7.7 PDE-Constrained Topology OptimizationΒΆ
We are again interested in minimizing a shape function of the type
\[\mathcal J(\Omega) = \int_{\mathsf{D}} (u-u_d)^2 \; dx\]
subject to \(u:\mathsf{D} \to \mathbb{R}\) solves
\[\int_{\mathsf{D}} \beta_\Omega\nabla u\cdot \nabla \varphi\;dx = \int_{\mathsf{D}} f_\Omega\varphi \quad \text{ for all } \varphi \in H^1_0(\mathsf{D}),\]
  • \(\beta_\Omega = \beta_1\chi_\Omega + \beta_2 \chi_{\mathsf{D}\setminus \Omega}\), \(\qquad \beta_1,\beta_2>0\),
  • \(f_\Omega = f_1\chi_\Omega + f_2 \chi_{\mathsf{D}\setminus \Omega}\), \(\qquad f_1,f_2\in \mathbb{R}\),
  • \(u_d:\mathsf{D} \to \mathbb{R}\).
from netgen.geom2d import SplineGeometry  # SplieGeometry to define a 2D mesh
from ngsolve import * # import everything from the ngsolve module
from interpolations import InterpolateLevelSetToElems # function which interpolates a levelset function
myMAXH = 0.05
EPS = myMAXH * 1e-6      #variable defining when a point is on the interface and when not
The file interpolations.py can contains a routine to compute the volume ratio of each element with respect to a given level set function. The file can be downloaded from interpolations.py .
We begin with defining the domain \(\mathsf{D}\). For this we define a rectangular mesh with side length \(R\) using the NGSolve function SplineGeometry() with maximum triangle size maxh. The boundary name of \(\partial\mathsf{D}\) is "rectangle".
R = 2
## add a rectangle
geo.AddRectangle(p1=(-R,-R),
                 p2=(R,R),
                 bc="rectangle",
                 leftdomain=1,
                 rightdomain=0)
geo.SetMaterial (1, "outer") # give the domain the name "outer"
mesh = Mesh(geo.GenerateMesh(maxh=myMAXH)) # generate ngsolve mesh
  • fes_state,fes_adj - \(H^1\) conforming finite element space of order 1
  • pwc - \(L^2\) subspace of functions constant on each element of mesh
  • \(u,v\) are our trial and test functions
  • gfu, gfp are Gridfunctions storing the state and adjoint variable, respectively
  • gfud stores \(u_d\) - the target function
fes_state = H1(mesh, order=1, dirichlet="rectangle")
fes_adj = H1(mesh, order=1, dirichlet="rectangle")
fes_level = H1(mesh, order=1)
pwc = L2(mesh)   #piecewise constant space
## test and trial functions
u, v = fes_state.TnT()
p, q = fes_adj.TnT()
gfu = GridFunction(fes_state)
gfp = GridFunction(fes_adj)
gfud = GridFunction(fes_state)
\[\begin{split}\begin{array}{rl} \psi(x) < 0 &\quad \Longleftrightarrow\quad x \in \Omega \\ \psi(x) = 0 &\quad \Longleftrightarrow\quad x \in \partial \Omega \\ \psi(x) > 0 &\quad \Longleftrightarrow\quad x \in \mathsf{D} \setminus \overline \Omega. \end{array}\end{split}\]
  • psi - gridfunction in fes_state defining \(\psi\)
  • psides - gridfunction describing the optimal shape
  • psinew - dummy function for line search
psi = GridFunction(fes_level)
psi.Set(1)
psides = GridFunction(fes_level)
psinew = GridFunction(fes_level)
Next we solve the state equation \begin{equation} \int_{\mathsf{D}} \beta_\Omega \nabla u \cdot \nabla \varphi \;dx = \int_{\mathsf{D}} f_\Omega\varphi \;dx \quad \text{ for all } \varphi \in H^1_0(\mathsf{D}). \end{equation}
  • beta, f_rhs - piecewise constant gridfunction
  • B - bilinear form defining \(\int_{\mathsf{D}} \beta_\Omega\nabla \psi \cdot \nabla \varphi \;dx\)
  • B_adj - bilinear form defining \(\int_{\mathsf{D}} \beta_\Omega\nabla \psi \cdot \nabla \varphi \;dx\)
  • L - right hand side \(\int_{\mathsf{D}} f_\Omega \varphi \;dx\)
# constants for f_rhs and beta
f1 = 10
f2 = 1
beta1 = 10
beta2 = 1
# piecewise constant coefficient functions beta and f_rhs
beta = GridFunction(pwc)
beta.Set(beta1)
f_rhs = GridFunction(pwc)
f_rhs.Set(f1)
# bilinear form for state equation
B = BilinearForm(fes_state)
B += beta*grad(u) * grad(v) * dx
B_adj = BilinearForm(fes_adj)
B_adj += beta*grad(p) * grad(q) * dx
L = LinearForm(fes_state)
L += f_rhs * v *dx
duCost = LinearForm(fes_adj)
# solving
psides.Set(1)
InterpolateLevelSetToElems(psides, beta1, beta2, beta, mesh, EPS)
InterpolateLevelSetToElems(psides, f1, f2, f_rhs, mesh, EPS)
B.Assemble()
L.Assemble()
inv = B.mat.Inverse(fes_state.FreeDofs(), inverse="sparsecholesky") # inverse of bilinear form
gfu.vec.data = inv*L.vec
scene_u = Draw(gfu)
As an optimal shape we define \(\Omega_{opt} := \{f<0\}\), where \(f\) is the function from the levelset example describing a clover shape. We construct \(u_d\) by solving
\[\int_{\mathsf{D}} \beta_{\Omega_{opt}} \nabla u_d \cdot \nabla \varphi \;dx = \int_{\mathsf{D}} f_{\Omega_{opt}}\varphi \;dx \quad \text{ for all } \varphi \in H^1_0(\mathsf{D}).\]
a = 4.0/5.0
b = 2
                * (sqrt(b * x**2 + (y + a)**2) - 1) - 0.001) )
psides.Set(f)
B.Assemble()
L.Assemble()
gfud.vec.data = inv*L.vec
Draw(gfud, mesh, 'gfud')
The function SolvePDE solves the state and adjoint state each time it is called. Note that since the functions beta and f_rhs are GridFunctions we do not have to re-define the bilinear form and linear form when beta and f_rhs change.
def SolvePDE(adjoint=False):
    #Newton(a, gfu, printing = False, maxerr = 3e-9)
    B.Assemble()
    L.Assemble()
    inv_state = B.mat.Inverse(fes_state.FreeDofs(), inverse="sparsecholesky")
    # solve state equation
    gfu.vec.data = inv_state*L.vec
    if adjoint == True:
        # solve adjoint state equatoin
        duCost.Assemble()
        B_adj.Assemble()
        inv_adj = B_adj.mat.Inverse(fes_adj.FreeDofs(), inverse="sparsecholesky")
        gfp.vec.data = -inv_adj * duCost.vec
    scene_u.Redraw()
InterpolateLevelSetToElems(psi, beta1, beta2, beta, mesh, EPS)
InterpolateLevelSetToElems(psi, f1, f2, f_rhs, mesh, EPS)
SolvePDE()
# define the cost function
def Cost(u):
    return (u - gfud)**2*dx
# derivative of cost function
duCost += 2*(gfu-gfud) * q * dx
print("initial cost = ", Integrate(Cost(gfu), mesh))
initial cost =  39.29567644494834
It remains to implement the topological derivative: In define \(NegPos\) and \(PosNeg\) as the topological derivative in \(\Omega\) respectively \(D \setminus \overline{\Omega}\):
\[\begin{split}\begin{array}{rl} \mathsf{NegPos}(x) := -DJ(\Omega,\omega)(x) &= (-1) * \left( 2 \beta_2 \left(\frac{\beta_2-\beta_1}{\beta_1+\beta_2}\right)\nabla u(x)\cdot \nabla p(x) - (f_2-f_1)p(x) \right) \\ &= 2 \beta_2 \left(\frac{\beta_1-\beta_2}{\beta_1+\beta_2}\right)\nabla u(x)\cdot \nabla p(x) - (f_1-f_2)p(x) \quad \text{ for }x\in \Omega \\ \mathsf{PosNeg}(x) := DJ(\Omega,\omega)(x) &= 2 \beta_1 \left(\frac{\beta_1-\beta_2}{\beta_1+\beta_2}\right)\nabla u(x)\cdot \nabla p(x) - (f_1-f_2)p(x) \quad \text{ for }x\in D \setminus \overline{\Omega} \end{array}\end{split}\]
and the update function (also called generalised topological derivative)
\[g_\Omega(x):= -\chi_\Omega (x)DJ(\Omega,\omega)(x) + (1-\chi_\Omega)*DJ(\Omega,\omega)(x) .\]
BetaPosNeg = 2 * beta2 * (beta1-beta2)/(beta1+beta2)    # factors in TD in positive part {x: \psi(x)>0} ={x: \beta(x) = \beta_2}
BetaNegPos = 2 * beta1 * (beta1-beta2)/(beta1+beta2)    # factors in TD in positive part {x: \psi(x)>0} ={x: \beta(x) = \beta_2}
FPosNeg = -(f1-f2)
psinew.vec.data = psi.vec
## normalise psi in L2
normPsi = sqrt(Integrate(psi**2*dx, mesh))
psi.vec.data = 1/normPsi * psi.vec
kappa = 0.05
# set level set function to data
TD_node = GridFunction(fes_level)
#scene1 = Draw(TD_node, mesh, "TD_node")
TD_pwc = GridFunction(pwc)
#scene2 = Draw(TD_pwc, mesh, "TD_pwc")
cutRatio = GridFunction(pwc)
# solve for current configuration
SolvePDE(adjoint=True)
Finally we can define a loop defining the levelset update: :nbsphinx-math:`begin{align*}
psi_{k+1} = (1-s_k) frac{psi_k}{|\psi_k|} + s_k frac{g_{psi_k}}{|g_{\psi_k}|}
end{align*}`
scene = Draw(psi)
scene_cr = Draw(cutRatio, mesh, "cutRatio")
iter_max = 20
converged = False
xm=0.
ym=0.
psi.Set( (x-xm)**2+(y-ym)**2-0.25**2)
psinew.vec.data= psi.vec
J = Integrate(Cost(gfu),mesh)
    for k in range(iter_max):
        # copy new levelset data from psinew into psi
        psi.vec.data = psinew.vec
        J_current = Integrate(Cost(gfu),mesh)
        print( Integrate( (gfu-gfud)**2*dx, mesh) )
        # compute the piecewise constant topological derivative in each domain
        TDPosNeg_pwc.Set( BetaPosNeg * grad(gfu) * grad(gfp)  + FPosNeg*gfp )
        TDNegPos_pwc.Set( BetaNegPos * grad(gfu) * grad(gfp)  + FPosNeg*gfp )
        # compute the cut ratio of the interface elements
        InterpolateLevelSetToElems(psi, 1, 0, cutRatio, mesh, EPS)
        scene_cr.Redraw()
            TD_pwc.vec[j] = cutRatio.vec[j] * TDNegPos_pwc.vec[j] + (1-cutRatio.vec[j])*TDPosNeg_pwc.vec[j]
        TD_node.Set(TD_pwc)
        normTD = sqrt(Integrate(TD_node**2*dx, mesh)) # L2 norm of TD_node
        TD_node.vec.data = 1/normTD * TD_node.vec # normalised TD_node
        normPsi = sqrt(Integrate(psi**2*dx, mesh)) # L2 norm of psi
        psi.vec.data = 1/normPsi * psi.vec  # normalised psi
        linesearch = True
        for j in range(10):
            psinew.vec.data = (1-kappa)*psi.vec + kappa*TD_node.vec
            # update beta and f_rhs
            InterpolateLevelSetToElems(psinew, beta1, beta2, beta, mesh, EPS)
            InterpolateLevelSetToElems(psinew, f1, f2, f_rhs, mesh, EPS)
            # solve PDE without adjoint
            SolvePDE()
            if Jnew > J_current:
                print("--------------------")
                print("-----line search ---")
                kappa = kappa*0.8
                print("kappa", kappa)
                break
        print("----------- Jnew in  iteration ", k, " = ", Jnew, " (kappa = ", kappa, ")")
        print('')
        print("iter" + str(k) + ", Jnew = " + str(Jnew) + " (kappa = ", kappa, ")")
        kappa = min(1, kappa*1.2)
================ iteration  0 ===================
39.29567644494836
cost in beginning of iteration 0 : Cost =  39.29567644494836
----------- Jnew in  iteration  0  =  11.859500825449294  (kappa =  0.05 )
iter0, Jnew = 11.859500825449294 (kappa =  0.05 )
end of iter 0
================ iteration  1 ===================
11.859500825449317
cost in beginning of iteration 1 : Cost =  11.859500825449317
----------- Jnew in  iteration  1  =  6.366217031113301  (kappa =  0.06 )
iter1, Jnew = 6.366217031113301 (kappa =  0.06 )
end of iter 1
================ iteration  2 ===================
6.366217031113343
cost in beginning of iteration 2 : Cost =  6.366217031113343
----------- Jnew in  iteration  2  =  6.219404002333813  (kappa =  0.072 )
iter2, Jnew = 6.219404002333813 (kappa =  0.072 )
end of iter 2
================ iteration  3 ===================
6.219404002333512
cost in beginning of iteration 3 : Cost =  6.219404002333512
kappa 0.06912
kappa 0.055296000000000005
kappa 0.04423680000000001
kappa 0.03538944000000001
kappa 0.028311552000000007
kappa 0.02264924160000001
kappa 0.018119393280000007
kappa 0.014495514624000005
----------- Jnew in  iteration  3  =  5.650460303043283  (kappa =  0.014495514624000005 )
iter3, Jnew = 5.650460303043283 (kappa =  0.014495514624000005 )
end of iter 3
================ iteration  4 ===================
5.650460303043278
cost in beginning of iteration 4 : Cost =  5.6504603030432765
kappa 0.013915694039040007
----------- Jnew in  iteration  4  =  5.538240999804814  (kappa =  0.013915694039040007 )
iter4, Jnew = 5.538240999804814 (kappa =  0.013915694039040007 )
end of iter 4
================ iteration  5 ===================
5.53824099980476
cost in beginning of iteration 5 : Cost =  5.538240999804759
kappa 0.013359066277478408
kappa 0.010687253021982727
kappa 0.008549802417586181
kappa 0.006839841934068946
----------- Jnew in  iteration  5  =  5.477093516467384  (kappa =  0.006839841934068946 )
iter5, Jnew = 5.477093516467384 (kappa =  0.006839841934068946 )
end of iter 5
================ iteration  6 ===================
5.477093516467347
cost in beginning of iteration 6 : Cost =  5.477093516467347
kappa 0.006566248256706188
----------- Jnew in  iteration  6  =  5.085963722546436  (kappa =  0.006566248256706188 )
iter6, Jnew = 5.085963722546436 (kappa =  0.006566248256706188 )
end of iter 6
================ iteration  7 ===================
5.085963722546522
cost in beginning of iteration 7 : Cost =  5.085963722546522
kappa 0.00630359832643794
kappa 0.005042878661150352
kappa 0.004034302928920282
----------- Jnew in  iteration  7  =  5.024676369417167  (kappa =  0.004034302928920282 )
iter7, Jnew = 5.024676369417167 (kappa =  0.004034302928920282 )
end of iter 7
================ iteration  8 ===================
5.024676369417165
cost in beginning of iteration 8 : Cost =  5.024676369417165
kappa 0.003872930811763471
----------- Jnew in  iteration  8  =  4.68016400292729  (kappa =  0.003872930811763471 )
iter8, Jnew = 4.68016400292729 (kappa =  0.003872930811763471 )
end of iter 8
================ iteration  9 ===================
4.6801640029272615
cost in beginning of iteration 9 : Cost =  4.6801640029272615
kappa 0.003718013579292932
kappa 0.0029744108634343455
kappa 0.0023795286907474767
kappa 0.0019036229525979814
----------- Jnew in  iteration  9  =  4.548013307503873  (kappa =  0.0019036229525979814 )
iter9, Jnew = 4.548013307503873 (kappa =  0.0019036229525979814 )
end of iter 9
================ iteration  10 ===================
4.548013307503882
cost in beginning of iteration 10 : Cost =  4.548013307503882
----------- Jnew in  iteration  10  =  4.297138500840193  (kappa =  0.0022843475431175778 )
iter10, Jnew = 4.297138500840193 (kappa =  0.0022843475431175778 )
end of iter 10
================ iteration  11 ===================
4.297138500840255
cost in beginning of iteration 11 : Cost =  4.297138500840255
kappa 0.002192973641392875
kappa 0.0017543789131143001
kappa 0.00140350313049144
----------- Jnew in  iteration  11  =  4.240506681972883  (kappa =  0.00140350313049144 )
iter11, Jnew = 4.240506681972883 (kappa =  0.00140350313049144 )
end of iter 11
================ iteration  12 ===================
4.240506681972922
cost in beginning of iteration 12 : Cost =  4.240506681972922
----------- Jnew in  iteration  12  =  4.11614083570576  (kappa =  0.0016842037565897282 )
iter12, Jnew = 4.11614083570576 (kappa =  0.0016842037565897282 )
end of iter 12
================ iteration  13 ===================
4.116140835705725
cost in beginning of iteration 13 : Cost =  4.116140835705725
----------- Jnew in  iteration  13  =  4.1052025618828925  (kappa =  0.002021044507907674 )
iter13, Jnew = 4.1052025618828925 (kappa =  0.002021044507907674 )
end of iter 13
================ iteration  14 ===================
4.105202561882884
cost in beginning of iteration 14 : Cost =  4.105202561882884
----------- Jnew in  iteration  14  =  4.030283152745945  (kappa =  0.0024252534094892086 )
iter14, Jnew = 4.030283152745945 (kappa =  0.0024252534094892086 )
end of iter 14
================ iteration  15 ===================
4.030283152745991
cost in beginning of iteration 15 : Cost =  4.030283152745991
kappa 0.00232824327310964
kappa 0.0018625946184877122
----------- Jnew in  iteration  15  =  4.013358364170057  (kappa =  0.0018625946184877122 )
iter15, Jnew = 4.013358364170057 (kappa =  0.0018625946184877122 )
end of iter 15
================ iteration  16 ===================
4.013358364170046
cost in beginning of iteration 16 : Cost =  4.013358364170046
----------- Jnew in  iteration  16  =  3.884567520526195  (kappa =  0.0022351135421852545 )
iter16, Jnew = 3.884567520526195 (kappa =  0.0022351135421852545 )
end of iter 16
================ iteration  17 ===================
3.8845675205262893
cost in beginning of iteration 17 : Cost =  3.8845675205262893
kappa 0.0021457090004978444
kappa 0.0017165672003982757
----------- Jnew in  iteration  17  =  3.8369927695927633  (kappa =  0.0017165672003982757 )
iter17, Jnew = 3.8369927695927633 (kappa =  0.0017165672003982757 )
end of iter 17
================ iteration  18 ===================
3.8369927695927624
cost in beginning of iteration 18 : Cost =  3.8369927695927624
----------- Jnew in  iteration  18  =  3.736383183808345  (kappa =  0.0020598806404779307 )
iter18, Jnew = 3.736383183808345 (kappa =  0.0020598806404779307 )
end of iter 18
================ iteration  19 ===================
3.736383183808438
cost in beginning of iteration 19 : Cost =  3.736383183808438
kappa 0.0019774854148588133
----------- Jnew in  iteration  19  =  3.7181392146667878  (kappa =  0.0019774854148588133 )
iter19, Jnew = 3.7181392146667878 (kappa =  0.0019774854148588133 )
end of iter 19
After 999 iterations: $J = $
8bec6ae5e6f6403b96a40b7b29776b4c
