This page was generated from unit-11.2-bem-Laplace/Laplace_NtD_indirect.ipynb.
11.2.3 Neumann Laplace Indirect Method¶
keys: homogeneous Neumann bvp, hypersingular operator
from ngsolve.bem import *
Consider the Neumann boundary value problem
The solution \(u\in H^1(\Omega)\) of the above bvp can be written in the following form (representation forumula)
Let’s carefully apply the Neumann trace \(\gamma_1\) to the representation formula and solve the resulting boundary integral equation for \(m \in H^{\frac12}(\Gamma)\) by discretisation of the following variational formulation:
sp = Sphere( (0,0,0), 1)
mesh = Mesh( OCCGeometry(sp).GenerateMesh(maxh=0.3)).Curve(2)
Define the finite element space for \(H^{\frac12}(\Gamma)\) for given geometry :
fesH1 = H1(mesh, order=2, definedon=mesh.Boundaries(".*"))
uH1,vH1 = fesH1.TnT()
print ("ndof H1 = ", fesH1.ndof)
ndof H1 = 630
Define the right hand side with given Neumann data \(u_1\):
n = specialcf.normal(3)
u1exa = graduexa*n
rhs = LinearForm(u1exa*vH1.Trace()*ds(bonus_intorder=3)).Assemble()
The discretisation of the variational formulation leads to a system of linear equations, ie
where \(\mathrm{D}\) is the hypersingular operator and the stabilisation \((\mathrm D + \mathrm{S})\) is regular and symmetric.
vH1m1 = LinearForm(vH1*1*ds(bonus_intorder=3)).Assemble()
S = (BaseMatrix(Matrix(vH1m1.vec.Reshape(1))))@(BaseMatrix(Matrix(vH1m1.vec.Reshape(fesH1.ndof))))
m = GridFunction(fesH1)
pre = BilinearForm(uH1*vH1*ds).Assemble().mat.Inverse(freedofs=fesH1.FreeDofs())
D=LaplaceSL(curl(uH1)*ds)*curl(vH1)*ds
CG(mat = D.mat+S, pre=pre, rhs = rhs.vec, sol=m.vec, tol=1e-8, maxsteps=200, initialize=False, printrates=True)
Draw (m, mesh, draw_vol=False, order=3);
CG iteration 1, residual = 1.092624998882661
CG iteration 2, residual = 0.5729010293389224
CG iteration 3, residual = 0.3431253018753172
CG iteration 4, residual = 0.2303924025968425
CG iteration 5, residual = 0.1784007812931949
CG iteration 6, residual = 0.11050148131747625
CG iteration 7, residual = 0.07041182879523007
CG iteration 8, residual = 0.04245917406352975
CG iteration 9, residual = 0.026947807306562082
CG iteration 10, residual = 0.015528094493477258
CG iteration 11, residual = 0.009046901059635855
CG iteration 12, residual = 0.004930671570556998
CG iteration 13, residual = 0.002669245037366955
CG iteration 14, residual = 0.0013289096044563806
CG iteration 15, residual = 0.0006491869037722307
CG iteration 16, residual = 0.00030590035747030586
CG iteration 17, residual = 0.0001404871255973697
CG iteration 18, residual = 6.305215386718816e-05
CG iteration 19, residual = 2.7094055093101134e-05
CG iteration 20, residual = 1.1674905025436948e-05
CG iteration 21, residual = 4.60950161864175e-06
CG iteration 22, residual = 1.763497605545483e-06
CG iteration 23, residual = 6.5021199365537e-07
CG iteration 24, residual = 2.299851571302292e-07
CG iteration 25, residual = 8.60167374308212e-08
CG iteration 26, residual = 4.116665599289134e-08
CG iteration 27, residual = 3.6541952799934714e-08
CG iteration 28, residual = 3.9446866060541044e-08
CG iteration 29, residual = 2.0417995291360302e-08
CG iteration 30, residual = 9.034079689019415e-09
Note: the hypersingular operator is implemented as follows
Details for instance in Numerische Näherungsverfahren für elliptische Randwertprobleme, p.127, p.259 (1st edition).
