8.5 Space-time discretizations on unfitted geometries
%%html
\[\begin{split}\left\{ \begin{aligned} \partial_t u + \mathbf{w} \cdot \nabla u - \alpha \Delta u &= f \quad \text{ in } \Omega(t), & \\ ~ \partial_{\mathbf{n}} u &= 0 \quad \text{ on } \partial \Omega(t), & \\ u &= u_0 \quad \text{at } t=0, & \\ \end{aligned}\right.\end{split}\]
\[\operatorname{div}(\mathbf{w}) = 0 \quad \text{ in } \Omega(t), \quad \mathbf{w} \cdot n = \mathcal{V}_n \text{ on } \partial \Omega(t).\]
Literature:
ngsglobals.msg_level = 1
#import netgen.gui
importing ngsxfem-2.1.2607.dev0
# DISCRETIZATION PARAMETERS:
i = 3
n_steps = 2**i
space_refs = i
# Polynomial order in time
k_t = 2
# Polynomial order in space
k_s = k_t
lset_order_time = k_t
# Integration order in time
time_order = 2 * k_t
# Time stepping parameters
tstart = 0
tend = 0.5
maxh = 0.5
# Ghost-penalty parameter
gamma = 0.05
Background geometry and mesh:
  • We consider a simple square as background domain an use a simple mesh for that.
  • The space-time method uses tensor-product elements. Hence, we do not need space-time meshes.
# Outer domain:
rect = SplineGeometry()
for j in range(space_refs):
    ngmesh.Refine()
Handling of the time variable
For the handling of the space-time integration we use the following rules:
  • every time step is formulated with respect to the reference interval \([0,1)\) in time
  • Example: \(t_{n-1} = 0.4\), \(t=0.55\), \(\Delta t = 0.2\) \(\quad \longrightarrow \quad\) \(\hat{t} = 0.75\).
  • \(\hat{t}\) is the ReferenceTimeVariable (tref)
  • We define \(t_{old}(=t_{n-1})\) and \(\Delta t\) as a Parameter, s.t. we can change the time interval later
told = Parameter(tstart)
t = told + delta_t * tref
t.MakeVariable()
<ngsolve.fem.CoefficientFunction at 0x7f3c06876e10>
Data functions (depending on \(t\))
# Level set geometry
R = 0.5
# Convection velocity:
# Level set
r = sqrt(x**2 + (y - rho)**2)
levelset = r - R
# Diffusion coefficient
alpha = 1
# Solution
# R.h.s.
coeff_f = (u_exact.Diff(t)
A View on the time-dependent level set function on \([0,\)tend\(]\)
Space-Time finite elements
  • For the construction of a space-time FESpace we can combine any spatial FESpace with a scalar FiniteElement in a tensor-product fashion.
  • Here, we use a nodal FiniteElement to simplify the extraction of spatial functions at fixed times.
tfe = ScalarTimeFE(k_t)
st_fes = tfe * fes1
Levelset mesh adaptation class
                                            order_time=lset_order_time,
                                            threshold=0.5,
                                            discontinuous_qn=True)
Space-Time version of the CutInfo class
To Update the slab geometry later on (for updated values of told) we do the following:
  • update of the isoparametric mapping
  • update of the cut information
  • update of facet markers
  • update of dof markers
def UpdateTimeSlabGeometry():
                                              b=ci.GetElementsOfType(IF))
Note that here the call of CalcDeformation of lsetadap entails the calculation of the P1 projection of the levelset function internally. The space-time P1-in-space level set approximation of lsetadap can be accessed by lsetadap.levelsetp1[timetype] where timetype is either INTERVAL which yields the space-time function or TOP or BOTTOM which yields the spatial P1 function that is obtained by restriction to either tref=1 or tref=0. Similarly the access to the deformation is organized as lsetadap.deformation[timetype].
Solution GridFunction
gfu = GridFunction(st_fes)
Variational formulation
We start by multiplying the equation
\begin{equation*} \partial_{t} u- \alpha \Delta{u} + w \cdot \nabla{u} = f \quad in \quad \Omega(t), \qquad t \in [0,T] \end{equation*} by a test function \(v\) and perform integration by parts.
Upwind DG in time
limits-time-slab
Ghost penalty stabilization
\[\begin{split}\text{with} \qquad\qquad s_h(u,v) = \sum\limits_{F \in F_{h}}{ \gamma_{j} \int\limits_{t_{n-1}}^{t_{n}}{ \int\limits_{\omega_F}{ h^{-2} [\![ u]\!] \, [\![ v]\!] \, d\mathbf{x} \, dt. } } } \\\end{split}\]
where \([\![u]\!]\) is the difference of \(u|_{T_1}\) and \(u|_{T_2}\) (interpreted as polynomials \(\in \mathbb{R}^d\)) and \(F_h\) is the set of facets on which the stabilization shall be applied. macro-element
Implementation of space-time integrals
u,v = st_fes.TnT()
Transformation from reference interval to \((t_{n-1},t_n)\):
The transformation
\[(x,\hat{t}) \to (x,t_{n-1} + \hat{t} \Delta t), \qquad v(x,t) = \hat{v}(x,\hat{t}), \quad u(x,t) = \hat{u}(x,\hat{t}).\]
def dt(u):
                           facet_restriction=ba_facets)
a += v * w * grad(u) * dQ
a += u * v * dOmold
Fifth integral:
\[s_h(u,v) = \sum\limits_{F \in F_{h}}{ \gamma_{j} \int\limits_{t_{n-1}}^{t_{n}}{ \int\limits_{\omega_F}{ h^{-2} [\![ u]\!] \, [\![ v]\!] \, d\mathbf{x} \, dt. }}} = \sum\limits_{F \in F_{h}}{ \Delta t \ \gamma_{j} \int\limits_{t_{n-1}}^{t_{n}}{ \int\limits_{\omega_F}{ h^{-2} [\![ \hat u]\!] \, [\![ \hat v]\!] \, d\mathbf{x} \, dt. }}}\]
f = LinearForm(st_fes)
f += coeff_f * v * dQ
f += u_last * v * dOmold
Solution of linear systems in every time step
  • setup the new linear system
  • solve the linear system
def SolveForTimeSlab():
    a.Assemble(reallocate=True)
At the end of every time step, we
  • store the solution at \(t_n\) into a (purely) spatial GridFunction (to be used in next time step)
  • compute the error
  • update visualization
def FinalizeStep(scene=None):
    #  * for error evaluation
    #  * upwind-coupling to next time slab
    # Compute error at final time
    if scene:
The final time loop
# Set initial values
told.Set(0)
timestep = 0
md_comps = 0
        if timestep % 1 == 0:
            md_comps += 1
        SolveForTimeSlab()
        timestep += 1
        FinalizeStep(scene)
print("")
t =  0.500000000, L2 error = 3.273189062e-01
Play around suggestions:
  • use other orders in space or time (and a coarse grid)
  • use different level set evolutions
Further material:
