In this tutorial we make use of ipywidgets. You can (in the ideal case) simply install them with executing the next cell. You will however need to restart jupyter afterwards.
!pip3 install --user ipywidgets
!jupyter nbextension enable --py widgetsnbextension
Requirement already satisfied: ipywidgets in /usr/local/lib/python3.10/dist-packages (8.0.6)
Requirement already satisfied: ipython>=6.1.0 in /usr/local/lib/python3.10/dist-packages (from ipywidgets) (8.14.0)
Requirement already satisfied: ipykernel>=4.5.1 in /usr/local/lib/python3.10/dist-packages (from ipywidgets) (6.23.3)
Requirement already satisfied: traitlets>=4.3.1 in /usr/local/lib/python3.10/dist-packages (from ipywidgets) (5.9.0)
Requirement already satisfied: widgetsnbextension~=4.0.7 in /usr/local/lib/python3.10/dist-packages (from ipywidgets) (4.0.7)
Requirement already satisfied: jupyterlab-widgets~=3.0.7 in /usr/local/lib/python3.10/dist-packages (from ipywidgets) (3.0.7)
Requirement already satisfied: nest-asyncio in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (1.5.6)
Requirement already satisfied: debugpy>=1.6.5 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (1.6.7)
Requirement already satisfied: jupyter-client>=6.1.12 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (8.3.0)
Requirement already satisfied: psutil in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (5.9.5)
Requirement already satisfied: comm>=0.1.1 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (0.1.3)
Requirement already satisfied: matplotlib-inline>=0.1 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (0.1.6)
Requirement already satisfied: jupyter-core!=5.0.*,>=4.12 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (5.3.1)
Requirement already satisfied: packaging in /usr/lib/python3/dist-packages (from ipykernel>=4.5.1->ipywidgets) (21.3)
Requirement already satisfied: pyzmq>=20 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (25.1.0)
Requirement already satisfied: tornado>=6.1 in /usr/local/lib/python3.10/dist-packages (from ipykernel>=4.5.1->ipywidgets) (6.3.2)
Requirement already satisfied: backcall in /usr/local/lib/python3.10/dist-packages (from ipython>=6.1.0->ipywidgets) (0.2.0)
Requirement already satisfied: pygments>=2.4.0 in /usr/lib/python3/dist-packages (from ipython>=6.1.0->ipywidgets) (2.11.2)
Requirement already satisfied: decorator in /usr/lib/python3/dist-packages (from ipython>=6.1.0->ipywidgets) (4.4.2)
Requirement already satisfied: pexpect>4.3 in /usr/local/lib/python3.10/dist-packages (from ipython>=6.1.0->ipywidgets) (4.8.0)
Requirement already satisfied: stack-data in /usr/local/lib/python3.10/dist-packages (from ipython>=6.1.0->ipywidgets) (0.6.2)
Requirement already satisfied: prompt-toolkit!=3.0.37,<3.1.0,>=3.0.30 in /usr/local/lib/python3.10/dist-packages (from ipython>=6.1.0->ipywidgets) (3.0.38)
Requirement already satisfied: jedi>=0.16 in /usr/local/lib/python3.10/dist-packages (from ipython>=6.1.0->ipywidgets) (0.18.2)
Requirement already satisfied: pickleshare in /usr/local/lib/python3.10/dist-packages (from ipython>=6.1.0->ipywidgets) (0.7.5)
Requirement already satisfied: parso<0.9.0,>=0.8.0 in /usr/local/lib/python3.10/dist-packages (from jedi>=0.16->ipython>=6.1.0->ipywidgets) (0.8.3)
Requirement already satisfied: python-dateutil>=2.8.2 in /usr/local/lib/python3.10/dist-packages (from jupyter-client>=6.1.12->ipykernel>=4.5.1->ipywidgets) (2.8.2)
Requirement already satisfied: platformdirs>=2.5 in /usr/local/lib/python3.10/dist-packages (from jupyter-core!=5.0.*,>=4.12->ipykernel>=4.5.1->ipywidgets) (3.8.0)
Requirement already satisfied: ptyprocess>=0.5 in /usr/local/lib/python3.10/dist-packages (from pexpect>4.3->ipython>=6.1.0->ipywidgets) (0.7.0)
Requirement already satisfied: wcwidth in /usr/local/lib/python3.10/dist-packages (from prompt-toolkit!=3.0.37,<3.1.0,>=3.0.30->ipython>=6.1.0->ipywidgets) (0.2.6)
Requirement already satisfied: asttokens>=2.1.0 in /usr/local/lib/python3.10/dist-packages (from stack-data->ipython>=6.1.0->ipywidgets) (2.2.1)
Requirement already satisfied: pure-eval in /usr/local/lib/python3.10/dist-packages (from stack-data->ipython>=6.1.0->ipywidgets) (0.2.2)
Requirement already satisfied: executing>=1.2.0 in /usr/local/lib/python3.10/dist-packages (from stack-data->ipython>=6.1.0->ipywidgets) (1.2.0)
Requirement already satisfied: six in /usr/lib/python3/dist-packages (from asttokens>=2.1.0->stack-data->ipython>=6.1.0->ipywidgets) (1.16.0)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
Enabling notebook extension jupyter-js-widgets/extension...
- Validating: OK
Literature:¶
ngsglobals.msg_level = 1
#import netgen.gui
importing ngsxfem-2.1.2301
# DISCRETIZATION PARAMETERS:
i = 3
n_steps = 2**i
space_refs = i
# Polynomial order in time
k_t = 2
# Polynomial order in space
k_s = k_t
lset_order_time = k_t
# Integration order in time
time_order = 2 * k_t
# Time stepping parameters
tstart = 0
tend = 0.5
maxh = 0.5
# Ghost-penalty parameter
gamma = 0.05
# Outer domain:
rect = SplineGeometry()
for j in range(space_refs):
ngmesh.Refine()
\(\hat{t}\) is the
told = Parameter(tstart)
t = told + delta_t * tref
# Level set geometry
R = 0.5
# Convection velocity:
# Level set
r = sqrt(x**2 + (y - rho)**2)
levelset = r - R
# Diffusion coefficient
alpha = 1
# Solution
# R.h.s.
coeff_f = (u_exact.Diff(t)
Warning: differentiationg by a variable not marked as Variable,
might be optimized out. Call MakeVariable for differentiation CF
A View on the time-dependent level set function¶
r_one_timestep = sqrt(x**2 + (y - (1 / (pi)) * sin(2 * pi * tref))**2)
TimeSlider_Draw(levelset_one_timestep,mesh,autoscale=False,min=-0.02,max=0.02,deformation=True)
<function xfem.TimeSlider_Draw.<locals>.UpdateTime(time)>
u_exact_one_timestep = cos(pi * r_one_timestep / R) * sin(pi * t)
TimeSlider_DrawDC(levelset_one_timestep,u_exact_one_timestep,0,mesh)
<function xfem.TimeSlider_DrawDC.<locals>.UpdateTime(time)>
Space-Time finite elements¶
tfe = ScalarTimeFE(k_t)
st_fes = tfe * fes1
In order to achieve higher order accuracy in space, a variant of the isoparametric mapping introduced in 3 is applied.
Literature:¶
order_time=lset_order_time,
threshold=0.5,
discontinuous_qn=True)
def UpdateTimeSlabGeometry():
b=ci.GetElementsOfType(IF))
gfu = GridFunction(st_fes)
scene = DrawDC(lsetadap.levelsetp1[TOP], u_last, 0, mesh, "u_last",
deformation=lsetadap.deformation[TOP])
Variational formulation¶
Upwind DG in time¶
Ghost penalty stabilization¶
:nbsphinx-math:`begin{alignat*}{3} begin{aligned}
&(partial_t u, v)_{Q^{n}} + alpha (nabla{u},nabla{v})_{Q^{n}} + (v, nabla{u} cdot w)_{Q^{n}} + (u_{n−1}^+,v_{n−1}^+)_{Omega^{n−1}} + s_h(u,v) \ &= (f,v)_{Q^{n}} + (u_{n−1}^-,v_{n−1}^+)_{Omega^{n−1}} \
end{aligned} end{alignat*}`
u,v = st_fes.TnT()
The transformation
def dt(u):
facet_restriction=ba_facets)
First integral: $ (\partialt u, v){Q^{n}}$
a += v * w * grad(u) * dQ
a += u * v * dOmold
Fifth integral:
f = LinearForm(st_fes)
f += coeff_f * v * dQ
f += u_last * v * dOmold
setup the new linear system
solve the linear system
def SolveForTimeSlab():
a.Assemble(reallocate=True)
inv = a.mat.Inverse(active_dofs, inverse="umfpack")
update visualization
def FinalizeStep(scene=None):
# * for error evaluation
# Compute error at final time
if scene:
# Set initial values
told.Set(0)
SolveForTimeSlab()
FinalizeStep(scene)
print("")
Play around suggestions:
Further material:
