c = Client(profile='mpi')
c.ids
[0, 1, 2, 3]
comm = MPI.COMM_WORLD
if comm.rank == 0:
ngmesh = unit_square.GenerateMesh(maxh=0.1).Distribute(comm)
ngmesh = netgen.meshing.Mesh.Receive(comm)
for l in range(2):
ngmesh.Refine()
[stdout:0]
Boundary mesh done, np = 40
CalcLocalH: 40 Points 0 Elements 0 Surface Elements
Meshing domain 1 / 1
Surface meshing done
Edgeswapping, topological
Smoothing
Split improve
Combine improve
Smoothing
Edgeswapping, metric
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
call metis 5 ...
metis start
metis complete
Send/Receive mesh
Update mesh topology
Sending nr of elements
Building vertex/proc mapping
Sending Vertices - vertices
Sending Vertices - identifications
Sending Vertices - distprocs
Sending elements
Sending Face Descriptors
Sending Surface elements
Sending Edge Segments
Point-Elements ...
now wait ...
Sending names
wait for names
Clean up local memory
send mesh complete
update parallel topology
Refine mesh
Update clusters
Refine mesh
Update clusters
Update clusters
[stdout:1] p1: got 0 elements and 76 surface elements
[stdout:2] p2: got 0 elements and 81 surface elements
[stdout:3] p3: got 0 elements and 75 surface elements
import petsc4py.PETSc as psc
[stdout:0]
assemble VOL element 0/0
assemble BND element 0/0
[stderr:0] [d9d8041d895e:15079] Read -1, expected 48512, errno = 1
[stderr:1] [d9d8041d895e:15080] Read -1, expected 33408, errno = 1
[stderr:2] [d9d8041d895e:15081] Read -1, expected 12576, errno = 1
pass
ksp = psc.KSP()
ksp.create()
ksp.setOperators(psc_mat)
ksp.setType(psc.KSP.Type.CG)
ksp.getPC().setType("gamg")
vecmap.N2P(f.vec, psc_f)
ksp.solve(psc_f, psc_u)
vecmap.P2N(psc_u, gfu.vec)
pass
[stderr:0]
[d9d8041d895e:15079] Read -1, expected 12552, errno = 1
[d9d8041d895e:15079] Read -1, expected 50208, errno = 1
[stderr:1]
[d9d8041d895e:15080] Read -1, expected 9540, errno = 1
[d9d8041d895e:15080] Read -1, expected 16204, errno = 1
[d9d8041d895e:15080] Read -1, expected 64816, errno = 1
[d9d8041d895e:15080] Read -1, expected 38160, errno = 1
[d9d8041d895e:15080] Read -1, expected 5512, errno = 1
[d9d8041d895e:15080] Read -1, expected 6704, errno = 1
[d9d8041d895e:15080] Read -1, expected 6512, errno = 1
[stderr:2]
[d9d8041d895e:15081] Read -1, expected 8204, errno = 1
[d9d8041d895e:15081] Read -1, expected 19168, errno = 1
[d9d8041d895e:15081] Read -1, expected 32816, errno = 1
[d9d8041d895e:15081] Read -1, expected 76672, errno = 1
[d9d8041d895e:15081] Read -1, expected 7144, errno = 1
[d9d8041d895e:15081] Read -1, expected 5720, errno = 1
[d9d8041d895e:15081] Read -1, expected 8832, errno = 1
[stderr:3]
[d9d8041d895e:15082] Read -1, expected 16964, errno = 1
[d9d8041d895e:15082] Read -1, expected 67856, errno = 1
[d9d8041d895e:15082] Read -1, expected 6992, errno = 1
gfu = c[:]["gfu"]
Update clusters
Update clusters
Update clusters
Update clusters
Draw (gfu[0])
pass
[stdout:0]
[stderr:0]
[stderr:1]
[stderr:2]
[stderr:3]
inv = CGSolver(a.mat, pre, printing=comm.rank==0)
[stdout:0]
WARNING: printing is deprecated, use printrates instead!
CG iteration 1, residual = 0.16186373090106865
CG iteration 2, residual = 0.032256334634758486
CG iteration 3, residual = 0.0041873433365436944
CG iteration 4, residual = 0.0005968449121709221
CG iteration 5, residual = 8.461918988055599e-05
CG iteration 6, residual = 1.0980502894984023e-05
CG iteration 7, residual = 1.6480728786485835e-06
CG iteration 8, residual = 2.0479915322333332e-07
CG iteration 9, residual = 2.6152153836992176e-08
CG iteration 10, residual = 3.383295610844336e-09
CG iteration 11, residual = 4.183121875015019e-10
CG iteration 12, residual = 5.703654028140915e-11
CG iteration 13, residual = 7.797932580843257e-12
CG iteration 14, residual = 9.331733543242658e-13
CG iteration 15, residual = 1.2343363523858606e-13
gfu = c[:]["gfu"]
Draw (gfu[0])
Update clusters
Update clusters
Update clusters
Update clusters
