This page was generated from unit-11.2-bem-Laplace/Laplace_DtN_direct.ipynb.
11.2.2. Dirichlet Laplace Direct Method¶
keys: homogeneous Dirichlet bvp, double and single layer potential, unknown Neumann data
from ngsolve.bem import *
Consider the Dirichlet boundary value problem
Let us choose the following ansatz for the solution \(u\in H^1(\Omega)\) (direct ansatz)
and solve for the Neumann data \(u_1 \in H^{-\frac12}(\Gamma)\) by the boundary element method, i.e.,
sp = Sphere( (0,0,0), 1)
mesh = Mesh( OCCGeometry(sp).GenerateMesh(maxh=0.2)).Curve(4)
Create the finite element spaces for \(H^{-\frac12}(\Gamma)\) and \(H^{\frac12}(\Gamma)\) according to the given mesh:
fesL2 = SurfaceL2(mesh, order=3, dual_mapping=True)
u,v = fesL2.TnT()
fesH1 = H1(mesh, order=4)
uH1,vH1 = fesH1.TnT()
print ("ndofL2 = ", fesL2.ndof, "ndof H1 = ", fesH1.ndof)
ndofL2 = 7220 ndof H1 = 21241
Compute the interpolation of exact Dirichlet data \(u_0\) in finite element space:
u0 = GridFunction(fesH1)
u0.Interpolate (uexa)
Draw (u0, mesh, draw_vol=False, order=3);
The discretisation of the above variational formulation leads to a system of linear equations, ie
where the linear operators are as follows
\(\mathrm{V}\) is the single layer operator. \(\mathrm V\) is regular and symmetric.
\(\mathrm{M}\) is a mass matrix.
\(\mathrm{K}\) is the double layer operator.
We approximate the linear operators as hmatrices and solve for the Neumann data \(u_1\) with an iterative solver:
u1 = GridFunction(fesL2)
pre = BilinearForm(u*v*ds, diagonal=True).Assemble().mat.Inverse()
V = LaplaceSL(u*ds)*v*ds
M = BilinearForm( uH1 * v.Trace() * ds(bonus_intorder=3)).Assemble()
K = LaplaceDL(uH1*ds)*v*ds
rhs = ( (0.5 * M.mat + K.mat)*u0.vec).Evaluate()
CG(mat = V.mat, pre=pre, rhs = rhs, sol=u1.vec, tol=1e-8, maxsteps=50, initialize=False, printrates=True)
CG iteration 1, residual = 0.26882442378337346
CG iteration 2, residual = 0.0655351684505376
CG iteration 3, residual = 0.01553700276984912
CG iteration 4, residual = 0.0036775753493559975
CG iteration 5, residual = 0.0009545914702082924
CG iteration 6, residual = 0.0013658090651907718
CG iteration 7, residual = 0.00019656586602843904
CG iteration 8, residual = 5.780275494299603e-05
CG iteration 9, residual = 4.636043835470735e-05
CG iteration 10, residual = 3.3998393641368276e-05
CG iteration 11, residual = 1.7052341979319546e-05
CG iteration 12, residual = 9.985256252872691e-06
CG iteration 13, residual = 4.669139761474325e-06
CG iteration 14, residual = 4.0876418932557886e-06
CG iteration 15, residual = 2.724594405447461e-06
CG iteration 16, residual = 2.086186767282083e-06
CG iteration 17, residual = 1.9082937570422438e-06
CG iteration 18, residual = 1.779998968393692e-06
CG iteration 19, residual = 9.154269963120529e-07
CG iteration 20, residual = 6.251758298760979e-07
CG iteration 21, residual = 5.062067583097599e-07
CG iteration 22, residual = 5.892187070432837e-07
CG iteration 23, residual = 4.5773187814164984e-07
CG iteration 24, residual = 3.8096759792052647e-07
CG iteration 25, residual = 2.0579028348241646e-07
CG iteration 26, residual = 1.00827446313782e-07
CG iteration 27, residual = 8.454411322281001e-08
CG iteration 28, residual = 5.7606047244721885e-08
CG iteration 29, residual = 9.844118624914557e-08
CG iteration 30, residual = 8.408413147376838e-08
CG iteration 31, residual = 4.587198756047232e-08
CG iteration 32, residual = 2.7332668500532224e-08
CG iteration 33, residual = 2.017490225828201e-08
CG iteration 34, residual = 2.5549975926317182e-08
CG iteration 35, residual = 1.3193959560237007e-08
CG iteration 36, residual = 7.626710134887075e-09
CG iteration 37, residual = 2.517926527222629e-08
CG iteration 38, residual = 5.868221957430554e-09
CG iteration 39, residual = 5.494857513345213e-09
CG iteration 40, residual = 4.4241589509111815e-09
CG iteration 41, residual = 2.4096856449820362e-09
Draw (u1, mesh, draw_vol=False, order=3);
Let’s have a look at the exact Neumann data and compute the error of the numerical solution:
n = specialcf.normal(3)
u1exa = graduexa*n
Draw (u1exa, mesh, draw_vol=False, order=3);
print ("L2-error =", sqrt (Integrate ( (u1exa-u1)**2, mesh, BND)))
L2-error = 0.0002506102210273427
