c = Client(profile='mpi')
c.ids
[0, 1, 2, 3]
comm = MPI.COMM_WORLD
if comm.rank == 0:
ngmesh = unit_square.GenerateMesh(maxh=0.1).Distribute(comm)
ngmesh = netgen.meshing.Mesh.Receive(comm)
for l in range(2):
ngmesh.Refine()
import petsc4py.PETSc as psc
[stderr:2] [28b404a97ea5:13863] Read -1, expected 18256, errno = 1
[stderr:0] [28b404a97ea5:13861] Read -1, expected 48352, errno = 1
[stderr:1] [28b404a97ea5:13862] Read -1, expected 36240, errno = 1
pass
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec)
pass
[stderr:1] [28b404a97ea5:13862] Read -1, expected 7992, errno = 1
[28b404a97ea5:13862] Read -1, expected 16864, errno = 1
[28b404a97ea5:13862] Read -1, expected 31968, errno = 1
[28b404a97ea5:13862] Read -1, expected 67456, errno = 1
[28b404a97ea5:13862] Read -1, expected 4800, errno = 1
[28b404a97ea5:13862] Read -1, expected 4424, errno = 1
[28b404a97ea5:13862] Read -1, expected 5288, errno = 1
[28b404a97ea5:13862] Read -1, expected 4752, errno = 1
[stderr:0] [28b404a97ea5:13861] Read -1, expected 10588, errno = 1
[28b404a97ea5:13861] Read -1, expected 42352, errno = 1
[stderr:2] [28b404a97ea5:13863] Read -1, expected 11692, errno = 1
[28b404a97ea5:13863] Read -1, expected 16364, errno = 1
[28b404a97ea5:13863] Read -1, expected 46768, errno = 1
[28b404a97ea5:13863] Read -1, expected 65456, errno = 1
[28b404a97ea5:13863] Read -1, expected 4480, errno = 1
[28b404a97ea5:13863] Read -1, expected 8960, errno = 1
[28b404a97ea5:13863] Read -1, expected 6056, errno = 1
[28b404a97ea5:13863] Read -1, expected 8464, errno = 1
[stderr:3] [28b404a97ea5:13864] Read -1, expected 22384, errno = 1
[28b404a97ea5:13864] Read -1, expected 89536, errno = 1
[28b404a97ea5:13864] Read -1, expected 8848, errno = 1
gfu = c[:]["gfu"]
Draw (gfu[0])
pass
inv = CGSolver(a.mat, pre, printing=comm.rank==0)
[stdout:0] WARNING: printing is deprecated, use printrates instead!
CG iteration 1, residual = 0.1618787001637246
CG iteration 2, residual = 0.031964365197057684
CG iteration 3, residual = 0.0038382478132801393
CG iteration 4, residual = 0.0005682457460902522
CG iteration 5, residual = 7.955315146595451e-05
CG iteration 6, residual = 9.699739268709486e-06
CG iteration 7, residual = 1.5069797657401885e-06
CG iteration 8, residual = 1.9165943622363737e-07
CG iteration 9, residual = 2.1994160499747156e-08
CG iteration 10, residual = 3.0749779591135743e-09
CG iteration 11, residual = 4.036559619891373e-10
CG iteration 12, residual = 5.060126332469917e-11
CG iteration 13, residual = 6.5441849062792505e-12
CG iteration 14, residual = 8.105131770777225e-13
CG iteration 15, residual = 1.054169477629426e-13
gfu = c[:]["gfu"]
Draw (gfu[0])
