7.1 Shape optimization via the shape derivative
\[\min_{\Omega} J(\Omega) := \int_{\Omega} f(x)\;dx, \quad f\in C^1(\mathbf{R}^d).\]
\[\Omega^*:= \{x\in \mathbf{R}^d:\; f(x)\le 0\}.\]
\[\min_{X} J((\mbox{id}+X)(\Omega_0)),\]
Initial geometry and shape function
We choose \(f\) as
\[\begin{split}\begin{array}{rl} f(x,y) =& \left(\sqrt{(x - a)^2 + b y^2} - 1 \right) \left(\sqrt{(x + a)^2 + b y^2} - 1 \right) \\ & \left(\sqrt{b x^2 + (y - a)^2} - 1 \right) \left(\sqrt{b x^2 + (y + a)^2} - 1 \right) - \varepsilon. \end{array}\end{split}\]
bc396bdde88d400a9291a6aff1a7f9d0
Let us set up the geometry.
# Generate the geometry
geo.AddCircle((0,0), r = 2.5)
mesh.Curve(2)
<ngsolve.comp.Mesh at 0x7f79c305c170>
#gfset.vec[:]=0
#gfset.Set((0.2*x,0))
#mesh.SetDeformation(gfset)
a =4.0/5.0
b = 2
gfset = GridFunction(VEC)
gfX = GridFunction(VEC)
Draw(gfset)
Shape derivative
\[DJ(\Omega)(X) = \int_\Omega f \mbox{div}(X) + \nabla f\cdot X\;dx\]
# Test and trial functions
PHI, PSI = VEC.TnT()
# shape derivative
dJOmega = LinearForm(VEC)
Bilinear form
\[(\varphi,\psi) \mapsto b_\Omega(\varphi,\psi):= \int_\Omega (\nabla \varphi+\nabla \varphi^\top): \nabla\psi+\varphi\cdot \psi\; dx.\]
\[b_\Omega(X,\psi) = DJ(\Omega)(\psi)\quad \text{ for all } \quad \psi \in H^1(\Omega)\]
aX = BilinearForm(VEC)
The first optimisation step
\[\mathcal J_{\Omega_0}(X):= J((\mbox{id} + X)(\Omega_0)).\]
\[D\mathcal J_{\Omega_0}(X_n)(X) = DJ((\mbox{id}+X_n)(\Omega_0))(X\circ(\mbox{id}+X_n)^{-1}).\]
Here
  • \((\mbox{id}+X_n)(\Omega_0)\) is current shape
  • assembling \(\varphi \mapsto D\mathcal J_{\Omega_0}(X_n)(\varphi)\) on the fixed domain \(\Omega_0\)
  • assembling \(\varphi \mapsto DJ((\mbox{id}+X_n)(\Omega_0))(\varphi)\) on the deformed domain \((\mbox{id}+X_n)(\Omega_0)\).
# assemble on deformed domain
aX.Assemble()
dJOmega.Assemble()
mesh.UnsetDeformation()
# unset deformation
\[\Omega_1 = (\mbox{id} - \alpha_1 X_0)(\Omega_0).\]
# compute X_0
alpha = 20.0 / Norm(gfX.vec)
gfset.vec[:]=0
scene = Draw(gfset)
# input("A")
#draw deformed shape
# input("B")
current cost  63.58544060454411
Gradient norm  441.59290658661814
cost after gradient step: 5.023994232440696
Optimisation loop
\[\Omega_2 = (\mbox{id} - \alpha_0 X_0 - \alpha_1 X_1)(\Omega_0)\]
import time
iter_max = 50
gfset.vec[:] = 0
converged = False
# input("A")
for k in range(iter_max):
    Jold = Integrate(f, mesh)
    # assemble bilinear form
    aX.Assemble()
    # assemble shape derivative
    dJOmega.Assemble()
    # step size control
    gfset_old.data = gfset.vec
    Jnew = Jold + 1
    while Jnew > Jold:
        gfset.vec.data = gfset_old
        Jnew = Integrate(f, mesh)
        if Jnew > Jold:
            print("reducing step size")
            alpha = 0.9*alpha
            alpha = alpha*1.5
            break
    time.sleep(0.1)
    Jold = Jnew
cost at iteration  0 :  63.58544060454411
step size:  0.165
cost at iteration  1 :  -0.738254576357041
step size:  0.2475
cost at iteration  2 :  -0.8176867576439081
step size:  0.37124999999999997
cost at iteration  3 :  -0.9325774655646528
step size:  0.556875
cost at iteration  4 :  -1.0701609035569999
step size:  0.8353125
cost at iteration  5 :  -1.1521932913592041
step size:  1.25296875
cost at iteration  6 :  -1.154748226275979
reducing step size
reducing step size
step size:  1.52235703125
cost at iteration  7 :  -1.1549550076062756
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.4982276723046877
cost at iteration  8 :  -1.1550471713549186
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.3270326873287925
cost at iteration  9 :  -1.1554533885077465
reducing step size
reducing step size
reducing step size
step size:  1.4511102435940346
cost at iteration  10 :  -1.155597635089538
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.4281101462330694
cost at iteration  11 :  -1.1556252662136521
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.4054746004152756
cost at iteration  12 :  -1.1558537564268136
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.3831978279986936
cost at iteration  13 :  -1.1559568694538278
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.3612741424249144
cost at iteration  14 :  -1.156152895177697
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.3396979472674797
cost at iteration  15 :  -1.156163212447893
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.1866173613229614
cost at iteration  16 :  -1.1563069254537521
reducing step size
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0510285285313932
cost at iteration  17 :  -1.1563735494124507
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.034369726354171
cost at iteration  18 :  -1.1564005065054814
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0179749661914572
cost at iteration  19 :  -1.156410660717939
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0018400629773228
cost at iteration  20 :  -1.1564510867510738
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9859608979791321
cost at iteration  21 :  -1.15651064882374
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9703334177461629
cost at iteration  22 :  -1.1565853953839436
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9549536330748863
cost at iteration  23 :  -1.1566652270331106
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9398176179906492
cost at iteration  24 :  -1.1567406736299468
reducing step size
reducing step size
reducing step size
step size:  1.027690565272775
cost at iteration  25 :  -1.1567415931350449
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0114016698132016
cost at iteration  26 :  -1.156752769029148
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9953709533466624
cost at iteration  27 :  -1.1567746927196607
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9795943237361178
cost at iteration  28 :  -1.1568044739348984
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9640677537049005
cost at iteration  29 :  -1.156839050894721
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9487872798086778
cost at iteration  30 :  -1.1568739518978017
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9337490014237104
cost at iteration  31 :  -1.1569061440231068
reducing step size
reducing step size
reducing step size
step size:  1.0210545330568275
cost at iteration  32 :  -1.1569107199788788
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0048708187078768
cost at iteration  33 :  -1.1569189782060108
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.988943616231357
cost at iteration  34 :  -1.1569304219331644
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.97326885991409
cost at iteration  35 :  -1.1569442348717438
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9578425484844518
cost at iteration  36 :  -1.1569589035206531
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9426607440909731
cost at iteration  37 :  -1.1569732064699132
reducing step size
reducing step size
reducing step size
step size:  1.0307995236634793
cost at iteration  38 :  -1.156975948558764
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0144613512134133
cost at iteration  39 :  -1.156980232839626
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9983821387966807
cost at iteration  40 :  -1.1569860444980844
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9825577818967535
cost at iteration  41 :  -1.1569932002791807
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.96698424105369
cost at iteration  42 :  -1.1570010762794645
reducing step size
reducing step size
reducing step size
step size:  1.05739726759221
cost at iteration  43 :  -1.157001171518357
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0406375209008738
cost at iteration  44 :  -1.1570020152391787
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0241434161945948
cost at iteration  45 :  -1.1570041949268592
reducing step size
reducing step size
reducing step size
reducing step size
step size:  1.0079107430479106
cost at iteration  46 :  -1.1570078474526788
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9919353577706012
cost at iteration  47 :  -1.1570130270308245
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9762131823499371
cost at iteration  48 :  -1.1570192444424454
reducing step size
reducing step size
reducing step size
reducing step size
step size:  0.9607402034096908
cost at iteration  49 :  -1.1570260548839815
reducing step size
reducing step size
reducing step size
step size:  1.050569412428497
Using SciPy optimize toolbox
ngsglobals.msg_level = 1
mesh.Curve(2)
a =4.0/5.0
b = 2
# element order
order = 1
PHI = VEC.TrialFunction()
PSI = VEC.TestFunction()
gfset.Set((0,0))
# only for new gui
#if scene:
#    scene.setDeformation(True)
#Draw(gfset,mesh,"gfset")
 Curve elements, order = 2
Shape derivative
fX = LinearForm(VEC)
# analytic shape derivative
Bilinear form for shape gradient
Define the bilinear form
\[(\varphi,\psi) \mapsto b_\Omega(\varphi,\psi):= \int_\Omega (\nabla \varphi+\nabla \varphi^\top): \nabla\psi + \varphi\cdot\psi\; dx\]
\[b_\Omega(X,\psi) = DJ(\Omega)(\psi)\quad \text{ for all } \psi\in H^1(\Omega)\]
# Cauchy-Riemann descent CR
CR = False
# bilinear form for gradient
if CR == True:
    gamma = 100
aX.Assemble()
Wrapping the shape function and its gradient
def J(x_):
    gfset.Set((0,0))
    # x_ NumPy vector
    cost_c = Integrate (f, mesh)
    return cost_c
    gfset.Set((0,0))
    # x_ NumPy vector
    fX.Assemble()
    if euclid == True:
        gfX.vec.data = fX.vec
        gfX.vec.data = invaX * fX.vec
Gradient descent and Armijo rule
\[J((\mbox{Id}+\alpha_k X_k)(\Omega_k)) \le J(\Omega_k) - c_1 \alpha_k \|\nabla J(\Omega_k)\|^2,\]
# from scipy.optimize.linesearch import line_search_armijo
# try:
#    from scipy.optimize._linesearch import line_search_armijo   # SciPy >= 1.8
# except ImportError:
#    from scipy.optimize.linesearch import line_search_armijo    # older SciPy
def line_search_armijo(f, xk, pk, gfk, old_fval, c1=1e-4, alpha0=1.0):
    phi0 = f(xk) if old_fval is None else old_fval
    derphi0 = np.dot(gfk, pk)
    alpha, nfev = alpha0, 0
    for _ in range(30):
        fval = f(xk + alpha * pk); nfev += 1
        if fval <= phi0 + c1 * alpha * derphi0:
            return alpha, nfev, fval
        alpha *= 0.5
    return None, nfev, phi0
    xk_ = np.copy(x0)
    # maximal iteration
    it_max = 50
    nfval_total = 0
    print('\n')
    for i in range(1, it_max):
        # compute descent direction
        pk = -gradJ_(xk_)
        # eval cost function
        fold = J_(xk_)
        # perform armijo stepsize
        if CR == True:
            alpha0 = 0.15
            alpha0 = 0.11
        nfval_total += nfval
        xk_ = xk_ - step * grad_xk
            print('\n'+'{:<20}  {:<12} '.format("##################################", ""))
            print('{:<20}  {:<12} '.format("### success - accuracy reached ###", ""))
            print('{:<20}  {:<12} '.format("##################################", ""))
            print('{:<20}  {:<12} '.format("gradient norm: ", np.linalg.norm(gradJ_(xk_))))
            print('{:<20}  {:<12} '.format("n evals f: ", nfval_total))
            print('{:<20}  {:<12} '.format("f val: ", fold) + '\n')
            break
        elif i == it_max-1:
            print('\n'+'{:<20}  {:<12} '.format("#######################", ""))
            print('{:<20}  {:<12} '.format("### maxiter reached ###", ""))
            print('{:<20}  {:<12} '.format("#######################", ""))
Now we are ready to run our first optimisation algorithm:
gfset.vec[:]=0
Iteration  1 | Cost  63.58544060454411 | grad norm 441.59290658661826
Iteration  2 | Cost  -0.7382545763570404 | grad norm 4.795270097704353
Iteration  3 | Cost  -0.7857727667400647 | grad norm 4.810253357263973
Iteration  4 | Cost  -0.8340100892582167 | grad norm 4.7781422950709524
Iteration  5 | Cost  -0.8819829476436117 | grad norm 4.690302282301013
Iteration  6 | Cost  -0.9285214898272772 | grad norm 4.539798263167299
Iteration  7 | Cost  -0.9723556895806467 | grad norm 4.322976857862463
Iteration  8 | Cost  -1.0122531578877778 | grad norm 4.04105181526844
Iteration  9 | Cost  -1.0471883778786129 | grad norm 3.7012245498531766
Iteration  10 | Cost  -1.0765044436655513 | grad norm 3.3168858328914888
Iteration  11 | Cost  -1.1000162626592422 | grad norm 2.90620275515686
Iteration  12 | Cost  -1.1180150904153776 | grad norm 2.489788164133281
Iteration  13 | Cost  -1.1311719155347602 | grad norm 2.0875804970132057
Iteration  14 | Cost  -1.1403746530625058 | grad norm 1.7159371235339929
Iteration  15 | Cost  -1.1465562098318838 | grad norm 1.3857186789181648
Iteration  16 | Cost  -1.1505622552842778 | grad norm 1.102472078023223
Iteration  17 | Cost  -1.1530807674166723 | grad norm 0.866439030185641
Iteration  18 | Cost  -1.1546254458650944 | grad norm 0.6744733131571017
Iteration  19 | Cost  -1.1555550744962944 | grad norm 0.5214023587336147
Iteration  20 | Cost  -1.1561072737628189 | grad norm 0.40125724712232436
Iteration  21 | Cost  -1.1564329926583796 | grad norm 0.308126478478436
Iteration  22 | Cost  -1.1566250729528906 | grad norm 0.2366460842080754
Iteration  23 | Cost  -1.1567392218240353 | grad norm 0.18221681468364992
Iteration  24 | Cost  -1.1568082482769888 | grad norm 0.14104424517287406
Iteration  25 | Cost  -1.1568512129825606 | grad norm 0.11008000257674168
Iteration  26 | Cost  -1.1568790835671523 | grad norm 0.08691942912250125
Iteration  27 | Cost  -1.1568981341123956 | grad norm 0.06968543512602446
Iteration  28 | Cost  -1.1569119439709792 | grad norm 0.05692156240844237
Iteration  29 | Cost  -1.1569225568515864 | grad norm 0.04750014325185843
Iteration  30 | Cost  -1.1569311460615876 | grad norm 0.04055031381079014
Iteration  31 | Cost  -1.1569383917279337 | grad norm 0.03540437114759005
Iteration  32 | Cost  -1.1569446953786282 | grad norm 0.031557817079965717
Iteration  33 | Cost  -1.1569502999928776 | grad norm 0.028637497719290885
Iteration  34 | Cost  -1.1569553580085294 | grad norm 0.026373993717594465
Iteration  35 | Cost  -1.1569599695029125 | grad norm 0.024577086183132948
Iteration  36 | Cost  -1.1569642036044874 | grad norm 0.0231147466962476
Iteration  37 | Cost  -1.156968110947085 | grad norm 0.021896245450960097
Iteration  38 | Cost  -1.156971730608716 | grad norm 0.020859390544323685
Iteration  39 | Cost  -1.1569750939270342 | grad norm 0.01996136241899197
Iteration  40 | Cost  -1.1569782269881672 | grad norm 0.019172877193450594
Iteration  41 | Cost  -1.1569811514952681 | grad norm 0.01847191228418588
Iteration  42 | Cost  -1.1569838871549833 | grad norm 0.017845413165404448
Iteration  43 | Cost  -1.1569864496512072 | grad norm 0.017278988193843978
Iteration  44 | Cost  -1.1569888554425791 | grad norm 0.016765650640741446
Iteration  45 | Cost  -1.1569911182298938 | grad norm 0.016298795918092707
Iteration  46 | Cost  -1.1569932500627205 | grad norm 0.015873146903417616
Iteration  47 | Cost  -1.1569952619910002 | grad norm 0.015485165897309274
Iteration  48 | Cost  -1.1569971633976457 | grad norm 0.015129700903153938
Iteration  49 | Cost  -1.156998963623071 | grad norm 0.014804371462622071
gradient norm:        0.014506461247563532
n evals f:            49
f val:                -1.156998963623071
L-BFGS method
In the BFGS method we replace
\[b_\Omega(X,\varphi) = \nabla J(\Omega)(\varphi)\]
by
\[H_\Omega(X,\varphi) = \nabla J(\Omega)(\varphi),\]
\[\begin{split}\begin{array}{rl} \text{ solve }\quad B_nX_k & = \nabla J(\Omega_k) \\ & \\ \text{ update } \quad s_k & := -\alpha_k p_k \\ y_k & := \nabla J_h(\Omega_{k+1}) - \nabla J_h(\Omega_k) \\ B_{k+1} &:= B_k + \frac{y_k\otimes y_k}{y_k\cdot s_k} + \frac{B_ks_k\otimes B_ks_k}{B_ky_k\cdot B_ks_k}. \end{array}\end{split}\]
# options for optimiser
options = {"maxiter":1000,
              "gtol":1e-10}
  message: CONVERGENCE: RELATIVE REDUCTION OF F <= FACTR*EPSMCH
  success: True
   status: 0
      fun: -1.1571165964142893
        x: [-5.237e-04  6.989e-01 ... -1.488e-03  4.596e-03]
      nit: 22
      jac: [ 3.524e-06 -4.362e-05 ...  4.314e-06 -5.087e-06]
     nfev: 155
     njev: 155
Improving mesh quality via Cauchy-Riemann equations
\[\int_{\Omega} \nabla X : \nabla \varphi + X\cdot \varphi\; dx = DJ(\Omega)(\varphi) \quad \forall \varphi \in H^1(\Omega)^d.\]
\[\int_{\Omega} \nabla X : \nabla \varphi + X\cdot \varphi + \color{red}\gamma \color{red}B\color{red}X\cdot \color{red}B\color{red}\varphi\;dx = DJ(\Omega)(\varphi) \; \forall \varphi \in H^1(\Omega)^d,\]
\[\begin{split}B := \begin{pmatrix} -\partial_x & \partial_y \\ \partial_y & \partial_x \end{pmatrix}\end{split}\]
alpha = 100
