# Visualisation
importing ngsxfem-2.1.2301
We generate a background mesh
Draw(mesh, 0, 0)
nr_ls = len(level_sets)
To integrate, we still use the function Integrate. In the multiple level set context, the input to the dCut(levelset, domain_type, order) is very similar to the single level set setting. Here, * the levelset argument must be a tuple of the P1-GridFunction level set functions and * the domain_type can be a * tuple({NEG, POS, IF}) of the same length as the levelset tuple which describes the domain whith respect each level set function * list(tuple) of such tuples
when the domain is described via (the union of) multiple regions * DomainTypeArray (see xfem.mlset convininece layer below). * the remaining (keyword) arguments remain as in the single level set case
error = abs(area - 0.5)
from xfem.mlset import *
DomainTypeArray?
domain.as_list
domain.codim
Geometrical features¶
Operator |
Operation |
Remark |
Returns a |
Returns a |
Returns a |
Note: - For | and &, the tuples in each DomainTypeArray must have the same length. - The operators &= and |= are also available.
outside_triangle = ~triangle
outside_triangle.as_list
dta1.as_list
dta2.as_list
dta3.as_list
boundary.as_list
corners = boundary.Boundary()
corners.as_list
Visualisation Tools¶
for i in range(2):
lset_p1.Update()
<xfem.DummyScene at 0x7eff698877c0>
DrawDC(boundary.IndicatorSmoothed(level_sets_p1, 0.06), -3.5, 2.5, mesh,
"boundary_indicator")
DrawDC(corners.IndicatorSmoothed(level_sets_p1, 0.06), -3.5, 2.5, mesh, "boundary_indicator")
Further details are discussed in the extended version of this jupyter tutorial here.
