7.7 PDE constrained Topology Optimization
We are again interested in minimizing a shape function of the type :nbsphinx-math:`begin{align*}
mathcal J(Omega) = int_{mathsf{D}} (u-u_d)^2 ; dx
end{align*}` subject to u:DR solves
DβΩuφdx=DfΩφ for all φH01(D),
  • $:nbsphinx-math:beta_:nbsphinx-math:Omega `= :nbsphinx-math:beta`1:nbsphinx-math:`chi`\Omega `+ :nbsphinx-math:beta`2 :nbsphinx-math:`chi`{\mathsf{D}\setminus `:nbsphinx-math:Omega`},:nbsphinx-math:qquad `$ :math:beta_1,beta_2>0`,
  • $f_:nbsphinx-math:Omega `= f_1:nbsphinx-math:chi`:nbsphinx-math:`Omega `+ f_2 :nbsphinx-math:`chi`{\mathsf{D}\setminus `:nbsphinx-math:Omega`}, \qquad `$ :math:`f_1,f_2\in \mathbb{R},
  • ud:DR.
from netgen.geom2d import SplineGeometry  # SplieGeometry to define a 2D mesh
from ngsolve import * # import everything from the ngsolve module
from interpolations import InterpolateLevelSetToElems # function which interpolates a levelset function
myMAXH = 0.05
EPS = myMAXH * 1e-6      #variable defining when a point is on the interface and when not
We begin with defining the domain D. For this we define a rectangular mesh with side lenght R using the NGSolve function SplineGeometry() with maximum triangle size maxh. The boundary name of D is “rectangle”.
R = 2
## add a rectangle
geo.AddRectangle(p1=(-R,-R),
                 p2=(R,R),
                 bc="rectangle",
                 leftdomain=1,
                 rightdomain=0)
geo.SetMaterial (1, "outer") # give the domain the name "outer"
mesh = Mesh(geo.GenerateMesh(maxh=myMAXH)) # generate ngsolve mesh
  • fes_state,fes_adj - H1 conforming finite element space of order 1
  • pwc - L2 subspace of functions constant on each element of mesh
  • u,v are our trial and test functions
  • gfu, gfp are Gridfunctions storing the state and adjoint variable, respectively
  • gfud stores ud - the target function
fes_state = H1(mesh, order=1, dirichlet="rectangle")
fes_adj = H1(mesh, order=1, dirichlet="rectangle")
fes_level = H1(mesh, order=1)
pwc = L2(mesh)   #piecewise constant space
## test and trial functions
u, v = fes_state.TnT()
p, q = fes_adj.TnT()
gfu = GridFunction(fes_state)
gfp = GridFunction(fes_adj)
gfud = GridFunction(fes_state)
We represent the design ΩD by means of a level set function ψ:DR in the following way:
psi(x) < 0 &quad Longleftrightarrowquad x in Omega \ psi(x) = 0 &quad Longleftrightarrowquad x in partial Omega \ psi(x) > 0 &quad Longleftrightarrowquad x in mathsf{D} setminus overline Omega.
end{align*}`
  • psi - gridfunction in fes_state defining ψ
  • <li> psides - gridfunction describing the optimal shape </li>
    <li> psinew - dummy function for line search </li>
    psi = GridFunction(fes_level)
    psi.Set(1)
    psides = GridFunction(fes_level)
    psinew = GridFunction(fes_level)
    scene_psi = Draw(psi, mesh, "psi")
    Next we solve the state equation DβΩuφdx=DfΩφdx for all φH01(D).
    • beta, f_rhs - piecewise constant gridfunction
    • B - bilinear form defining DβΩψφdx
    • B_adj - bilinear form defining DβΩψφdx
    • L - right hand side DfΩφdx
    # constants for f_rhs and beta
    f1 = 10
    f2 = 1
    beta1 = 10
    beta2 = 1
    # piecewise constant coefficient functions beta and f_rhs
    beta = GridFunction(pwc)
    beta.Set(beta1)
    f_rhs = GridFunction(pwc)
    f_rhs.Set(f1)
    #Draw(beta, mesh, "beta")
    #Draw(f_rhs, mesh, "f_rhs")
    # bilinear form for state equation
    B = BilinearForm(fes_state)
    B += beta*grad(u) * grad(v) * dx
    B_adj = BilinearForm(fes_adj)
    B_adj += beta*grad(p) * grad(q) * dx
    L = LinearForm(fes_state)
    L += f_rhs * v *dx
    duCost = LinearForm(fes_adj)
    # solving
    psides.Set(1)
    InterpolateLevelSetToElems(psides, beta1, beta2, beta, mesh, EPS)
    InterpolateLevelSetToElems(psides, f1, f2, f_rhs, mesh, EPS)
    B.Assemble()
    L.Assemble()
    inv = B.mat.Inverse(fes_state.FreeDofs(), inverse="sparsecholesky") # inverse of bilinear form
    gfu.vec.data = inv*L.vec
    scene_u = Draw(gfu)
    As an optimal shape we define Ωopt:={f<0}, where f is the function from the levelset example describing a clover shape. We construct ud by solving DβΩoptudφdx=DfΩoptφdx for all φH01(D).
    a = 4.0/5.0
    b = 2
                    * (sqrt(b * x**2 + (y + a)**2) - 1) - 0.001) )
    psides.Set(f)
    B.Assemble()
    L.Assemble()
    gfud.vec.data = inv*L.vec
    Draw(gfud, mesh, 'gfud')
    The function SolvePDE solves the state and adjoint state each time it is called. Note that since the functions beta and f_rhs are GridFunctions we do not have to redefine the bilinearform and linearform when beta and f_rhs change.
    def SolvePDE(adjoint=False):
        #Newton(a, gfu, printing = False, maxerr = 3e-9)
        B.Assemble()
        L.Assemble()
        inv_state = B.mat.Inverse(fes_state.FreeDofs(), inverse="sparsecholesky")
        # solve state equation
        gfu.vec.data = inv_state*L.vec
        if adjoint == True:
            # solve adjoint state equatoin
            duCost.Assemble()
            B_adj.Assemble()
            inv_adj = B_adj.mat.Inverse(fes_adj.FreeDofs(), inverse="sparsecholesky")
            gfp.vec.data = -inv_adj * duCost.vec
        scene_u.Redraw()
    InterpolateLevelSetToElems(psi, beta1, beta2, beta, mesh, EPS)
    InterpolateLevelSetToElems(psi, f1, f2, f_rhs, mesh, EPS)
    SolvePDE()
    # define the cost function
    def Cost(u):
        return (u - gfud)**2*dx
    # derivative of cost function
    duCost += 2*(gfu-gfud) * q * dx
    print("initial cost = ", Integrate(Cost(gfu), mesh))
    initial cost =  39.29514987635362
    It remains to implement the topological derivative: In define NegPos and PosNeg as the topological derivative in Ω respectively Ωc: :nbsphinx-math:`begin{align*}
    mathsf{NegPos}(x) := -DJ(Omega,omega)(x) &= (-1) * left( 2 beta_2 left(frac{beta_2-beta_1}{beta_1+beta_2}right)nabla u(x)cdot nabla p(x) - (f_2-f_1)p(x) right) \ &= 2 beta_2 left(frac{beta_1-beta_2}{beta_1+beta_2}right)nabla u(x)cdot nabla p(x) - (f_1-f_2)p(x) quad text{ for }xin Omega \ mathsf{PosNeg}(x) := DJ(Omega,omega)(x) &= 2 beta_1 left(frac{beta_1-beta_2}{beta_1+beta_2}right)nabla u(x)cdot nabla p(x) - (f_1-f_2)p(x) quad text{ for }xin Omega^c
    end{align*}` and the update function (also called generalised topological derivative) gΩ(x):=χΩ(x)DJ(Ω,ω)(x)+(1χΩ)DJ(Ω,ω)(x).
    BetaPosNeg = 2 * beta2 * (beta1-beta2)/(beta1+beta2)    # factors in TD in positive part {x: \psi(x)>0} ={x: \beta(x) = \beta_2}
    BetaNegPos = 2 * beta1 * (beta1-beta2)/(beta1+beta2)    # factors in TD in positive part {x: \psi(x)>0} ={x: \beta(x) = \beta_2}
    FPosNeg = -(f1-f2)
    psinew.vec.data = psi.vec
    ## normalise psi in L2
    normPsi = sqrt(Integrate(psi**2*dx, mesh))
    psi.vec.data = 1/normPsi * psi.vec
    kappa = 0.05
    # set level set function to data
    TD_node = GridFunction(fes_level)
    #scene1 = Draw(TD_node, mesh, "TD_node")
    TD_pwc = GridFunction(pwc)
    #scene2 = Draw(TD_pwc, mesh, "TD_pwc")
    #Draw(TDPosNeg_pwc, mesh, "TDPosNeg_pwc")
    #Draw(TDNegPos_pwc, mesh, "TDNegPos_pwc")
    cutRatio = GridFunction(pwc)
    #scene3 = Draw(cutRatio, mesh, "cutRatio")
    # solve for current configuration
    SolvePDE(adjoint=True)
    Finally we can define a loop defining the levelset update: :nbsphinx-math:`begin{align*}
    psi_{k+1} = (1-s_k) frac{psi_k}{|\psi_k|} + s_k frac{g_{psi_k}}{|g_{\psi_k}|}
    end{align*}`
    scene = Draw(psi)
    scene_cr = Draw(cutRatio, mesh, "cutRatio")
    scene_TD0 = Draw(TD_pwc, mesh, "TD_pwc")
    scene_TD1 = Draw(TD_node, mesh, "TD_node")
    # iter_max = 1000
    iter_max = 20
    converged = False
    xm=0.
    ym=0.
    psi.Set( (x-xm)**2+(y-ym)**2-0.25**2)
    psinew.vec.data= psi.vec
    # input("press enter to start optimization")
    J = Integrate(Cost(gfu),mesh)
        for k in range(iter_max):
            # copy new levelset data from psinew into psi
            psi.vec.data = psinew.vec
            J_current = Integrate(Cost(gfu),mesh)
            print( Integrate( (gfu-gfud)**2*dx, mesh) )
            # compute the piecewise constant topological derivative in each domain
            TDPosNeg_pwc.Set( BetaPosNeg * grad(gfu) * grad(gfp)  + FPosNeg*gfp )
            TDNegPos_pwc.Set( BetaNegPos * grad(gfu) * grad(gfp)  + FPosNeg*gfp )
            # compute the cut ratio of the interface elements
            InterpolateLevelSetToElems(psi, 1, 0, cutRatio, mesh, EPS)
                TD_pwc.vec[j] = cutRatio.vec[j] * TDNegPos_pwc.vec[j] + (1-cutRatio.vec[j])*TDPosNeg_pwc.vec[j]
            TD_node.Set(TD_pwc)
            scene_cr.Redraw()
            scene_TD0.Redraw()
            scene_TD1.Redraw()
            normTD = sqrt(Integrate(TD_node**2*dx, mesh)) # L2 norm of TD_node
            TD_node.vec.data = 1/normTD * TD_node.vec # normalised TD_node
            normPsi = sqrt(Integrate(psi**2*dx, mesh)) # L2 norm of psi
            psi.vec.data = 1/normPsi * psi.vec  # normalised psi
            linesearch = True
            for j in range(10):
                psinew.vec.data = (1-kappa)*psi.vec + kappa*TD_node.vec
                # update beta and f_rhs
                InterpolateLevelSetToElems(psinew, beta1, beta2, beta, mesh, EPS)
                InterpolateLevelSetToElems(psinew, f1, f2, f_rhs, mesh, EPS)
                # solve PDE without adjoint
                SolvePDE()
                if Jnew > J_current:
                    print("--------------------")
                    print("-----line search ---")
                    kappa = kappa*0.8
                    print("kappa", kappa)
                    break
            print("----------- Jnew in  iteration ", k, " = ", Jnew, " (kappa = ", kappa, ")")
            print('')
            print("iter" + str(k) + ", Jnew = " + str(Jnew) + " (kappa = ", kappa, ")")
            kappa = min(1, kappa*1.2)
    # input("Finished")
    ================ iteration  0 ===================
    39.29514987635357
    cost in beginning of iteration 0 : Cost =  39.29514987635357
    ----------- Jnew in  iteration  0  =  11.85901940018507  (kappa =  0.05 )
    iter0, Jnew = 11.85901940018507 (kappa =  0.05 )
    end of iter 0
    ================ iteration  1 ===================
    11.859019400184742
    cost in beginning of iteration 1 : Cost =  11.859019400184742
    ----------- Jnew in  iteration  1  =  6.368291440712806  (kappa =  0.06 )
    iter1, Jnew = 6.368291440712806 (kappa =  0.06 )
    end of iter 1
    ================ iteration  2 ===================
    6.368291440712683
    cost in beginning of iteration 2 : Cost =  6.368291440712683
    ----------- Jnew in  iteration  2  =  6.213775684310629  (kappa =  0.072 )
    iter2, Jnew = 6.213775684310629 (kappa =  0.072 )
    end of iter 2
    ================ iteration  3 ===================
    6.213775684310509
    cost in beginning of iteration 3 : Cost =  6.213775684310509
    kappa 0.06912
    kappa 0.055296000000000005
    kappa 0.04423680000000001
    kappa 0.03538944000000001
    kappa 0.028311552000000007
    kappa 0.02264924160000001
    kappa 0.018119393280000007
    kappa 0.014495514624000005
    ----------- Jnew in  iteration  3  =  5.649581482991682  (kappa =  0.014495514624000005 )
    iter3, Jnew = 5.649581482991682 (kappa =  0.014495514624000005 )
    end of iter 3
    ================ iteration  4 ===================
    5.649581482991694
    cost in beginning of iteration 4 : Cost =  5.649581482991693
    kappa 0.013915694039040007
    ----------- Jnew in  iteration  4  =  5.528568652187315  (kappa =  0.013915694039040007 )
    iter4, Jnew = 5.528568652187315 (kappa =  0.013915694039040007 )
    end of iter 4
    ================ iteration  5 ===================
    5.528568652187283
    cost in beginning of iteration 5 : Cost =  5.528568652187283
    kappa 0.013359066277478408
    kappa 0.010687253021982727
    kappa 0.008549802417586181
    kappa 0.006839841934068946
    ----------- Jnew in  iteration  5  =  5.4769140865234425  (kappa =  0.006839841934068946 )
    iter5, Jnew = 5.4769140865234425 (kappa =  0.006839841934068946 )
    end of iter 5
    ================ iteration  6 ===================
    5.476914086523388
    cost in beginning of iteration 6 : Cost =  5.476914086523387
    kappa 0.006566248256706188
    ----------- Jnew in  iteration  6  =  5.077667333405579  (kappa =  0.006566248256706188 )
    iter6, Jnew = 5.077667333405579 (kappa =  0.006566248256706188 )
    end of iter 6
    ================ iteration  7 ===================
    5.077667333405358
    cost in beginning of iteration 7 : Cost =  5.077667333405358
    kappa 0.00630359832643794
    kappa 0.005042878661150352
    kappa 0.004034302928920282
    ----------- Jnew in  iteration  7  =  5.023551026006033  (kappa =  0.004034302928920282 )
    iter7, Jnew = 5.023551026006033 (kappa =  0.004034302928920282 )
    end of iter 7
    ================ iteration  8 ===================
    5.0235510260060305
    cost in beginning of iteration 8 : Cost =  5.0235510260060305
    kappa 0.003872930811763471
    ----------- Jnew in  iteration  8  =  4.677691174783886  (kappa =  0.003872930811763471 )
    iter8, Jnew = 4.677691174783886 (kappa =  0.003872930811763471 )
    end of iter 8
    ================ iteration  9 ===================
    4.677691174783982
    cost in beginning of iteration 9 : Cost =  4.677691174783982
    kappa 0.003718013579292932
    kappa 0.0029744108634343455
    kappa 0.0023795286907474767
    kappa 0.0019036229525979814
    ----------- Jnew in  iteration  9  =  4.575993905142038  (kappa =  0.0019036229525979814 )
    iter9, Jnew = 4.575993905142038 (kappa =  0.0019036229525979814 )
    end of iter 9
    ================ iteration  10 ===================
    4.575993905142015
    cost in beginning of iteration 10 : Cost =  4.575993905142015
    ----------- Jnew in  iteration  10  =  4.310627608694736  (kappa =  0.0022843475431175778 )
    iter10, Jnew = 4.310627608694736 (kappa =  0.0022843475431175778 )
    end of iter 10
    ================ iteration  11 ===================
    4.310627608694717
    cost in beginning of iteration 11 : Cost =  4.310627608694717
    kappa 0.002192973641392875
    kappa 0.0017543789131143001
    kappa 0.00140350313049144
    ----------- Jnew in  iteration  11  =  4.272470133009127  (kappa =  0.00140350313049144 )
    iter11, Jnew = 4.272470133009127 (kappa =  0.00140350313049144 )
    end of iter 11
    ================ iteration  12 ===================
    4.272470133009114
    cost in beginning of iteration 12 : Cost =  4.272470133009114
    ----------- Jnew in  iteration  12  =  4.130540514506373  (kappa =  0.0016842037565897282 )
    iter12, Jnew = 4.130540514506373 (kappa =  0.0016842037565897282 )
    end of iter 12
    ================ iteration  13 ===================
    4.1305405145064125
    cost in beginning of iteration 13 : Cost =  4.1305405145064125
    kappa 0.001616835606326139
    kappa 0.0012934684850609115
    ----------- Jnew in  iteration  13  =  4.105073090155797  (kappa =  0.0012934684850609115 )
    iter13, Jnew = 4.105073090155797 (kappa =  0.0012934684850609115 )
    end of iter 13
    ================ iteration  14 ===================
    4.105073090155789
    cost in beginning of iteration 14 : Cost =  4.105073090155789
    ----------- Jnew in  iteration  14  =  4.005444714834245  (kappa =  0.0015521621820730937 )
    iter14, Jnew = 4.005444714834245 (kappa =  0.0015521621820730937 )
    end of iter 14
    ================ iteration  15 ===================
    4.005444714834296
    cost in beginning of iteration 15 : Cost =  4.0054447148342955
    ----------- Jnew in  iteration  15  =  3.984226572448126  (kappa =  0.0018625946184877124 )
    iter15, Jnew = 3.984226572448126 (kappa =  0.0018625946184877124 )
    end of iter 15
    ================ iteration  16 ===================
    3.984226572448154
    cost in beginning of iteration 16 : Cost =  3.984226572448154
    ----------- Jnew in  iteration  16  =  3.893357673028718  (kappa =  0.002235113542185255 )
    iter16, Jnew = 3.893357673028718 (kappa =  0.002235113542185255 )
    end of iter 16
    ================ iteration  17 ===================
    3.893357673028768
    cost in beginning of iteration 17 : Cost =  3.8933576730287682
    kappa 0.002145709000497845
    kappa 0.0017165672003982759
    ----------- Jnew in  iteration  17  =  3.8635185562084837  (kappa =  0.0017165672003982759 )
    iter17, Jnew = 3.8635185562084837 (kappa =  0.0017165672003982759 )
    end of iter 17
    ================ iteration  18 ===================
    3.8635185562084833
    cost in beginning of iteration 18 : Cost =  3.8635185562084833
    ----------- Jnew in  iteration  18  =  3.7706492565666916  (kappa =  0.002059880640477931 )
    iter18, Jnew = 3.7706492565666916 (kappa =  0.002059880640477931 )
    end of iter 18
    ================ iteration  19 ===================
    3.770649256566732
    cost in beginning of iteration 19 : Cost =  3.770649256566732
    kappa 0.001977485414858814
    ----------- Jnew in  iteration  19  =  3.760465670775931  (kappa =  0.001977485414858814 )
    iter19, Jnew = 3.760465670775931 (kappa =  0.001977485414858814 )
    end of iter 19
    # After 999 iterations: $J = $
    # <center>
    #    <img src="psi_iter999.jpg" width="800" aligh="center"/>
    # </center>
