\[\begin{split}\left\{ \begin{aligned} \partial_t u - \Delta u &= f \quad \text{ in } \Omega \text{ for all } t \in [0,1], & \\ ~ \partial_{\mathbf{n}} u &= 0 \quad \text{ on } \partial \Omega, & \\ u &= u_0 \quad \text{at } t=0. & \\ \end{aligned}\right.\end{split}\]
import time
ngsglobals.msg_level = 1
importing ngsxfem-2.1.2607.dev0
# Space finite element order
order = 1
# Time finite element order
k_t = 1
# Final simulation time
tend = 1.0
# Time step
delta_t = 1 / 32
def dt(u): return 1.0 / delta_t * dtref(u) tnew = 0 told = Parameter(0) t = told + delta_t * tref t.MakeVariable()
<ngsolve.fem.CoefficientFunction at 0x7f149f25d310>
tfe = ScalarTimeFE(k_t)
gfu = GridFunction(st_fes)
u, v = st_fes.TnT()
coeff_f = coeff_f.Compile()
dxold = dmesh(mesh, tref=0)
dxnew = dmesh(mesh, tref=1)
\[\int_{Q} (\partial_t u v + \nabla u \cdot \nabla v) ~~d(x,t) + \int_{\Omega} u_-(\cdot,t^{n-1}) v_-(\cdot,t^{n-1}) dx = \int_Q f v ~ d(x,t) + \int_{\Omega} u_+(\cdot,t^{n-1}) v_-(\cdot,t^{n-1}) dx\quad\forall v \in W_h\]
a += u * v * dxold
f = LinearForm(st_fes)
f += coeff_f * v * dxt
f += u_last * v * dxold
told.Set(0.)
Finally, the problem is solved in a time-stepping manner, which includes:
  • Assemble of r.h.s.
  • solve time step solution
  • extract solution on new time level (RestrictGFInTime extracts a spatial GridFunction from a space-time one for a fixed value `tref)
  • storing time step solution for later visualization (see last cell)
  • measuring the error
timestep = 0
    if timestep % 4 == 0:
    timestep += 1
    gfu.vec.data = ainv * f.vec
t =  1.000000000, L2 error = 1.797697622e-04
