In this tutorial we make use of ipywidgets. You can (in the ideal case) simply install them with executing the next cell. You will however need to restart jupyter afterwards (unless you have it installed already).
!pip3 install --user ipywidgets
!jupyter nbextension enable --py widgetsnbextension
Requirement already satisfied: ipywidgets in /usr/local/lib/python3.10/dist-packages (8.0.6)
Requirement already satisfied: traitlets>=4.3.1 in /usr/local/lib/python3.10/dist-packages (from ipywidgets) (5.9.0)
Requirement already satisfied: widgetsnbextension~=4.0.7 in /usr/local/lib/python3.10/dist-packages (from ipywidgets) (4.0.7)
Requirement already satisfied: ipython>=6.1.0 in /usr/local/lib/python3.10/dist-packages (from ipywidgets) (8.14.0)
Requirement already satisfied: jupyterlab-widgets~=3.0.7 in /usr/local/lib/python3.10/dist-packages (from ipywidgets) (3.0.7)
Requirement already satisfied: ipykernel>=4.5.1 in /usr/local/lib/python3.10/dist-packages (from ipywidgets) (6.23.3)
Requirement already satisfied: comm>=0.1.1 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (0.1.3)
Requirement already satisfied: pyzmq>=20 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (25.1.0)
Requirement already satisfied: tornado>=6.1 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (6.3.2)
Requirement already satisfied: matplotlib-inline>=0.1 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (0.1.6)
Requirement already satisfied: jupyter-core!=5.0.*,>=4.12 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (5.3.1)
Requirement already satisfied: debugpy>=1.6.5 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (1.6.7)
Requirement already satisfied: packaging in /usr/lib/python3/dist-packages (from ipykernel>=4.5.1->ipywidgets) (21.3)
Requirement already satisfied: jupyter-client>=6.1.12 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (8.3.0)
Requirement already satisfied: psutil in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (5.9.5)
Requirement already satisfied: nest-asyncio in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (1.5.6)
Requirement already satisfied: pygments>=2.4.0 in /usr/lib/python3/dist-packages (from ipython>=6.1.0->ipywidgets) (2.11.2)
Requirement already satisfied: jedi>=0.16 in /usr/local/lib/python3.10/dist-packages (from ipython>=6.1.0->ipywidgets) (0.18.2)
Requirement already satisfied: pexpect>4.3 in /usr/local/lib/python3.10/dist-packages (from ipython>=6.1.0->ipywidgets) (4.8.0)
Requirement already satisfied: decorator in /usr/lib/python3/dist-packages (from ipython>=6.1.0->ipywidgets) (4.4.2)
Requirement already satisfied: stack-data in /usr/local/lib/python3.10/dist-packages (from ipython>=6.1.0->ipywidgets) (0.6.2)
Requirement already satisfied: pickleshare in /usr/local/lib/python3.10/dist-packages (from ipython>=6.1.0->ipywidgets) (0.7.5)
Requirement already satisfied: backcall in /usr/local/lib/python3.10/dist-packages (from ipython>=6.1.0->ipywidgets) (0.2.0)
Requirement already satisfied: prompt-toolkit!=3.0.37,<3.1.0,>=3.0.30 in /usr/local/lib/python3.10/dist-packages (from ipython>=6.1.0->ipywidgets) (3.0.38)
Requirement already satisfied: parso<0.9.0,>=0.8.0 in /usr/local/lib/python3.10/dist-packages (from jedi>=0.16->ipython>=6.1.0->ipywidgets) (0.8.3)
Requirement already satisfied: python-dateutil>=2.8.2 in /usr/local/lib/python3.10/dist-packages (from jupyter-client>=6.1.12->ipykernel>=4.5.1->ipywidgets) (2.8.2)
Requirement already satisfied: platformdirs>=2.5 in /usr/local/lib/python3.10/dist-packages (from jupyter-core!=5.0.*,>=4.12->ipykernel>=4.5.1->ipywidgets) (3.8.0)
Requirement already satisfied: ptyprocess>=0.5 in /usr/local/lib/python3.10/dist-packages (from pexpect>4.3->ipython>=6.1.0->ipywidgets) (0.7.0)
Requirement already satisfied: wcwidth in /usr/local/lib/python3.10/dist-packages (from prompt-toolkit!=3.0.37,<3.1.0,>=3.0.30->ipython>=6.1.0->ipywidgets) (0.2.6)
Requirement already satisfied: asttokens>=2.1.0 in /usr/local/lib/python3.10/dist-packages (from stack-data->ipython>=6.1.0->ipywidgets) (2.2.1)
Requirement already satisfied: pure-eval in /usr/local/lib/python3.10/dist-packages (from stack-data->ipython>=6.1.0->ipywidgets) (0.2.2)
Requirement already satisfied: executing>=1.2.0 in /usr/local/lib/python3.10/dist-packages (from stack-data->ipython>=6.1.0->ipywidgets) (1.2.0)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from asttokens>=2.1.0->stack-data->ipython>=6.1.0->ipywidgets) (1.16.0)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Enabling notebook extension jupyter-js-widgets/extension...
- Validating: OK
import time
ngsglobals.msg_level = 1
importing ngsxfem-2.1.2301
# Space finite element order
order = 1
# Time finite element order
k_t = 1
# Final simulation time
tend = 1.0
# Time step
delta_t = 1 / 32
def dt(u):
tnew = 0
told = Parameter(0)
t = told + delta_t * tref
tfe = ScalarTimeFE(k_t)
gfu = GridFunction(st_fes)
u, v = st_fes.TnT()
The exact solution is as stated above. With the TimeSlider_Draw we can visualize the function as a function in space for different values of tref
TimeSlider_Draw(sin(pi * tref) * sin(pi * x)**2 * sin(pi * y)**2,mesh,"u_exact", autoscale=False,min=0,max=1)
#In order to draw the function u_exact for t in [0,1] instead of t in [0, delta t], we rewrite the function
<function xfem.TimeSlider_Draw.<locals>.UpdateTime(time)>
The right-hand side \(f\) is calculated accordingly and can also be visualized similarly:
coeff_f = coeff_f.Compile()
TimeSlider_Draw(coeff_f,mesh,"coeff_f", autoscale=False,min=-2,max=8)
Warning: differentiationg by a variable not marked as Variable,
might be optimized out. Call MakeVariable for differentiation CF
dxold = dmesh(mesh, tref=0)
dxnew = dmesh(mesh, tref=1)
Here, dxt corresponds to $ \intQ :nbsphinx-math:`cdot `d(x,t) = :nbsphinx-math:`int`{t{n-1}}{t^n} \int_{\Omega} \cdot `d(x,t)$ whereas ``dxold` and dxnew are spatial integrals on \(\Omega\) with however fixed reference time values 0 or 1 for the evaluation of space-time functions. With those, we can write the variational formulation as: Find
\(u \in W_h = V_h \times \mathcal{P}^1([t^{n-1},t^n])\) so that
a += u * v * dxold
f = LinearForm(st_fes)
f += coeff_f * v * dxt
f += u_last * v * dxold
told.Set(0.)
gfu.vec.data = ainv * f.vec
check type <class 'ngsolve.comp.GridFunction'>
Draw (gfut, mesh, interpolate_multidim=True, animate=True, deformation=True)
