7.5 PDE-Constrained Shape Optimization in NGSolve
We want to solve the PDE-constrained shape optimization problem :nbsphinx-math:`begin{equation}
underset{Omegasubset mathsf{D}}{mbox{min}} ; J(u) := int_Omega |u-u_d|^q ; dx, quad qge 2
end{equation}` subject to that \((\Omega,u)\) satisfy :nbsphinx-math:`begin{equation}
int_Omega nabla u cdot nabla v ; dx = int_Omega f v ; dx ; quad text{ for all } v in H_0^1(Omega),
end{equation}` where \(\Omega \subset \mathbb R^2\) for given \(u_d, f \in C^1(\mathbb R^2)\).
from ngsolve.solvers import *
ud = x*(1-x)*y*(1-y)
gfp = GridFunction(fes)
Automatic Shape Differentiation
The formula for the shape derivative was derived as the partial derivative of the perturbed Lagrangian (brought back to the original domain): :nbsphinx-math:`begin{align*}
dmathcal J(Omega; X) = frac{partial}{partial t} left( int_Omega |u - u_d^t|^q ,mbox{det}(F_t) mbox{d} x
  • int_{Omega} (F_t^{-top}nabla u) cdot (F_t^{-top} nabla p), mbox{det}(F_t) , dx - int_{Omega}f^t p ,mbox{det}(F_t) ,dx right)|_{t=0}
end{align*}` where
  • \(T_t(x)=x+tX(x)=y\)
  • \(F_t = DT_t = I+t DX\)
  • \(u_d^t = u_d \circ T_t\)
  • \(f^t = f \circ T_t\)
The integrand depends on the parameter \(t\) only via \(F_t\) and \(T_t\). We define the Lagrangian in this form, involving a parameter t that has the value 0.
In order to define the perturbed Lagrangian for a given problem, one needs to know transformation rules of differential operators, e.g.,
\[(\nabla u)\circ T_t = (\partial T_t)^{-T} \nabla (u \circ T_t)\]
for \(u \in H^1\).
Since these transformation rules are known by NGSolve for all implemented differential operators, also the step of defining the perturbed Lagrangian can be automated.
PHI, X = VEC.TnT()
def EquationFA(u,v):
    return ( grad(u)*grad(v)-f*v)*dx
q=6
def CostAutoFA(u):
    return (u-ud)**q*dx
def CostAuto2(u):
    return CostAutoFA(u)
LagrangianFA = CostAutoFA(gfu) + EquationFA(gfu,gfp)
State equation
Equation can also be used to define the bilinear form. The following defines left and right hand side of the PDE in a “BilinearForm”:
u, v = fes.TnT()
aAuto += EquationFA(u,v)
gfu.vec[:]=0
scene_u.Redraw()
Newton iteration  0
err =  0.130424398895105
Newton iteration  1
err =  1.222588750362193e-16
Adjoint equation
We set up the adjoint equation :nbsphinx-math:`begin{align*}
mbox{Find } p in H_0^1(Omega): int_Omega nabla w cdot nabla p , mbox dx = - partial_u J(u)(w) quad text{ for all } w in H_0^1(Omega)
end{align*}` where \(u\) is the solution to the state equation. For \(J(u) = \int_\Omega |u-u_d|^2 \mbox dx\), we get :nbsphinx-math:`begin{align*}
partial_u J(u)(w) = 2 int_Omega (u-u_d)w ,mbox dx.
end{align*}` However, we can also use the Diff(…) command:
p, w = fes.TnT()
fadjoint = LinearForm(fes)
fadjoint += -1*(CostAutoFA(gfu)).Diff(gfu,w)
def SolveAdjointEquation():
    rhs = gfp.vec.CreateVector()
    gfp.vec.data += update
fadjoint.Assemble()
scene_p.Redraw()
Denoting the integrand by \(G^{u,p}\), the shape derivative is given by :nbsphinx-math:`begin{align*}
dmathcal J(Omega; X) =& left( left. frac{partial G^{u,p}}{partial t} + frac{d G^{u,p}}{dy} cdot frac{d T_t}{dt}right)rightrvert_{t=0} \ =& left. frac{partial G^{u,p}}{partial t}rightrvert_{t=0} + frac{d G^{u,p}}{dy} cdot X
end{align*}`
dJOmegaAuto = LinearForm(VEC)
dJOmegaAuto += LagrangianFA.DiffShape(X)
b = BilinearForm(VEC)
gfX = GridFunction(VEC)
gfset = GridFunction(VEC)
gfset.Set((0,0))
Draw(gfset,mesh,"gfset")
    rhs = gfX.vec.CreateVector()
    gfX.vec.data += update
b.Assemble()
dJOmegaAuto.Assemble()
Draw(-gfX, mesh, "-gfX")
gfset.Set((0,0))
scale = 0.5 / Norm(gfX.vec)
Cost at initial design 6.143043263036927e-13
scene_u = Draw(gfu)
mesh.SetDeformation(gfset)
scene_u.Redraw()
#a.Assemble()
#fstate.Assemble()
#SolveStateEquation()
gfu.vec[:]=0
Newton iteration  0
err =  0.1536966000887244
Newton iteration  1
err =  1.457722603663598e-16
Cost at new design 5.1527237573490425e-14
scene_u = Draw(gfu)
gfset.Set((0,0))
scene_u.Redraw()
gfu.vec[:]=0
LineSearch = False
iter_max = 600
converged = False
for k in range(iter_max):
    scene_u.Redraw()
    gfu.vec[:]=0
    fadjoint.Assemble()
    b.Assemble()
    scale = 0.01 / Norm(gfX.vec)
    gfsetOld = gfset
    if LineSearch:
            # input('a')
            scale = scale / 2
            if scale <= 1e-12:
                converged = True
                break
            gfu.vec[:]=0
    if converged==True:
        break
    Jold = Jnew
Newton iteration  0
Newton iteration  1
cost at iteration 0 :  6.143043263036927e-13
cost at iteration 1 :  5.748857816381753e-13
cost at iteration 2 :  5.207266929791141e-13
cost at iteration 3 :  4.712188154427544e-13
cost at iteration 4 :  4.2601246194071067e-13
cost at iteration 5 :  3.847789933608326e-13
cost at iteration 6 :  3.4721001943872263e-13
cost at iteration 7 :  3.13016599099225e-13
cost at iteration 8 :  2.81928441933407e-13
cost at iteration 9 :  2.536931124686017e-13
cost at iteration 10 :  2.2807523888028106e-13
cost at iteration 11 :  2.0485572778556018e-13
cost at iteration 12 :  1.8383098674975284e-13
cost at iteration 13 :  1.648121561301935e-13
cost at iteration 14 :  1.4762435187561976e-13
cost at iteration 15 :  1.3210592089413214e-13
cost at iteration 16 :  1.1810771059603216e-13
cost at iteration 17 :  1.0549235420542276e-13
cost at iteration 18 :  9.413357340867057e-14
cost at iteration 19 :  8.391549985589432e-14
cost at iteration 20 :  7.473201693329001e-14
cost at iteration 21 :  6.648612304797901e-14
cost at iteration 22 :  5.908931736586109e-14
cost at iteration 23 :  5.246100844624003e-14
cost at iteration 24 :  4.65279454213834e-14
cost at iteration 25 :  4.122367012501331e-14
cost at iteration 26 :  3.648798666831419e-14
cost at iteration 27 :  3.226644210142681e-14
cost at iteration 28 :  2.850980759602267e-14
cost at iteration 29 :  2.517354358177014e-14
cost at iteration 30 :  2.2217224058404318e-14
cost at iteration 31 :  1.9603884944725066e-14
cost at iteration 32 :  1.7299250559312112e-14
cost at iteration 33 :  1.5270787906707026e-14
cost at iteration 34 :  1.3486560674109262e-14
cost at iteration 35 :  1.1913957307461336e-14
cost at iteration 36 :  1.0518670615441477e-14
cost at iteration 37 :  9.264990111449492e-15
cost at iteration 38 :  8.119397374676163e-15
cost at iteration 39 :  7.058740039030549e-15
cost at iteration 40 :  6.07801559132372e-15
cost at iteration 41 :  5.186529047294115e-15
cost at iteration 42 :  4.393749538492723e-15
cost at iteration 43 :  3.700929658095945e-15
cost at iteration 44 :  3.1023563402231286e-15
cost at iteration 45 :  2.589079180211726e-15
cost at iteration 46 :  2.1513675813708033e-15
cost at iteration 47 :  1.779837877234147e-15
cost at iteration 48 :  1.4658675080290138e-15
cost at iteration 49 :  1.2016999622066879e-15
cost at iteration 50 :  9.804305149659413e-16
cost at iteration 51 :  7.959510644047553e-16
cost at iteration 52 :  6.428837951229063e-16
cost at iteration 53 :  5.165141949142227e-16
cost at iteration 54 :  4.127269086294047e-16
cost at iteration 55 :  3.2794544893469153e-16
cost at iteration 56 :  2.5907602581981555e-16
cost at iteration 57 :  2.0345544352874154e-16
cost at iteration 58 :  1.5880302621372565e-16
cost at iteration 59 :  1.231763262291855e-16
cost at iteration 60 :  9.493065692145712e-17
cost at iteration 61 :  7.268188463759144e-17
cost at iteration 62 :  5.527310547565252e-17
cost at iteration 63 :  4.174334002822213e-17
cost at iteration 64 :  3.1302324411124516e-17
cost at iteration 65 :  2.3305298972294725e-17
cost at iteration 66 :  1.72822443772741e-17
cost at iteration 67 :  1.3196858138632126e-17
cost at iteration 68 :  1.1355789271611047e-17
cost at iteration 69 :  1.0066473898769335e-17
cost at iteration 70 :  8.778326167709423e-18
cost at iteration 71 :  7.743734182275104e-18
cost at iteration 72 :  6.791416833991138e-18
cost at iteration 73 :  5.98064439533481e-18
cost at iteration 74 :  5.259435783484501e-18
cost at iteration 75 :  4.629785878056088e-18
cost at iteration 76 :  4.077989039555047e-18
cost at iteration 77 :  3.590413612087848e-18
cost at iteration 78 :  3.1660167282029176e-18
cost at iteration 79 :  2.788609415184e-18
cost at iteration 80 :  2.4611724048686307e-18
cost at iteration 81 :  2.168875444242977e-18
cost at iteration 82 :  1.9157066715251983e-18
cost at iteration 83 :  1.689122440047969e-18
cost at iteration 84 :  1.493064100761492e-18
cost at iteration 85 :  1.31724653628271e-18
cost at iteration 86 :  1.1652212891710215e-18
cost at iteration 87 :  1.0286628643477308e-18
cost at iteration 88 :  9.106531869343668e-19
cost at iteration 89 :  8.044866483943211e-19
cost at iteration 90 :  7.127920582705766e-19
cost at iteration 91 :  6.301754690022127e-19
cost at iteration 92 :  5.5886128902803645e-19
cost at iteration 93 :  4.945079490598607e-19
cost at iteration 94 :  4.389913960495953e-19
cost at iteration 95 :  3.888110591589572e-19
cost at iteration 96 :  3.4554799802780274e-19
cost at iteration 97 :  3.063727134415224e-19
cost at iteration 98 :  2.7261921896593103e-19
cost at iteration 99 :  2.4199335968382093e-19
cost at iteration 100 :  2.1562339073629171e-19
cost at iteration 101 :  1.9164241686433218e-19
cost at iteration 102 :  1.7100787622932475e-19
cost at iteration 103 :  1.5219419612134518e-19
cost at iteration 104 :  1.360171873068078e-19
cost at iteration 105 :  1.2122434499087446e-19
cost at iteration 106 :  1.085139997027876e-19
cost at iteration 107 :  9.685255766458341e-20
cost at iteration 108 :  8.684068571063554e-20
cost at iteration 109 :  7.762077234544569e-20
cost at iteration 110 :  6.971197678438353e-20
cost at iteration 111 :  6.239866947786396e-20
cost at iteration 112 :  5.613161024432231e-20
cost at iteration 113 :  5.031023271056938e-20
cost at iteration 114 :  4.53275068338356e-20
cost at iteration 115 :  4.0676608273371255e-20
cost at iteration 116 :  3.670131042643263e-20
cost at iteration 117 :  3.2971617774921484e-20
cost at iteration 118 :  2.9789097602778064e-20
cost at iteration 119 :  2.6787129193239516e-20
cost at iteration 120 :  2.4230805007222813e-20
cost at iteration 121 :  2.180613341777564e-20
cost at iteration 122 :  1.9746480660805864e-20
cost at iteration 123 :  1.778185747883102e-20
cost at iteration 124 :  1.6117885054882568e-20
cost at iteration 125 :  1.4521609657071135e-20
cost at iteration 126 :  1.3174284235072751e-20
cost at iteration 127 :  1.1874327637645612e-20
cost at iteration 128 :  1.0781518473843053e-20
cost at iteration 129 :  9.72101340376204e-21
cost at iteration 130 :  8.833617947409941e-21
cost at iteration 131 :  7.967405782055852e-21
cost at iteration 132 :  7.246386373819717e-21
cost at iteration 133 :  6.538376130640068e-21
cost at iteration 134 :  5.9524953052135205e-21
cost at iteration 135 :  5.373643245668884e-21
cost at iteration 136 :  4.897732758442935e-21
cost at iteration 137 :  4.424495943429634e-21
cost at iteration 138 :  4.038134603866887e-21
cost at iteration 139 :  3.6512892107753946e-21
cost at iteration 140 :  3.3377973960899874e-21
cost at iteration 141 :  3.0215424773413133e-21
cost at iteration 142 :  2.7672256408379607e-21
cost at iteration 143 :  2.5085134287210442e-21
cost at iteration 144 :  2.3021012257643353e-21
cost at iteration 145 :  2.0901446461526138e-21
cost at iteration 146 :  1.922377129364015e-21
cost at iteration 147 :  1.7482865046543367e-21
cost at iteration 148 :  1.6115999301661322e-21
cost at iteration 149 :  1.4681018107005334e-21
cost at iteration 150 :  1.356372240450159e-21
cost at iteration 151 :  1.2375717182291792e-21
cost at iteration 152 :  1.1458882419460091e-21
cost at iteration 153 :  1.0470522002649413e-21
cost at iteration 154 :  9.715083161163535e-22
cost at iteration 155 :  8.888635129110536e-22
cost at iteration 156 :  8.263672522159456e-22
cost at iteration 157 :  7.569168485302811e-22
cost at iteration 158 :  7.050243857534842e-22
cost at iteration 159 :  6.463883869978555e-22
cost at iteration 160 :  6.031643821401037e-22
cost at iteration 161 :  5.534468209800247e-22
cost at iteration 162 :  5.173514574944012e-22
cost at iteration 163 :  4.750337005392762e-22
cost at iteration 164 :  4.448337800958686e-22
cost at iteration 165 :  4.0869098037190863e-22
cost at iteration 166 :  3.8339120367766167e-22
cost at iteration 167 :  3.5242795327355773e-22
cost at iteration 168 :  3.31218379632165e-22
cost at iteration 169 :  3.046196521172557e-22
cost at iteration 170 :  2.868357833103557e-22
cost at iteration 171 :  2.639298168159634e-22
cost at iteration 172 :  2.4902237147417138e-22
cost at iteration 173 :  2.292528875876724e-22
cost at iteration 174 :  2.167648444215627e-22
cost at iteration 175 :  1.996707205682884e-22
cost at iteration 176 :  1.892194597586684e-22
cost at iteration 177 :  1.7442043947141511e-22
cost at iteration 178 :  1.6568267002689166e-22
cost at iteration 179 :  1.5286888223743162e-22
cost at iteration 180 :  1.4556524797364635e-22
cost at iteration 181 :  1.344827747456885e-22
cost at iteration 182 :  1.2835993189952305e-22
cost at iteration 183 :  1.1877650178678024e-22
cost at iteration 184 :  1.136041864910115e-22
cost at iteration 185 :  1.0526910560197973e-22
cost at iteration 186 :  1.0088870638044954e-22
cost at iteration 187 :  9.354531311500241e-23
cost at iteration 188 :  8.991162080760111e-23
cost at iteration 189 :  8.334152400660958e-23
cost at iteration 190 :  8.054715522170631e-23
cost at iteration 191 :  7.472193628787711e-23
cost at iteration 192 :  7.33399661513434e-23
cost at iteration 193 :  6.871811176732208e-23
cost at iteration 194 :  6.719536599682814e-23
cost at iteration 195 :  6.286800565869466e-23
cost at iteration 196 :  6.146682677901722e-23
cost at iteration 197 :  5.747718259934753e-23
cost at iteration 198 :  5.635556630025704e-23
cost at iteration 199 :  5.263622706506236e-23
cost at iteration 200 :  5.1758915581176933e-23
cost at iteration 201 :  4.827848547611668e-23
cost at iteration 202 :  4.7631077561987754e-23
cost at iteration 203 :  4.437808508889321e-23
cost at iteration 204 :  4.3952432890186505e-23
cost at iteration 205 :  4.09153120163626e-23
cost at iteration 206 :  4.069958103225097e-23
cost at iteration 207 :  3.786007960195095e-23
cost at iteration 208 :  3.7838868776953186e-23
cost at iteration 209 :  3.517307495000091e-23
cost at iteration 210 :  3.533112105374632e-23
cost at iteration 211 :  3.2811488777543653e-23
cost at iteration 212 :  3.313817828376935e-23
cost at iteration 213 :  3.073447888573042e-23
cost at iteration 214 :  3.1230090786402085e-23
cost at iteration 215 :  2.89104615929986e-23
cost at iteration 216 :  2.960025591014402e-23
cost at iteration 217 :  2.734490742348623e-23
cost at iteration 218 :  2.833713140485501e-23
cost at iteration 219 :  2.6350752476106918e-23
cost at iteration 220 :  2.789285192441431e-23
cost at iteration 221 :  2.5990534151680644e-23
cost at iteration 222 :  2.6308198506414694e-23
cost at iteration 223 :  2.461449372602541e-23
cost at iteration 224 :  2.4991276121721625e-23
cost at iteration 225 :  2.3444565325346604e-23
cost at iteration 226 :  2.3937298141333052e-23
cost at iteration 227 :  2.2481088890063503e-23
cost at iteration 228 :  2.3045281752087138e-23
cost at iteration 229 :  2.164331523766919e-23
cost at iteration 230 :  2.2245621415051165e-23
cost at iteration 231 :  2.088466026768691e-23
cost at iteration 232 :  2.1504639514420584e-23
cost at iteration 233 :  2.0186372359565213e-23
cost at iteration 234 :  2.0808785588505124e-23
cost at iteration 235 :  1.9545026952678367e-23
cost at iteration 236 :  2.015097795225338e-23
cost at iteration 237 :  1.8968523685200284e-23
cost at iteration 238 :  1.9525541931197382e-23
cost at iteration 239 :  1.8490911036434476e-23
cost at iteration 240 :  1.894109593391037e-23
cost at iteration 241 :  1.827296281111438e-23
cost at iteration 242 :  1.858930822510816e-23
cost at iteration 243 :  1.919760723874906e-23
cost at iteration 244 :  1.8136414979317902e-23
cost at iteration 245 :  1.8751151222832754e-23
cost at iteration 246 :  1.7050233582447102e-23
cost at iteration 247 :  1.7680889470981916e-23
cost at iteration 248 :  1.6355787060892243e-23
cost at iteration 249 :  1.7095704438915475e-23
cost at iteration 250 :  1.5900857272887435e-23
cost at iteration 251 :  1.6736593907511725e-23
cost at iteration 252 :  1.5547763294133663e-23
cost at iteration 253 :  1.652681806978694e-23
cost at iteration 254 :  1.5330131765783864e-23
cost at iteration 255 :  1.6731989473552768e-23
cost at iteration 256 :  1.5972812425082444e-23
cost at iteration 257 :  1.6527249153222646e-23
cost at iteration 258 :  1.5563955346612166e-23
cost at iteration 259 :  1.558428714586768e-23
cost at iteration 260 :  1.4754179414854664e-23
cost at iteration 261 :  1.4995388835879963e-23
cost at iteration 262 :  1.431428445876863e-23
cost at iteration 263 :  1.4664444133537097e-23
cost at iteration 264 :  1.4039586986182403e-23
cost at iteration 265 :  1.4418617767958174e-23
cost at iteration 266 :  1.3834341242413355e-23
cost at iteration 267 :  1.4185299851320687e-23
cost at iteration 268 :  1.369803999919254e-23
cost at iteration 269 :  1.395806347681476e-23
cost at iteration 270 :  1.3834494166179567e-23
cost at iteration 271 :  1.4080853439847992e-23
cost at iteration 272 :  1.533468380305438e-23
cost at iteration 273 :  1.364237118682098e-23
cost at iteration 274 :  1.4836154078441823e-23
cost at iteration 275 :  1.2748817387000872e-23
cost at iteration 276 :  1.4129571750615693e-23
cost at iteration 277 :  1.228966906623356e-23
cost at iteration 278 :  1.381924658010431e-23
cost at iteration 279 :  1.2048709393230007e-23
cost at iteration 280 :  1.3700727220279432e-23
cost at iteration 281 :  1.1912080370820256e-23
cost at iteration 282 :  1.3811828693297547e-23
cost at iteration 283 :  1.2185233533782706e-23
cost at iteration 284 :  1.4655835038264668e-23
cost at iteration 285 :  1.2546671300471876e-23
cost at iteration 286 :  1.3725379566920644e-23
cost at iteration 287 :  1.1686301430496147e-23
cost at iteration 288 :  1.3182985155411466e-23
cost at iteration 289 :  1.124600974362297e-23
cost at iteration 290 :  1.2927735672392293e-23
cost at iteration 291 :  1.1063236792508457e-23
cost at iteration 292 :  1.2765094987561596e-23
cost at iteration 293 :  1.1001535728574338e-23
cost at iteration 294 :  1.2626398158259362e-23
cost at iteration 295 :  1.1220557069547118e-23
cost at iteration 296 :  1.3081658592864096e-23
cost at iteration 297 :  1.2705823627431391e-23
cost at iteration 298 :  1.1992374498235226e-23
cost at iteration 299 :  1.2336318735854467e-23
cost at iteration 300 :  1.1302297071812453e-23
cost at iteration 301 :  1.1757072876508286e-23
cost at iteration 302 :  1.0976127380572297e-23
cost at iteration 303 :  1.1548876776704768e-23
cost at iteration 304 :  1.0818380012857708e-23
cost at iteration 305 :  1.1545038825449993e-23
cost at iteration 306 :  1.0814091813433137e-23
cost at iteration 307 :  1.2043313445533839e-23
cost at iteration 308 :  1.1755105759615726e-23
cost at iteration 309 :  1.1838106611667001e-23
cost at iteration 310 :  1.1370172858239098e-23
cost at iteration 311 :  1.1089418143152126e-23
cost at iteration 312 :  1.0839974041203125e-23
cost at iteration 313 :  1.0715805811168719e-23
cost at iteration 314 :  1.0608320563704231e-23
cost at iteration 315 :  1.0571443413570244e-23
cost at iteration 316 :  1.0507816506692442e-23
cost at iteration 317 :  1.0488357694851024e-23
cost at iteration 318 :  1.0478610941271677e-23
cost at iteration 319 :  1.0411079679244304e-23
cost at iteration 320 :  1.0661031190699301e-23
cost at iteration 321 :  1.0608268070109789e-23
cost at iteration 322 :  1.2320194927389646e-23
cost at iteration 323 :  1.0426122436960466e-23
cost at iteration 324 :  1.1900000364838567e-23
cost at iteration 325 :  9.699222108648063e-24
cost at iteration 326 :  1.130992156307019e-23
cost at iteration 327 :  9.344253425515957e-24
cost at iteration 328 :  1.1105180060618669e-23
cost at iteration 329 :  9.205164082341697e-24
cost at iteration 330 :  1.1095110989148187e-23
cost at iteration 331 :  9.180973157035362e-24
cost at iteration 332 :  1.1424479075322671e-23
cost at iteration 333 :  9.885691937612605e-24
cost at iteration 334 :  1.1634777152018802e-23
cost at iteration 335 :  9.950481004005563e-24
cost at iteration 336 :  1.0959407650487472e-23
cost at iteration 337 :  9.226328012166028e-24
cost at iteration 338 :  1.0621122495925968e-23
cost at iteration 339 :  8.950832126752342e-24
cost at iteration 340 :  1.0490556162518647e-23
cost at iteration 341 :  8.879812439804032e-24
cost at iteration 342 :  1.041243268158099e-23
cost at iteration 343 :  8.992169608651323e-24
cost at iteration 344 :  1.058813492967352e-23
cost at iteration 345 :  1.0388809165576952e-23
cost at iteration 346 :  1.0195648486457628e-23
cost at iteration 347 :  1.044233792309561e-23
cost at iteration 348 :  9.587305646123462e-24
cost at iteration 349 :  9.724135284856826e-24
cost at iteration 350 :  9.289837758272417e-24
cost at iteration 351 :  9.479438748829515e-24
cost at iteration 352 :  9.170319706885913e-24
cost at iteration 353 :  9.47940883426226e-24
cost at iteration 354 :  9.195719460131072e-24
cost at iteration 355 :  9.94696512708742e-24
cost at iteration 356 :  1.0168874286261588e-23
cost at iteration 357 :  9.872208612158425e-24
cost at iteration 358 :  9.763652128124642e-24
cost at iteration 359 :  9.246197528971745e-24
cost at iteration 360 :  9.300894425796456e-24
cost at iteration 361 :  8.925967970936984e-24
cost at iteration 362 :  9.115920916489717e-24
cost at iteration 363 :  8.826432540740751e-24
cost at iteration 364 :  9.054065091413304e-24
cost at iteration 365 :  8.784815398025179e-24
cost at iteration 366 :  9.074119663430341e-24
cost at iteration 367 :  8.765132779283247e-24
cost at iteration 368 :  9.468079998289842e-24
cost at iteration 369 :  9.411853995257358e-24
cost at iteration 370 :  1.0438250547588311e-23
cost at iteration 371 :  8.996688038507313e-24
cost at iteration 372 :  9.87675609522342e-24
cost at iteration 373 :  8.402611624541576e-24
cost at iteration 374 :  9.49171880750888e-24
cost at iteration 375 :  8.157594445679029e-24
cost at iteration 376 :  9.395507073306988e-24
cost at iteration 377 :  8.073998825643107e-24
cost at iteration 378 :  9.477783902940982e-24
cost at iteration 379 :  8.17637436103806e-24
cost at iteration 380 :  1.0321369834185773e-23
cost at iteration 381 :  9.094713350105178e-24
cost at iteration 382 :  9.576602466627321e-24
cost at iteration 383 :  8.710038043006528e-24
cost at iteration 384 :  8.94671029932912e-24
cost at iteration 385 :  8.339897317847012e-24
cost at iteration 386 :  8.696780065313006e-24
cost at iteration 387 :  8.207975973251314e-24
cost at iteration 388 :  8.615149252531704e-24
cost at iteration 389 :  8.186211209327398e-24
cost at iteration 390 :  8.57382154761561e-24
cost at iteration 391 :  8.308519599397792e-24
cost at iteration 392 :  8.707783284836577e-24
cost at iteration 393 :  9.697520183467645e-24
cost at iteration 394 :  8.754615138303406e-24
cost at iteration 395 :  9.563732405472016e-24
cost at iteration 396 :  8.245948981884099e-24
cost at iteration 397 :  8.896775642012508e-24
cost at iteration 398 :  7.947817342777951e-24
cost at iteration 399 :  8.661503495499424e-24
cost at iteration 400 :  7.839081948997608e-24
cost at iteration 401 :  8.659592650252547e-24
cost at iteration 402 :  7.856112319347425e-24
cost at iteration 403 :  9.052831278821721e-24
cost at iteration 404 :  8.7709203310408e-24
cost at iteration 405 :  9.059518833973101e-24
cost at iteration 406 :  8.543952271394245e-24
cost at iteration 407 :  8.541437750534177e-24
cost at iteration 408 :  8.039657638173388e-24
cost at iteration 409 :  8.24400522190838e-24
cost at iteration 410 :  7.840399272915725e-24
cost at iteration 411 :  8.15223619868942e-24
cost at iteration 412 :  7.78980734307797e-24
cost at iteration 413 :  8.119434150981692e-24
cost at iteration 414 :  7.862944704484667e-24
cost at iteration 415 :  8.183547609227221e-24
cost at iteration 416 :  8.81050442432435e-24
cost at iteration 417 :  8.775222705228908e-24
cost at iteration 418 :  8.843075022274089e-24
cost at iteration 419 :  8.32774920412755e-24
cost at iteration 420 :  8.065446371790083e-24
cost at iteration 421 :  8.031771631835693e-24
cost at iteration 422 :  7.789784838911284e-24
cost at iteration 423 :  7.920436212560968e-24
cost at iteration 424 :  7.76607708905961e-24
cost at iteration 425 :  7.924607011322316e-24
cost at iteration 426 :  8.047752238864897e-24
cost at iteration 427 :  8.74317871903395e-24
cost at iteration 428 :  8.470899366139896e-24
cost at iteration 429 :  8.289720761250976e-24
cost at iteration 430 :  8.117776129455132e-24
cost at iteration 431 :  7.763565869135495e-24
cost at iteration 432 :  7.80365107656777e-24
cost at iteration 433 :  7.558733705263951e-24
cost at iteration 434 :  7.70609949930639e-24
cost at iteration 435 :  7.507078345369229e-24
cost at iteration 436 :  7.677664490752486e-24
cost at iteration 437 :  7.5696416785238e-24
cost at iteration 438 :  7.735544600700762e-24
cost at iteration 439 :  8.38260579835612e-24
cost at iteration 440 :  8.484171199611204e-24
cost at iteration 441 :  8.416252578161591e-24
cost at iteration 442 :  8.06543256175529e-24
cost at iteration 443 :  7.667494146974083e-24
cost at iteration 444 :  7.770533463506147e-24
cost at iteration 445 :  7.392268210894948e-24
cost at iteration 446 :  7.660155835326306e-24
cost at iteration 447 :  7.363343310719616e-24
cost at iteration 448 :  7.65857133952176e-24
cost at iteration 449 :  7.600153301578769e-24
cost at iteration 450 :  8.37284699837529e-24
cost at iteration 451 :  8.20193246067791e-24
cost at iteration 452 :  7.917361394066627e-24
cost at iteration 453 :  7.90394796934436e-24
cost at iteration 454 :  7.374203967359206e-24
cost at iteration 455 :  7.590034398513458e-24
cost at iteration 456 :  7.163067011039795e-24
cost at iteration 457 :  7.489963706567357e-24
cost at iteration 458 :  7.111860051246238e-24
cost at iteration 459 :  7.462413668932924e-24
cost at iteration 460 :  7.175480647524717e-24
cost at iteration 461 :  7.534615211916604e-24
cost at iteration 462 :  7.998814145909685e-24
cost at iteration 463 :  8.226660613181749e-24
cost at iteration 464 :  8.026237229710833e-24
cost at iteration 465 :  7.814786216133713e-24
cost at iteration 466 :  7.290490311838225e-24
cost at iteration 467 :  7.54464128081183e-24
cost at iteration 468 :  7.031677161292374e-24
cost at iteration 469 :  7.44609003284711e-24
cost at iteration 470 :  7.009464550943401e-24
cost at iteration 471 :  7.454157778837631e-24
cost at iteration 472 :  7.259367802445755e-24
cost at iteration 473 :  8.229886142581509e-24
cost at iteration 474 :  7.773878278044859e-24
cost at iteration 475 :  7.681513305129126e-24
cost at iteration 476 :  7.488338693385467e-24
cost at iteration 477 :  7.183440886186396e-24
cost at iteration 478 :  7.193526113231876e-24
cost at iteration 479 :  6.99070987661567e-24
cost at iteration 480 :  7.103837404784728e-24
cost at iteration 481 :  6.943227026679433e-24
cost at iteration 482 :  7.08316393315342e-24
cost at iteration 483 :  7.002670907208143e-24
cost at iteration 484 :  7.155513661413945e-24
cost at iteration 485 :  7.786389944251324e-24
cost at iteration 486 :  7.890248943912081e-24
cost at iteration 487 :  7.761863478151082e-24
cost at iteration 488 :  7.516490010919306e-24
cost at iteration 489 :  7.058278714276075e-24
cost at iteration 490 :  7.251947278628901e-24
cost at iteration 491 :  6.804646332698792e-24
cost at iteration 492 :  7.155072545850986e-24
cost at iteration 493 :  6.779469159881205e-24
cost at iteration 494 :  7.158030649085356e-24
cost at iteration 495 :  6.999151349101209e-24
cost at iteration 496 :  7.829100652425297e-24
cost at iteration 497 :  7.635839238344117e-24
cost at iteration 498 :  7.348999075754837e-24
cost at iteration 499 :  7.370881033764991e-24
cost at iteration 500 :  6.83332243402463e-24
cost at iteration 501 :  7.080022228698599e-24
cost at iteration 502 :  6.633229189790198e-24
cost at iteration 503 :  6.988350893701573e-24
cost at iteration 504 :  6.585357673576664e-24
cost at iteration 505 :  6.967082697983321e-24
cost at iteration 506 :  6.644555801915313e-24
cost at iteration 507 :  7.048891189194566e-24
cost at iteration 508 :  7.41745319767718e-24
cost at iteration 509 :  7.740031428394355e-24
cost at iteration 510 :  7.423371165248382e-24
cost at iteration 511 :  7.360866994841696e-24
cost at iteration 512 :  6.72654933385857e-24
cost at iteration 513 :  7.116811663040283e-24
cost at iteration 514 :  6.486321820342825e-24
cost at iteration 515 :  7.029091258535585e-24
cost at iteration 516 :  6.4666828634583676e-24
cost at iteration 517 :  7.039094598664822e-24
cost at iteration 518 :  6.694308702234632e-24
cost at iteration 519 :  7.761454264158733e-24
cost at iteration 520 :  7.26112673317566e-24
cost at iteration 521 :  7.171700954373969e-24
cost at iteration 522 :  7.017328899946139e-24
cost at iteration 523 :  6.698684533177913e-24
cost at iteration 524 :  6.741955327213352e-24
cost at iteration 525 :  6.5150782226049656e-24
cost at iteration 526 :  6.658589820593e-24
cost at iteration 527 :  6.469145812949752e-24
cost at iteration 528 :  6.642483992801412e-24
cost at iteration 529 :  6.519408381005057e-24
cost at iteration 530 :  6.713238838358345e-24
cost at iteration 531 :  7.189576619774997e-24
cost at iteration 532 :  7.523459472584288e-24
cost at iteration 533 :  7.18799995772506e-24
cost at iteration 534 :  7.163810358432677e-24
cost at iteration 535 :  6.524223512525237e-24
cost at iteration 536 :  6.914424060863568e-24
cost at iteration 537 :  6.28225466450757e-24
cost at iteration 538 :  6.822895213806963e-24
cost at iteration 539 :  6.255956454894619e-24
cost at iteration 540 :  6.821946897433012e-24
cost at iteration 541 :  6.438223540742367e-24
cost at iteration 542 :  7.381051993409796e-24
cost at iteration 543 :  7.205520703422803e-24
cost at iteration 544 :  6.879286394033604e-24
cost at iteration 545 :  6.989028543088948e-24
cost at iteration 546 :  6.3809483812666205e-24
cost at iteration 547 :  6.705187596453636e-24
cost at iteration 548 :  6.185392577428707e-24
cost at iteration 549 :  6.612806635764415e-24
cost at iteration 550 :  6.1374834933631034e-24
cost at iteration 551 :  6.5923728299630065e-24
cost at iteration 552 :  6.183228555755803e-24
cost at iteration 553 :  6.659644877037476e-24
cost at iteration 554 :  6.770535861501112e-24
cost at iteration 555 :  7.527866781724305e-24
cost at iteration 556 :  6.85479734929614e-24
cost at iteration 557 :  7.123492972325938e-24
cost at iteration 558 :  6.206967184285438e-24
cost at iteration 559 :  6.880387030412153e-24
cost at iteration 560 :  5.9734468865368776e-24
cost at iteration 561 :  6.791881881670932e-24
cost at iteration 562 :  5.949984187279958e-24
cost at iteration 563 :  6.791506229549144e-24
cost at iteration 564 :  6.123627732593171e-24
cost at iteration 565 :  7.35055593661749e-24
cost at iteration 566 :  6.895509620354917e-24
cost at iteration 567 :  6.727201865805719e-24
cost at iteration 568 :  6.722379695059383e-24
cost at iteration 569 :  6.2602249102769326e-24
cost at iteration 570 :  6.443968496509101e-24
cost at iteration 571 :  6.076261455560479e-24
cost at iteration 572 :  6.3539360783000584e-24
cost at iteration 573 :  6.028665432907771e-24
cost at iteration 574 :  6.335400416912817e-24
cost at iteration 575 :  6.0626693540471286e-24
cost at iteration 576 :  6.385526690836258e-24
cost at iteration 577 :  6.504924631799361e-24
cost at iteration 578 :  7.328620476620162e-24
cost at iteration 579 :  6.711047105568578e-24
cost at iteration 580 :  6.870657782858458e-24
cost at iteration 581 :  6.168566949172352e-24
cost at iteration 582 :  6.59255848738473e-24
cost at iteration 583 :  5.920275421412819e-24
cost at iteration 584 :  6.486571344294865e-24
cost at iteration 585 :  5.88195753601375e-24
cost at iteration 586 :  6.467976143290364e-24
cost at iteration 587 :  6.00777367205596e-24
cost at iteration 588 :  6.798113028479153e-24
cost at iteration 589 :  6.920361963340735e-24
cost at iteration 590 :  6.51498440942666e-24
cost at iteration 591 :  6.712646834042274e-24
cost at iteration 592 :  6.065092580866669e-24
cost at iteration 593 :  6.3818515316493294e-24
cost at iteration 594 :  5.862813674978562e-24
cost at iteration 595 :  6.26368979871307e-24
cost at iteration 596 :  5.8077427646365116e-24
cost at iteration 597 :  6.23445070937352e-24
cost at iteration 598 :  5.8300596727468536e-24
cost at iteration 599 :  6.263391140704472e-24
