This page was generated from unit-11.2-bem-Laplace/Laplace_NtD_direct.ipynb.
11.2.4. Neumann Laplace Direct Method¶
keys: homogeneous Neumann bvp, hypersingular operator, unknown Dirichlet data
from ngsolve.bem import *
Consider the Neumann boundary value problem
The unique solution \(u\in H^1(\Omega)\) can be written in the following form (representation forumula)
Let’s carefully apply the Neumann trace \(\gamma_1\) to the representation formula and solve the resulting boundary integral equation for the Dirichlet trace \(u_0\) of \(u\) by discretisation of the following variational formulation:
sp = Glue(Sphere( (0,0,0), 1).faces)
mesh = Mesh( OCCGeometry(sp).GenerateMesh(maxh=0.2)).Curve(2)
Define conforming finite element spaces for \(H^{\frac12}(\Gamma)\) and \(H^{-\frac12}(\Gamma)\) respectively:
fesL2 = SurfaceL2(mesh, order=2, dual_mapping=False)
u,v = fesL2.TnT()
fesH1 = H1(mesh, order=2, definedon=mesh.Boundaries(".*"))
uH1,vH1 = fesH1.TnT()
print ("ndofL2 = ", fesL2.ndof, "ndof H1 = ", fesH1.ndof)
ndofL2 = 4332 ndof H1 = 1446
Project the given Neumann data \(u_1\) in finite element space and have a look at the boundary data:
n = specialcf.normal(3)
u1 = GridFunction(fesL2)
u1.Interpolate(graduexa*n, definedon=mesh.Boundaries(".*"))
Draw (u1, mesh, draw_vol=False, order=3);
The discretisation of the variational formulation leads to a system of linear equations, ie
where the linear operators are as follows
\(\mathrm{D}\) is the hypersingular operator and the stabilisation \((\mathrm D + \mathrm{S})\) is regular and symmetric.
\(\mathrm{M}\) is a mass matrix.
\(\mathrm{K}'\) is the adjoint double layer operator.
The stabilisation matrix \(S\) is needed to cope with the kernel of the hypersingular operator. The following stabilisation matrix is used here:
where \(v_i, v_j\) being \(H^{\frac12}(\Gamma)\)-conforming shape functions.
vH1m1 = LinearForm(vH1*1*ds(bonus_intorder=3)).Assemble()
S = (BaseMatrix(Matrix(vH1m1.vec.Reshape(1))))@(BaseMatrix(Matrix(vH1m1.vec.Reshape(fesH1.ndof))))
Now we assemble the stabilised system matrix and the right hand side and solve for the Dirichlet data \(u_0\) with an iterative solver:
u0 = GridFunction(fesH1)
pre = BilinearForm(uH1*vH1*ds).Assemble().mat.Inverse(freedofs=fesH1.FreeDofs())
D = LaplaceSL(curl(uH1)*ds)*curl(vH1)*ds
M = BilinearForm( v.Trace() * uH1 * ds(bonus_intorder=3)).Assemble()
Kt = LaplaceDL(u*ds)*vH1*ds
rhs = ( (0.5 * M.mat.T - Kt.mat) * u1.vec ).Evaluate()
CG(mat=D.mat+S, pre=pre, rhs=rhs, sol=u0.vec, tol=1e-8, maxsteps=200, printrates=True)
CG iteration 1, residual = 0.6734142037183317
CG iteration 2, residual = 0.3570528457830083
CG iteration 3, residual = 0.20848548270382045
CG iteration 4, residual = 0.16306912759255537
CG iteration 5, residual = 0.12859404470981542
CG iteration 6, residual = 0.09481227871503588
CG iteration 7, residual = 0.06094155655965166
CG iteration 8, residual = 0.048209047011086886
CG iteration 9, residual = 0.029789833344009073
CG iteration 10, residual = 0.021210630931962966
CG iteration 11, residual = 0.013531583103050077
CG iteration 12, residual = 0.008288865888000567
CG iteration 13, residual = 0.005443370731788138
CG iteration 14, residual = 0.0032123119498690044
CG iteration 15, residual = 0.002038798111385328
CG iteration 16, residual = 0.0011895561324850436
CG iteration 17, residual = 0.0006849499664993714
CG iteration 18, residual = 0.0004044844407218265
CG iteration 19, residual = 0.00022080858713688795
CG iteration 20, residual = 0.00012690263045003612
CG iteration 21, residual = 6.911745077422168e-05
CG iteration 22, residual = 3.73738635867083e-05
CG iteration 23, residual = 1.9762015573687717e-05
CG iteration 24, residual = 9.964140413972853e-06
CG iteration 25, residual = 4.935087608718908e-06
CG iteration 26, residual = 2.4799111610470306e-06
CG iteration 27, residual = 1.1906224336618002e-06
CG iteration 28, residual = 5.712437356341714e-07
CG iteration 29, residual = 2.6237257169799506e-07
CG iteration 30, residual = 1.209626355095927e-07
CG iteration 31, residual = 5.496258065846073e-08
CG iteration 32, residual = 2.740345183862893e-08
CG iteration 33, residual = 1.844642825070852e-08
CG iteration 34, residual = 1.855120591227783e-08
CG iteration 35, residual = 2.132613024444208e-08
CG iteration 36, residual = 1.5929333011854455e-08
CG iteration 37, residual = 7.84674153724904e-09
CG iteration 38, residual = 3.459785061065297e-09
Let’s have a look at the numerical and exact Dirichlet data and compare them quantitatively:
Draw (u0, mesh, draw_vol=False, order=3);
u0exa = GridFunction(fesH1)
u0exa.Interpolate (uexa, definedon=mesh.Boundaries(".*"))
Draw (u0exa, mesh, draw_vol=False, order=3);
print ("L2 error of surface gradients =", sqrt (Integrate ( (grad(u0exa)-grad(u0))**2, mesh, BND)))
L2 error of surface gradients = 0.0044523804511488
