errno = 1
[4860d8c30022:61808] Read -1, expected 89264, errno = 1
[4860d8c30022:61808] Read -1, expected 8032, errno = 1
gfu = c[:]["gfu"]
Draw (gfu[0])
PETSc preconditioner for NGSolve
a.Assemble();
[stdout:0] CG iteration 1, residual = 0.16127010686172552
CG iteration 2, residual = 0.03143032472771138
CG iteration 3, residual = 0.004236806109474593
CG iteration 4, residual = 0.000673560256142833
CG iteration 5, residual = 9.254951509649891e-05
CG iteration 6, residual = 1.1543042891878278e-05
CG iteration 7, residual = 1.6313785246668694e-06
CG iteration 8, residual = 2.0609628931866596e-07
CG iteration 9, residual = 2.8655513283220788e-08
CG iteration 10, residual = 4.197371013948971e-09
CG iteration 11, residual = 4.94864208996692e-10
CG iteration 12, residual = 6.073045380176665e-11
CG iteration 13, residual = 8.761255707217241e-12
CG iteration 14, residual = 1.1080633610630865e-12
CG iteration 15, residual = 1.4459025695516513e-13
gfu = c[:]["gfu"]
Draw (gfu[0]);
