# the constant pi
# ngsolve stuff
# basic xfem functionality
# visualization stuff
importing ngsxfem-2.1.2301
Interface problem¶
<xfem.DummyScene at 0x7ff478a8f250>
Cut FE spaces¶
composed |
inner |
outer |
VhG = FESpace([Vh,Vh])
ci = CutInfo(mesh, lsetp1)
freedofs = VhG.FreeDofs()
gfu = GridFunction(VhG)
inactive dofs are 0
if not val:
gfu.vec[i] = 0.0
check type <class 'ngsolve.comp.GridFunction'>
gfu.components[0].Set(1)
gfu.components[1].Set(-1)
281 136 256
Nitsche discretization¶
- For the discretization of the interface problem we consider the Nitsche formulation: :nbsphinx-math:`begin{align*}
sum_{i in {+,-}} & left( alpha_i nabla u nabla v right)_{Omega_i} + left( {!!{ - alpha nabla u cdot n }!!}, [![v]!] right)_Gamma + left( [![u]!],{!!{ - alpha nabla v cdot n }!!} right)_Gamma + left( frac{bar{alpha} lambda}{h} [![u]!] , [![v]!] right)_{Gamma} \ = left( f,v right)_{Omega}
end{align*}`
for all \(v \in V_h^\Gamma\).
For this formulation we require: * a suitably defined average operator \(\{ \cdot \} = \kappa_+ (\cdot)|_{\Omega_{+}} + \kappa_- (\cdot)|_{\Omega_{-}}\) * a suitable definition of the normal direction * numerical integration on \(\Omega_{+}^{lin}\), \(\Omega_{-}^{lin}\) and \(\Gamma^{lin}\)
Cut ratio field¶
kappaminus = CutRatioGF(ci)
Normal direction¶
n = Normalize(grad(lsetp1))
Averages and jumps¶
alpha = [1.0,20.0]
u,v = VhG.TnT()
jump_u = u[0] - u[1]
jump_v = v[0] - v[1]
Integrals¶
coef_f = [1,0]
f = LinearForm(VhG)
Assembly¶
<ngsolve.comp.LinearForm at 0x7ff443fd18f0>
def SolveLinearSystem():
gfu.vec[:] = 0
f.vec.data -= a.mat * gfu.vec
SolveLinearSystem()
Higher order accuracy¶
# for isoparametric mapping
mesh.deformation = None
SolveLinearSystem()
XFEM spaces¶
Instead of the CutFEM space
Vhx = XFESpace(Vh,ci)
VhG = FESpace([Vh,Vhx])
original |
after cut |
The space
$u_- = u_h^{std} + $
neg(\(u_h^x\)) and $u_+ = u_h^{std} + $pos(\(u_h^x\))
In the source directory (or on http://www.github.com/ngsxfem/ngsxfem ) you can find in the demos directory a number of more advanced examples (with fewer explanatory comments). These are: * unf_interf_prob.py : Similar to this notebook. The file implements low and high order geometry approximation and gives the choice between a CutFEM and XFEM discretisation. * fictdom.py : Fictitious domain/CutFEM diffusion problem (one domain only) with ghost penalty stabilization. *
fictdom_dg.py : Fictitious domain/CutFEM diffusion problem with a discontiunous Galerkin discretisation and ghost-penalty stabilization. * ficdom_mlset.py : Fictitious domain/CutFEM diffusion problem with a geometry described by multiple level set funcions. * stokesxfem.py : Stokes interface problem with using XFEM and a Nitsche formulation. * tracefem.py or tracefem_scalar.ipynb : A scalar Laplace-Beltrami problem on a level set surface in 3d using
a trace finite element discretization (PDE on the interface only). * lsetgeoms.py : Shows a number of pre-implemented 3d level set geometries. * moving_domain.py : A scalar convection-diffusion problem posed on a moving domain discretised with an Eulerian time-stepping scheme. * spacetime/spacetimeCG_unfitted.py : A scalar unfitted PDE problem on a moving domain, discretized with CG-in-time space-time finite elements. * spacetime/spacetimeDG_unfitted.py : As
spacetimeCG_unfitted.py but with a DG-in-time space-time discretisation. * spacetime/spacetimeDG_fitted.py : A fitted FEM heat equation solved using DG-in-time space-time finite elements. * spacetime/spacetime_vtk.py : Demonstration to generate space-time VTK outputs. * mpi/mpi_nxfem.py : Same problem as unf_interf_prob.py (XFEM + higher order) campatible with MPI parallisation.
