VTK - Output¶
f += x*fes.TestFunction()*dx
vtk.Do()
'vtk_example1'
!ls -lh vtk_example1*
-rw-rw-r-- 1 root root 303K Sep 24 20:17 vtk_example1.png
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example1.vtu
Example 2: Series of data¶
t = Parameter(0)
coef = sin(4*(x+y+t))
vtkout.Do(time = 0.0)
for i in range(20):
t.Set((i+1)/20)
vtkout.Do(time = (i+1)/20.0)
ls -lh vtk_example2*
-rw-rw-r-- 1 root root 350K Sep 24 20:17 vtk_example2.png
-rw-r--r-- 1 root root 1.4K Sep 24 20:27 vtk_example2.pvd
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00001.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00002.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00003.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00004.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00005.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00006.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00007.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00008.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00009.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00010.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00011.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00012.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00013.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00014.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00015.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00016.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00017.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00018.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00019.vtu
-rw-r--r-- 1 root root 36K Sep 24 20:27 vtk_example2_step00020.vtu
We obtained 21
!cat vtk_example2.pvd
<?xml version="1.0"?>
<Collection>
</Collection>
</VTKFile>
Further options¶
help(VTKOutput)
| Method resolution order:
| VTKOutput
| builtins.object
| Methods defined here:
| Do(...)
| Do(*args, **kwargs)
| Overloaded function.
| (unless in legacy mode).
| Parameters:
| time :
| Parameters:
| time :
| drawelems: BitArray
| __init__(...)
| output together.
| Parameters:
| ma : ngsolve mesh
| names : list of strings
| subdivision : int
| only_element : int
| order : int (default: 1)
| allowed values: 1,2
| __new__(*args, **kwargs) from pybind11_builtins.pybind11_type
