VTK - Output
Example 1: single solution output
f += x*fes.TestFunction()*dx
vtk.Do()
'vtk_example1'
!ls -lh vtk_example1*
-rw-rw-r-- 1 root root 303K Dec 22 22:48 vtk_example1.png
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example1.vtu
a33a78da697144cb9dca097d5364c789
Example 2: Series of data
t = Parameter(0)
coef = sin(4*(x+y+t))
vtkout.Do(time = 0.0)
for i in range(20):
    t.Set((i+1)/20)
    vtkout.Do(time = (i+1)/20.0)
ls -lh vtk_example2*
-rw-rw-r-- 1 root root 350K Dec 22 22:48 vtk_example2.png
-rw-r--r-- 1 root root 1.4K Dec 22 22:53 vtk_example2.pvd
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00001.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00002.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00003.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00004.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00005.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00006.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00007.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00008.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00009.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00010.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00011.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00012.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00013.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00014.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00015.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00016.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00017.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00018.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00019.vtu
-rw-r--r-- 1 root root  36K Dec 22 22:53 vtk_example2_step00020.vtu
  • We obtained 21 .vtu-files corresponding to the 21 Do-calls.
  • Only the first Do-call does not have an additional suffix, while later calls append the _step...-suffix.
  • Furthermore there is a .pvd file which bundles the individual files and associates them to the provided time stamps (if provided):
!cat vtk_example2.pvd
<?xml version="1.0"?>
<Collection>
</Collection>
</VTKFile>
83871b2a391c4a878034430a864677ea
Further options
  • VTKOutput(..., subdivision=i) refines the mesh (locally and only temporarily) as often as i. Note that when opened with ParaView the visualized mesh no longer coincides with your computational mesh.
  • VTKOutput(..., only_element=i) puts only the data of one selected element out. This can be interesting for basis function visualization or alike.
  • VTKOutput(..., floatsize=fs) where fs is either "single" or "double" decides on the precision of the output. Default is "double". Using "single" can significantly reduce the used disk space.
  • ....Do(time=t) adds the time stamp t to the meta-file if a series of outputs is used.
  • ....Do(vb=vb) allows you to switch from volume mesh output (vb=VOL, default) to surface mesh output (vb=BND)
  • ....Do(drawelems=els) allows you to only write a submesh of the underlying mesh where the corresponding set of elements is prescribed by the BitArray els.
help(VTKOutput)
 |  Method resolution order:
 |      VTKOutput
 |      builtins.object
 |  Methods defined here:
 |  Do(...)
 |      Do(*args, **kwargs)
 |      Overloaded function.
 |      1. Do(self: ngsolve.comp.VTKOutput, time: float = -1, vb: ngsolve.comp.VorB = <VorB.VOL: 0>) -> str
 |      Write mesh and fields to file. When called several times on the same object
 |      an index is added to the output file name. A meta file (.pvd) is written
 |      (unless in legacy mode).
 |      Returns string of the output filename.
 |      Parameters:
 |      time :
 |        associate a time to the current output
 |      vb: VOL_or_BND (default VOL)
 |        defines if output is done on the volume (VOL) or surface mesh (BND).
 |      2. Do(self: ngsolve.comp.VTKOutput, time: float = -1, vb: ngsolve.comp.VorB = <VorB.VOL: 0>, drawelems: pyngcore.pyngcore.BitArray) -> str
 |      Parameters:
 |      time :
 |        associate a time to the current output (default: output counter)
 |      drawelems: BitArray
 |        defines the submesh (set of elements) that are (only) used for drawing.
 |  __init__(...)
 |      __init__(self: ngsolve.comp.VTKOutput, ma: ngsolve.comp.Mesh, coefs: list = [], names: list = [], filename: str = 'vtkout', subdivision: int = 0, only_element: int = -1, floatsize: str = 'double', legacy: bool = False, order: int = 1) -> None
 |      VTK output class. Allows to put mesh and field information of several CoefficientFunctions into a VTK file.
 |      (Can be used by independent visualization software, e.g. ParaView).
 |      When run in parallel, rank 0 stores no vtk output, but writes the pvd-file that links all parallel
 |      output together.
 |      Parameters:
 |      ma : ngsolve mesh
 |        mesh (Note: if a deformation is set, the output will be w.r.t. the deformed state of the mesh)
 |      coefs: list of CoefficientFunctions
 |        list of CFs that are stored as fields in the Paraview output
 |      names : list of strings
 |        labels for the fields that are put in the output file
 |      filename : string (default: \"output\")
 |        name of the output file ( .vtu file ending is added or .vtk file ending is added (legacy mode) ).
 |        If run in parallel, the suffix \"_procxyz\" is added (xyz a number).
 |        If output is written several times, the ending \"_stepxyz\" is added (xyz a counter).
 |        If run in parallel or the output is called several times a meta file with ending .pvd is also generated for convenience.
 |      subdivision : int
 |        Number of subdivision (bisections in each direction) that are applied
 |        (Note that only vertex values are stored otherwise rendering the output information piecewise linear only)
 |      only_element : int
 |        only work on one specific element (default: -1 which means `draw all elements`)
 |      floatsize : string in {\"single\", \"double\" }   object
 |        defines the precision of the output data (default is \"double\", \"single\" can be used to reduce output)
 |      legacy : bool (default: False)
 |        defines if legacy-VTK output shall be used
 |      order : int (default: 1)
 |        allowed values: 1,2
 |  Static methods inherited from pybind11_builtins.pybind11_object:
 |  __new__(*args, **kwargs) from pybind11_builtins.pybind11_type
 |      Create and return a new object.  See help(type) for accurate signature.
