6.1.2 Surface PDEs
Surface Poisson equation
Homogeneous Dirichlet data
\[\int_S\nabla_{\Gamma}u\cdot\nabla_{\Gamma}v\,ds = \int_S fv\,ds,\qquad u=0 \text{ on } \Gamma_D\]
geo          = CSGeometry()
sphere       = Sphere(Pnt(0,0,0), 1)
bot          = Plane(Pnt(0,0,0), Vec(0,0,-1))
finitesphere = sphere * bot
mesh.Curve(2)
u, v = fes.TnT()
print(fes.FreeDofs())
350: 111111111111111111
force = sin(x)*y*exp(z)
f += force*v*ds
<ngsolve.comp.LinearForm at 0x7f6e816cf2b0>
Solving is done as usual
Draw(gfu, mesh, "u")
Inhomogeneous Dirichlet data
r = f.vec.CreateVector()
Draw(gfu)
Finite element spaces for surfaces
a += grad(u)*grad(v)*ds
NgException                               Traceback (most recent call last)
Cell In[7], line 1
      2 a.Assemble()
The second class is given by
Space
Surface Space
L2
SurfaceL2
HDiv
HDivSurface
HDivDiv
HDivDivSurface
FacetFESpace
FacetSurface
