7.1 Shape optimization via the shape derivative in NGSolve¶
- We choose \(f\) as :nbsphinx-math:`begin{equation}
- begin{aligned}
- f(x,y) =& (sqrt{(x - a)^2 + b y^2} - 1) (sqrt{(x + a)^2 + b y^2} - 1) \
&(sqrt{b x^2 + (y - a)^2} - 1) (sqrt{b x^2 + (y + a)^2} - 1) - varepsilon.
end{aligned}
end{equation}` where \(\varepsilon = 0.001, a = 4/5, b = 2\). The corresponding zero level sets of this function are as follows. The green area indicates where \(f\) is negative.
Let us set up the geometry.
# Generate the geometry
geo.AddCircle((0,0), r = 2.5)
mesh.Curve(2)
<ngsolve.comp.Mesh at 0x7f03ec3eb130>
#gfset.vec[:]=0
#gfset.Set((0.2*x,0))
#mesh.SetDeformation(gfset)
a =4.0/5.0
b = 2
gfset = GridFunction(VEC)
gfX = GridFunction(VEC)
Draw(gfset)
Shape derivative¶
# Test and trial functions
PHI, PSI = VEC.TnT()
# shape derivative
dJOmega = LinearForm(VEC)
Bilinear form¶
aX = BilinearForm(VEC)
The first optimisation step¶
Here
Now we note that \(\varphi \mapsto \varphi\circ(\mbox{id}+X_n)^{-1}\) maps the finite element space on \((\mbox{id}+X_n)(\Omega_0)\) to the finite element space on \(\Omega_0\). Therefore the following are equvalent:
# assemble on deformed domain
aX.Assemble()
dJOmega.Assemble()
mesh.UnsetDeformation()
# unset deformation
# compute X_0
alpha = 20.0 / Norm(gfX.vec)
gfset.vec[:]=0
scene = Draw(gfset)
# input("A")
#draw deformed shape
# input("B")
current cost 63.585440628037816
Gradient norm 445.3891568155293
cost after gradient step: 5.186781651375821
Optimisation loop¶
import time
iter_max = 50
gfset.vec[:] = 0
converged = False
# input("A")
for k in range(iter_max):
Jold = Integrate(f, mesh)
# assemble bilinear form
aX.Assemble()
# assemble shape derivative
dJOmega.Assemble()
# step size control
gfset_old.data = gfset.vec
Jnew = Jold + 1
while Jnew > Jold:
gfset.vec.data = gfset_old
Jnew = Integrate(f, mesh)
if Jnew > Jold:
print("reducing step size")
alpha = 0.9*alpha
alpha = alpha*1.5
break
time.sleep(0.1)
Jold = Jnew
cost at iteration 0 : 63.585440628037816
step size: 0.165
cost at iteration 1 : -0.7382612251137118
step size: 0.2475
cost at iteration 2 : -0.8176946345276936
cost at iteration 3 : -0.9325865771728552
step size: 0.556875
cost at iteration 4 : -1.0701686667161618
step size: 0.8353125
cost at iteration 5 : -1.1521943829112362
step size: 1.25296875
cost at iteration 6 : -1.1547492098538301
reducing step size
reducing step size
step size: 1.52235703125
cost at iteration 7 : -1.1549564604998837
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.4982276723046877
cost at iteration 8 : -1.1550479523538317
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3270326873287925
cost at iteration 9 : -1.1554541597742467
reducing step size
reducing step size
reducing step size
step size: 1.4511102435940346
cost at iteration 10 : -1.155598291044698
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.4281101462330694
cost at iteration 11 : -1.1556276896977924
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.4054746004152756
cost at iteration 12 : -1.1558603169379684
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3831978279986936
cost at iteration 13 : -1.1559789883243972
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3612741424249144
cost at iteration 14 : -1.1562105741574882
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3396979472674797
cost at iteration 15 : -1.156329595403822
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.3184637348032904
cost at iteration 16 : -1.1564431842388996
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.1678094761459925
cost at iteration 17 : -1.156537664168601
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.034369726354171
cost at iteration 18 : -1.1566378011382392
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0179749661914572
cost at iteration 19 : -1.1566614856496904
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0018400629773228
cost at iteration 20 : -1.1566888376561855
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9859608979791321
cost at iteration 21 : -1.156722105821479
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9703334177461629
cost at iteration 22 : -1.1567606660811283
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9549536330748863
cost at iteration 23 : -1.1568020235063836
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9398176179906492
cost at iteration 24 : -1.1568400852839162
reducing step size
reducing step size
reducing step size
step size: 1.027690565272775
cost at iteration 25 : -1.1568461070793694
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0114016698132016
cost at iteration 26 : -1.1568553438714937
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9953709533466624
cost at iteration 27 : -1.156869963319767
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9795943237361178
cost at iteration 28 : -1.1568868368878324
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9640677537049005
cost at iteration 29 : -1.1569064364524482
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9487872798086778
cost at iteration 30 : -1.1569251064110817
reducing step size
reducing step size
reducing step size
step size: 1.0374988904707894
cost at iteration 31 : -1.1569284853084116
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0210545330568275
cost at iteration 32 : -1.1569330831857187
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0048708187078768
cost at iteration 33 : -1.1569408837564752
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.988943616231357
cost at iteration 34 : -1.1569499852437595
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.97326885991409
cost at iteration 35 : -1.156961339285066
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9578425484844518
cost at iteration 36 : -1.1569724959756595
reducing step size
reducing step size
reducing step size
step size: 1.047400826767748
cost at iteration 37 : -1.1569741997366239
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0307995236634793
cost at iteration 38 : -1.156976406299169
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0144613512134133
cost at iteration 39 : -1.1569809493716794
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9983821387966807
cost at iteration 40 : -1.1569864477238287
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9825577818967535
cost at iteration 41 : -1.156994032197216
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.96698424105369
cost at iteration 42 : -1.1570017690359318
reducing step size
reducing step size
reducing step size
step size: 1.05739726759221
cost at iteration 43 : -1.1570019192969718
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0406375209008738
cost at iteration 44 : -1.1570022681885446
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0241434161945948
cost at iteration 45 : -1.1570046749674276
reducing step size
reducing step size
reducing step size
reducing step size
step size: 1.0079107430479106
cost at iteration 46 : -1.157008000089275
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9919353577706012
cost at iteration 47 : -1.157013564226876
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9762131823499371
cost at iteration 48 : -1.1570196132648598
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9607402034096908
cost at iteration 49 : -1.1570268476759218
reducing step size
reducing step size
reducing step size
reducing step size
step size: 0.9455124711856473
Using SciPy optimize toolbox¶
ngsglobals.msg_level = 1
mesh.Curve(2)
a =4.0/5.0
b = 2
# element order
order = 1
PHI = VEC.TrialFunction()
PSI = VEC.TestFunction()
gfset.Set((0,0))
# only for new gui
#if scene:
# scene.setDeformation(True)
#Draw(gfset,mesh,"gfset")
Curve elements, order = 2
Shape derivative¶
fX = LinearForm(VEC)
# analytic shape derivative
Define the bilinear form
# Cauchy-Riemann descent CR
CR = False
# bilinear form for gradient
if CR == True:
gamma = 100
aX.Assemble()
def J(x_):
gfset.Set((0,0))
# x_ NumPy vector
cost_c = Integrate (f, mesh)
return cost_c
gfset.Set((0,0))
# x_ NumPy vector
fX.Assemble()
if euclid == True:
gfX.vec.data = fX.vec
gfX.vec.data = invaX * fX.vec
xk_ = np.copy(x0)
# maximal iteration
it_max = 50
nfval_total = 0
print('\n')
for i in range(1, it_max):
# compute descent direction
pk = -gradJ_(xk_)
# eval cost function
fold = J_(xk_)
# perform armijo stepsize
if CR == True:
alpha0 = 0.15
alpha0 = 0.11
nfval_total += nfval
xk_ = xk_ - step * grad_xk
break
elif i == it_max-1:
gfset.vec[:]=0
Iteration 1 | Cost 63.585440628037816 | grad norm 445.3891568155287
Iteration 2 | Cost -0.7382612251137115 | grad norm 4.83096429660247
Iteration 3 | Cost -0.7857804904180997 | grad norm 4.845836269046255
Iteration 4 | Cost -0.8340190220409043 | grad norm 4.813255015723316
Iteration 5 | Cost -0.8819932057553787 | grad norm 4.724540953421632
Iteration 6 | Cost -0.9285329806179062 | grad norm 4.572725032822891
Iteration 7 | Cost -0.9723683510026829 | grad norm 4.354102519630572
Iteration 8 | Cost -1.012266593262478 | grad norm 4.06994516503022
Iteration 9 | Cost -1.0472020217918228 | grad norm 3.727550452257371
Iteration 10 | Cost -1.0765177275718774 | grad norm 3.34032064494751
Iteration 11 | Cost -1.1000284914205707 | grad norm 2.926603252272237
Iteration 12 | Cost -1.1180257802903903 | grad norm 2.507099966539478
Iteration 13 | Cost -1.131180671798799 | grad norm 2.1019848782671553
Iteration 14 | Cost -1.1403814574777296 | grad norm 1.7276648579607528
Iteration 15 | Cost -1.1465612121108741 | grad norm 1.3952307764340515
Iteration 16 | Cost -1.1505659302990408 | grad norm 1.109999773331136
Iteration 17 | Cost -1.1530834103618983 | grad norm 0.8723292029461809
Iteration 18 | Cost -1.1546273377527376 | grad norm 0.6790431917120955
Iteration 19 | Cost -1.1555564457774934 | grad norm 0.524926205298827
Iteration 20 | Cost -1.1561082962671945 | grad norm 0.4039641213518469
Iteration 21 | Cost -1.156433787972622 | grad norm 0.31020187558462997
Iteration 22 | Cost -1.156625722874324 | grad norm 0.23823684381874635
Iteration 23 | Cost -1.1567397786651876 | grad norm 0.1834369658442347
Iteration 24 | Cost -1.156808743783146 | grad norm 0.14198177265203302
Iteration 25 | Cost -1.1568516663794377 | grad norm 0.11080189179046163
Iteration 26 | Cost -1.1568795063094082 | grad norm 0.08747596157450288
Iteration 27 | Cost -1.1568985323419332 | grad norm 0.07011478242597977
Iteration 28 | Cost -1.1569123209284013 | grad norm 0.057252689443980674
Iteration 29 | Cost -1.1569229144050097 | grad norm 0.047755249097678164
Iteration 30 | Cost -1.1569314851192378 | grad norm 0.0407466320243729
Iteration 31 | Cost -1.1569387130241238 | grad norm 0.03555541402345516
Iteration 32 | Cost -1.1569449993776226 | grad norm 0.03167419925502564
Iteration 33 | Cost -1.1569505871726007 | grad norm 0.028727501046364196
Iteration 34 | Cost -1.1569556288710916 | grad norm 0.02644400443905319
Iteration 35 | Cost -1.156960224537271 | grad norm 0.02463197167974173
Iteration 36 | Cost -1.1569644434456434 | grad norm 0.023158187638717156
Iteration 37 | Cost -1.1569683363413645 | grad norm 0.02193101836093458
Iteration 38 | Cost -1.1569719421945255 | grad norm 0.020887596172047395
Iteration 39 | Cost -1.1569752922488747 | grad norm 0.01998460213096205
Iteration 40 | Cost -1.1569784128384424 | grad norm 0.019192815309508768
Iteration 41 | Cost -1.1569813251680743 | grad norm 0.018489136123896403
Iteration 42 | Cost -1.1569840495535753 | grad norm 0.01785952766202848
Iteration 43 | Cost -1.1569866026100675 | grad norm 0.01729163715015754
Iteration 44 | Cost -1.1569889999341965 | grad norm 0.01677732377711827
Iteration 45 | Cost -1.1569912550705606 | grad norm 0.016310610754291282
Iteration 46 | Cost -1.1569933795428053 | grad norm 0.015884776661851802
Iteration 47 | Cost -1.1569953848027177 | grad norm 0.015496092662886955
Iteration 48 | Cost -1.1569972797142984 | grad norm 0.015138814338987313
Iteration 49 | Cost -1.1569990745698648 | grad norm 0.014816070949413285
gradient norm: 0.014516729693228373
n evals f: 49
f val: -1.1569990745698648
L-BFGS method¶
In the BFGS method we replace
by
- where \(H_\Omega\) is an approximation of the second shape derivative at \(\Omega\). On the discrete level we solve :nbsphinx-math:`begin{align}
- text{ solve }quad B_nX_k & = nabla J(Omega_k) \
- text{ update } quad s_k & := -alpha_k p_k \
y_k & := nabla J_h(Omega_{k+1}) - nabla J_h(Omega_k) \
B_{k+1} &:= B_k + frac{y_kotimes y_k}{y_kcdot s_k} + frac{B_ks_kotimes B_ks_k}{B_ky_kcdot B_ks_k}. end{align}`
# options for optimiser
options = {"maxiter":1000,
"disp":True,
"gtol":1e-10}
RUNNING THE L-BFGS-B CODE
Machine precision = 2.220D-16
N = 7978 M = 10
At iterate 0 f= -1.15700D+00 |proj g|= 9.61287D-04
At iterate 1 f= -1.15700D+00 |proj g|= 1.77880D-03
At iterate 2 f= -1.15703D+00 |proj g|= 1.17239D-03
At iterate 3 f= -1.15706D+00 |proj g|= 3.49236D-03
ys=-2.188E-04 -gs= 2.798E-03 BFGS update SKIPPED
At iterate 4 f= -1.15707D+00 |proj g|= 2.35894D-03
At iterate 5 f= -1.15709D+00 |proj g|= 9.74156D-04
At iterate 6 f= -1.15709D+00 |proj g|= 1.26338D-03
At iterate 7 f= -1.15709D+00 |proj g|= 1.33337D-03
At iterate 8 f= -1.15709D+00 |proj g|= 1.35435D-03
At iterate 9 f= -1.15709D+00 |proj g|= 1.40591D-03
At iterate 10 f= -1.15709D+00 |proj g|= 1.42675D-03
At iterate 11 f= -1.15709D+00 |proj g|= 1.47314D-03
At iterate 12 f= -1.15709D+00 |proj g|= 1.49676D-03
At iterate 13 f= -1.15709D+00 |proj g|= 1.53982D-03
At iterate 14 f= -1.15709D+00 |proj g|= 1.55132D-03
At iterate 15 f= -1.15709D+00 |proj g|= 1.59621D-03
At iterate 16 f= -1.15709D+00 |proj g|= 1.61391D-03
At iterate 17 f= -1.15709D+00 |proj g|= 1.67265D-03
At iterate 18 f= -1.15709D+00 |proj g|= 1.71145D-03
At iterate 19 f= -1.15709D+00 |proj g|= 1.81029D-03
At iterate 20 f= -1.15709D+00 |proj g|= 1.95316D-03
At iterate 21 f= -1.15709D+00 |proj g|= 1.99807D-03
At iterate 22 f= -1.15711D+00 |proj g|= 1.96615D-03
At iterate 23 f= -1.15712D+00 |proj g|= 1.67698D-03
At iterate 24 f= -1.15712D+00 |proj g|= 2.09128D-04
At iterate 25 f= -1.15712D+00 |proj g|= 1.69140D-04
At iterate 26 f= -1.15712D+00 |proj g|= 1.71713D-04
At iterate 27 f= -1.15713D+00 |proj g|= 2.08134D-04
At iterate 28 f= -1.15713D+00 |proj g|= 2.54162D-04
At iterate 29 f= -1.15713D+00 |proj g|= 1.79445D-04
At iterate 30 f= -1.15713D+00 |proj g|= 1.35263D-04
At iterate 31 f= -1.15713D+00 |proj g|= 1.35263D-04
fun: -1.1571274943428573
hess_inv: <7978x7978 LbfgsInvHessProduct with dtype=float64>
jac: array([ 1.10198186e-05, -8.87645210e-05, 4.98921966e-05, ...,
-4.45887814e-06, 5.34733615e-06, -4.57391704e-06])
message: b'CONVERGENCE: REL_REDUCTION_OF_F_<=_FACTR*EPSMCH'
nfev: 219
nit: 31
status: 0
success: True
x: array([-4.75169208e-04, 6.98632778e-01, -6.98685559e-01, ...,
4.72891499e-03, -1.25358955e-03, 4.73507746e-03])
F = final function value
7978 31 219 1 1 0 1.353D-04 -1.157D+00
F = -1.1571274943428573
Cauchy time 1.450E-04 seconds.
Subspace minimization time 2.740E-02 seconds.
Line search time 5.554E+01 seconds.
Total User time 5.583E+01 seconds.
This may lead to overly streched or even degenerated triangles. One way to improve this is to modify the above equation by
The two equations \(BX = 0\) are precisely the Cauchy-Riemann equations \(-\partial_x X_1 + \partial_y X_2=0\) and \(\partial_y X_1 + \partial_x X_2\). So the bigger \(\gamma\) the more angle preserving is the gradient. So by adding the B term we enforce conformaty with strengh \(\gamma\).
alpha = 100
