This page was generated from unit-7-optimization/03b_Shape_Derivative_Laplace_FullyAuto.ipynb.
7.5 PDE-Constrained Shape Optimization in NGSolve¶
- We want to solve the PDE-constrained shape optimization problem :nbsphinx-math:`begin{equation}
underset{Omegasubset mathsf{D}}{mbox{min}} ; J(u) := int_Omega |u-u_d|^q ; dx, quad qge 2
- end{equation}` subject to that \((\Omega,u)\) satisfy :nbsphinx-math:`begin{equation}
int_Omega nabla u cdot nabla v ; dx = int_Omega f v ; dx ; quad text{ for all } v in H_0^1(Omega),
end{equation}` where \(\Omega \subset \mathbb R^2\) for given \(u_d, f \in C^1(\mathbb R^2)\).
from ngsolve.solvers import *
ud = x*(1-x)*y*(1-y)
gfp = GridFunction(fes)
- The formula for the shape derivative was derived as the partial derivative of the perturbed Lagrangian (brought back to the original domain): :nbsphinx-math:`begin{align*}
- dmathcal J(Omega; X) = frac{partial}{partial t} left( int_Omega |u - u_d^t|^q ,mbox{det}(F_t) mbox{d} x
int_{Omega} (F_t^{-top}nabla u) cdot (F_t^{-top} nabla p), mbox{det}(F_t) , dx - int_{Omega}f^t p ,mbox{det}(F_t) ,dx right)|_{t=0}
end{align*}` where
\(T_t(x)=x+tX(x)=y\)
\(F_t = DT_t = I+t DX\)
\(u_d^t = u_d \circ T_t\)
\(f^t = f \circ T_t\)
The integrand depends on the parameter \(t\) only via \(F_t\) and \(T_t\). We define the Lagrangian in this form, involving a parameter t that has the value 0.
In order to define the perturbed Lagrangian for a given problem, one needs to know transformation rules of differential operators, e.g.,
for \(u \in H^1\).¶
Since these transformation rules are known by NGSolve for all implemented differential operators, also the step of defining the perturbed Lagrangian can be automated.¶
PHI, X = VEC.TnT()
def EquationFA(u,v):
return ( grad(u)*grad(v)-f*v)*dx
q=6
def CostAutoFA(u):
return (u-ud)**q*dx
def CostAuto2(u):
return CostAutoFA(u)
LagrangianFA = CostAutoFA(gfu) + EquationFA(gfu,gfp)
State equation¶
Equation can also be used to define the bilinear form. The following defines left and right hand side of the PDE in a “BilinearForm”:
u, v = fes.TnT()
aAuto += EquationFA(u,v)
gfu.vec[:]=0
scene_u.Redraw()
Newton iteration 0
err = 0.13042435973102348
Newton iteration 1
err = 1.1032913546772452e-16
Adjoint equation¶
- We set up the adjoint equation :nbsphinx-math:`begin{align*}
mbox{Find } p in H_0^1(Omega): int_Omega nabla w cdot nabla p , mbox dx = - partial_u J(u)(w) quad text{ for all } w in H_0^1(Omega)
- end{align*}` where \(u\) is the solution to the state equation. For \(J(u) = \int_\Omega |u-u_d|^2 \mbox dx\), we get :nbsphinx-math:`begin{align*}
partial_u J(u)(w) = 2 int_Omega (u-u_d)w ,mbox dx.
end{align*}` However, we can also use the Diff(…) command:
p, w = fes.TnT()
fadjoint = LinearForm(fes)
fadjoint += -1*(CostAutoFA(gfu)).Diff(gfu,w)
def SolveAdjointEquation():
rhs = gfp.vec.CreateVector()
gfp.vec.data += update
fadjoint.Assemble()
scene_p.Redraw()
- Denoting the integrand by \(G^{u,p}\), the shape derivative is given by :nbsphinx-math:`begin{align*}
dmathcal J(Omega; X) =& left( left. frac{partial G^{u,p}}{partial t} + frac{d G^{u,p}}{dy} cdot frac{d T_t}{dt}right)rightrvert_{t=0} \ =& left. frac{partial G^{u,p}}{partial t}rightrvert_{t=0} + frac{d G^{u,p}}{dy} cdot X
end{align*}`
dJOmegaAuto = LinearForm(VEC)
dJOmegaAuto += LagrangianFA.DiffShape(X)
b = BilinearForm(VEC)
gfX = GridFunction(VEC)
gfset = GridFunction(VEC)
gfset.Set((0,0))
Draw(gfset,mesh,"gfset")
rhs = gfX.vec.CreateVector()
gfX.vec.data += update
b.Assemble()
dJOmegaAuto.Assemble()
Draw(-gfX, mesh, "-gfX")
gfset.Set((0,0))
scale = 0.5 / Norm(gfX.vec)
Cost at initial design 6.143148052222692e-13
scene_u = Draw(gfu)
mesh.SetDeformation(gfset)
scene_u.Redraw()
#a.Assemble()
#fstate.Assemble()
#SolveStateEquation()
gfu.vec[:]=0
Newton iteration 0
err = 0.15369858576399262
Newton iteration 1
err = 1.5632394197727922e-16
Cost at new design 5.156527358681241e-14
scene_u = Draw(gfu)
gfset.Set((0,0))
scene_u.Redraw()
gfu.vec[:]=0
LineSearch = False
iter_max = 600
converged = False
for k in range(iter_max):
scene_u.Redraw()
gfu.vec[:]=0
fadjoint.Assemble()
b.Assemble()
scale = 0.01 / Norm(gfX.vec)
gfsetOld = gfset
if LineSearch:
# input('a')
scale = scale / 2
if scale <= 1e-12:
converged = True
break
gfu.vec[:]=0
if converged==True:
break
Jold = Jnew
Newton iteration 0
Newton iteration 1
cost at iteration 0 : 6.143148052222692e-13
cost at iteration 1 : 5.748924421710375e-13
cost at iteration 2 : 5.20729168320619e-13
cost at iteration 3 : 4.71218470415499e-13
cost at iteration 4 : 4.2601042354071205e-13
cost at iteration 5 : 3.847761781233703e-13
cost at iteration 6 : 3.472071587836018e-13
cost at iteration 7 : 3.130142627207186e-13
cost at iteration 8 : 2.8192705930158637e-13
cost at iteration 9 : 2.5369299251095394e-13
cost at iteration 10 : 2.2807658791507914e-13
cost at iteration 11 : 2.0485866578125664e-13
cost at iteration 12 : 1.8383556198750044e-13
cost at iteration 13 : 1.648183583493057e-13
cost at iteration 14 : 1.476321239842848e-13
cost at iteration 15 : 1.3211516932983262e-13
cost at iteration 16 : 1.1811831442181467e-13
cost at iteration 17 : 1.0550417302930229e-13
cost at iteration 18 : 9.414645421395105e-14
cost at iteration 19 : 8.392928282998769e-14
cost at iteration 20 : 7.474654038167762e-14
cost at iteration 21 : 6.650122747834898e-14
cost at iteration 22 : 5.910484882534774e-14
cost at iteration 23 : 5.2476821192466175e-14
cost at iteration 24 : 4.6543904006388165e-14
cost at iteration 25 : 4.1239650971425876e-14
cost at iteration 26 : 3.650387922147076e-14
cost at iteration 27 : 3.228214965320488e-14
cost at iteration 28 : 2.85252479020604e-14
cost at iteration 29 : 2.518864944338929e-14
cost at iteration 30 : 2.223194412951471e-14
cost at iteration 31 : 1.9618185174189406e-14
cost at iteration 32 : 1.7313116912517227e-14
cost at iteration 33 : 1.5284231312016085e-14
cost at iteration 34 : 1.3499625322018847e-14
cost at iteration 35 : 1.1926732694784306e-14
cost at iteration 36 : 1.0531303593744397e-14
cost at iteration 37 : 9.27768038694111e-15
cost at iteration 38 : 8.13233714726934e-15
cost at iteration 39 : 7.071966236038461e-15
cost at iteration 40 : 6.091276007722448e-15
cost at iteration 41 : 5.199376001132593e-15
cost at iteration 42 : 4.405785582671859e-15
cost at iteration 43 : 3.711925379822326e-15
cost at iteration 44 : 3.112224113526591e-15
cost at iteration 45 : 2.5978166970225225e-15
cost at iteration 46 : 2.159018406994307e-15
cost at iteration 47 : 1.786469663921592e-15
cost at iteration 48 : 1.4715603971503933e-15
cost at iteration 49 : 1.2065400180447507e-15
cost at iteration 50 : 9.845055998865804e-16
cost at iteration 51 : 7.99348003160733e-16
cost at iteration 52 : 6.456863305953521e-16
cost at iteration 53 : 5.188015132062596e-16
cost at iteration 54 : 4.1457261034736827e-16
cost at iteration 55 : 3.294168913676978e-16
cost at iteration 56 : 2.602339643046421e-16
cost at iteration 57 : 2.043539295166247e-16
cost at iteration 58 : 1.5948949129778978e-16
cost at iteration 59 : 1.2369184914302557e-16
cost at iteration 60 : 9.531029893847505e-17
cost at iteration 61 : 7.295521492901523e-17
cost at iteration 62 : 5.546455795840084e-17
cost at iteration 63 : 4.187309901754956e-17
cost at iteration 64 : 3.138591646371586e-17
cost at iteration 65 : 2.335535905929117e-17
cost at iteration 66 : 1.729473752176982e-17
cost at iteration 67 : 1.3113795252106978e-17
cost at iteration 68 : 1.1184553914376212e-17
cost at iteration 69 : 9.93610528454917e-18
cost at iteration 70 : 8.639821340582527e-18
cost at iteration 71 : 7.627303853770186e-18
cost at iteration 72 : 6.674909338666358e-18
cost at iteration 73 : 5.878566062352036e-18
cost at iteration 74 : 5.159185229692012e-18
cost at iteration 75 : 4.540446942317616e-18
cost at iteration 76 : 3.990970301997151e-18
cost at iteration 77 : 3.512307860392857e-18
cost at iteration 78 : 3.0902987255321203e-18
cost at iteration 79 : 2.720414667283902e-18
cost at iteration 80 : 2.395286593148187e-18
cost at iteration 81 : 2.1094232498729787e-18
cost at iteration 82 : 1.8584298650107363e-18
cost at iteration 83 : 1.6373763467622607e-18
cost at iteration 84 : 1.4433387994764414e-18
cost at iteration 85 : 1.2722860770972655e-18
cost at iteration 86 : 1.1221198584256444e-18
cost at iteration 87 : 9.89669991769875e-19
cost at iteration 88 : 8.733570130333628e-19
cost at iteration 89 : 7.707339213078236e-19
cost at iteration 90 : 6.805768541408179e-19
cost at iteration 91 : 6.010159008432209e-19
cost at iteration 92 : 5.310856763150937e-19
cost at iteration 93 : 4.693664103400988e-19
cost at iteration 94 : 4.150876625008246e-19
cost at iteration 95 : 3.6717705846604814e-19
cost at iteration 96 : 3.2501449245701824e-19
cost at iteration 97 : 2.8779436629913613e-19
cost at iteration 98 : 2.550140635141921e-19
cost at iteration 99 : 2.260723835242602e-19
cost at iteration 100 : 2.0055930409388184e-19
cost at iteration 101 : 1.7803003351704597e-19
cost at iteration 102 : 1.5814796655334883e-19
cost at iteration 103 : 1.4058783973315649e-19
cost at iteration 104 : 1.2507156329405408e-19
cost at iteration 105 : 1.1136497942943338e-19
cost at iteration 106 : 9.923684747948202e-20
cost at iteration 107 : 8.852201943104713e-20
cost at iteration 108 : 7.902682488179705e-20
cost at iteration 109 : 7.063759269478259e-20
cost at iteration 110 : 6.319063694069729e-20
cost at iteration 111 : 5.660943723978904e-20
cost at iteration 112 : 5.075420583916368e-20
cost at iteration 113 : 4.5574117712217507e-20
cost at iteration 114 : 4.094960137511758e-20
cost at iteration 115 : 3.6848015278802767e-20
cost at iteration 116 : 3.316938347308628e-20
cost at iteration 117 : 2.989557822001468e-20
cost at iteration 118 : 2.694577384374234e-20
cost at iteration 119 : 2.4313398663586663e-20
cost at iteration 120 : 2.1933274206189253e-20
cost at iteration 121 : 1.9806745233804655e-20
cost at iteration 122 : 1.7879349236308983e-20
cost at iteration 123 : 1.6157414400212398e-20
cost at iteration 124 : 1.459354373354658e-20
cost at iteration 125 : 1.3197349072963014e-20
cost at iteration 126 : 1.1926593517654218e-20
cost at iteration 127 : 1.0793160222892178e-20
cost at iteration 128 : 9.759149337724697e-21
cost at iteration 129 : 8.83791465878515e-21
cost at iteration 130 : 7.99551456258536e-21
cost at iteration 131 : 7.246034190256576e-21
cost at iteration 132 : 6.559195739885668e-21
cost at iteration 133 : 5.949174612681842e-21
cost at iteration 134 : 5.389028082141338e-21
cost at iteration 135 : 4.8925553651005715e-21
cost at iteration 136 : 4.435792393203161e-21
cost at iteration 137 : 4.031894352800233e-21
cost at iteration 138 : 3.6595200208295016e-21
cost at iteration 139 : 3.3310724451466514e-21
cost at iteration 140 : 3.0274952871204965e-21
cost at iteration 141 : 2.760429756667419e-21
cost at iteration 142 : 2.512798478309769e-21
cost at iteration 143 : 2.2955189826858877e-21
cost at iteration 144 : 2.0932319985605754e-21
cost at iteration 145 : 1.9161844738236847e-21
cost at iteration 146 : 1.7505238833718966e-21
cost at iteration 147 : 1.6058745032684612e-21
cost at iteration 148 : 1.469723241530637e-21
cost at iteration 149 : 1.351103780781188e-21
cost at iteration 150 : 1.2387100153362801e-21
cost at iteration 151 : 1.1409986340862756e-21
cost at iteration 152 : 1.0477652097756954e-21
cost at iteration 153 : 9.668873357952796e-22
cost at iteration 154 : 8.891787960564126e-22
cost at iteration 155 : 8.219247447642413e-22
cost at iteration 156 : 7.568923643884447e-22
cost at iteration 157 : 7.007521456026998e-22
cost at iteration 158 : 6.461774505154802e-22
cost at iteration 159 : 5.991895866341132e-22
cost at iteration 160 : 5.533366885592446e-22
cost at iteration 161 : 5.139338157578901e-22
cost at iteration 162 : 4.753790344742153e-22
cost at iteration 163 : 4.42210986011314e-22
cost at iteration 164 : 4.0965571870215564e-22
cost at iteration 165 : 3.8149130123260573e-22
cost at iteration 166 : 3.5374183456626837e-22
cost at iteration 167 : 3.2959845867052542e-22
cost at iteration 168 : 3.0573354821176865e-22
cost at iteration 169 : 2.8498527758281935e-22
cost at iteration 170 : 2.6440565602209475e-22
cost at iteration 171 : 2.4675340028361784e-22
cost at iteration 172 : 2.2921554198659723e-22
cost at iteration 173 : 2.1494090856776006e-22
cost at iteration 174 : 2.0102692640935432e-22
cost at iteration 175 : 1.90356620407107e-22
cost at iteration 176 : 1.7834372857919499e-22
cost at iteration 177 : 1.6868186609581511e-22
cost at iteration 178 : 1.5778858872718134e-22
cost at iteration 179 : 1.4906293473320682e-22
cost at iteration 180 : 1.392976865534981e-22
cost at iteration 181 : 1.3149534134985753e-22
cost at iteration 182 : 1.2277642641908882e-22
cost at iteration 183 : 1.1587756511162276e-22
cost at iteration 184 : 1.0816047477592435e-22
cost at iteration 185 : 1.0214773278748872e-22
cost at iteration 186 : 9.537737214389195e-23
cost at iteration 187 : 9.020447202060025e-23
cost at iteration 188 : 8.430193341698763e-23
cost at iteration 189 : 7.989722101569155e-23
cost at iteration 190 : 7.476883415763255e-23
cost at iteration 191 : 7.104868600314887e-23
cost at iteration 192 : 6.659758279356814e-23
cost at iteration 193 : 6.34779813395571e-23
cost at iteration 194 : 5.961287933241987e-23
cost at iteration 195 : 5.701885231054489e-23
cost at iteration 196 : 5.366356034836563e-23
cost at iteration 197 : 5.1546109052034197e-23
cost at iteration 198 : 4.867634144989418e-23
cost at iteration 199 : 4.7119688283949086e-23
cost at iteration 200 : 4.522250745299087e-23
cost at iteration 201 : 4.53428491551145e-23
cost at iteration 202 : 4.292358565473393e-23
cost at iteration 203 : 4.224198667009581e-23
cost at iteration 204 : 4.015928638321197e-23
cost at iteration 205 : 3.947124663365399e-23
cost at iteration 206 : 3.756913946877759e-23
cost at iteration 207 : 3.694080945279965e-23
cost at iteration 208 : 3.5202086091944967e-23
cost at iteration 209 : 3.465484491057137e-23
cost at iteration 210 : 3.304550316993069e-23
cost at iteration 211 : 3.2585270039922696e-23
cost at iteration 212 : 3.108011974320025e-23
cost at iteration 213 : 3.071529223835344e-23
cost at iteration 214 : 2.92973720434577e-23
cost at iteration 215 : 2.904076866541252e-23
cost at iteration 216 : 2.769585802220861e-23
cost at iteration 217 : 2.756722058520111e-23
cost at iteration 218 : 2.6282288804223662e-23
cost at iteration 219 : 2.6321766358373425e-23
cost at iteration 220 : 2.5094892949458668e-23
cost at iteration 221 : 2.5406642156030157e-23
cost at iteration 222 : 2.4260671576350916e-23
cost at iteration 223 : 2.4587236682648856e-23
cost at iteration 224 : 2.3076638809387324e-23
cost at iteration 225 : 2.3159977853423423e-23
cost at iteration 226 : 2.177890754815206e-23
cost at iteration 227 : 2.20412321050613e-23
cost at iteration 228 : 2.0815065650867725e-23
cost at iteration 229 : 2.11974202133947e-23
cost at iteration 230 : 2.0047782541206843e-23
cost at iteration 231 : 2.051892401881519e-23
cost at iteration 232 : 1.943808647953593e-23
cost at iteration 233 : 2.0056859936759627e-23
cost at iteration 234 : 1.920838482769471e-23
cost at iteration 235 : 2.0191847739497258e-23
cost at iteration 236 : 1.912881985558181e-23
cost at iteration 237 : 1.9083415879659037e-23
cost at iteration 238 : 1.8044055696845993e-23
cost at iteration 239 : 1.8078171267293204e-23
cost at iteration 240 : 1.7237777212258034e-23
cost at iteration 241 : 1.7479345901206362e-23
cost at iteration 242 : 1.6721647345447486e-23
cost at iteration 243 : 1.7122899290656124e-23
cost at iteration 244 : 1.640013708152807e-23
cost at iteration 245 : 1.7087257461684404e-23
cost at iteration 246 : 1.6515130107849466e-23
cost at iteration 247 : 1.7319322582726396e-23
cost at iteration 248 : 1.60814565122883e-23
cost at iteration 249 : 1.6450623286260967e-23
cost at iteration 250 : 1.5178882632558133e-23
cost at iteration 251 : 1.5780141843415684e-23
cost at iteration 252 : 1.465960576489171e-23
cost at iteration 253 : 1.5412915161960792e-23
cost at iteration 254 : 1.4363027002172037e-23
cost at iteration 255 : 1.52624243701594e-23
cost at iteration 256 : 1.436814507762451e-23
cost at iteration 257 : 1.5785604506366356e-23
cost at iteration 258 : 1.494509914350896e-23
cost at iteration 259 : 1.4984089079656496e-23
cost at iteration 260 : 1.426418525435059e-23
cost at iteration 261 : 1.4136010515061184e-23
cost at iteration 262 : 1.3644636314951703e-23
cost at iteration 263 : 1.3733559165970767e-23
cost at iteration 264 : 1.3345115285474587e-23
cost at iteration 265 : 1.3628025337721274e-23
cost at iteration 266 : 1.3314496060000845e-23
cost at iteration 267 : 1.4068111015735657e-23
cost at iteration 268 : 1.37939591380113e-23
cost at iteration 269 : 1.3811173264214715e-23
cost at iteration 270 : 1.3226123040109785e-23
cost at iteration 271 : 1.3014261693552098e-23
cost at iteration 272 : 1.2675960106687461e-23
cost at iteration 273 : 1.2616284849747802e-23
cost at iteration 274 : 1.2422288105509589e-23
cost at iteration 275 : 1.247947262304797e-23
cost at iteration 276 : 1.2410149189391912e-23
cost at iteration 277 : 1.2784914019839278e-23
cost at iteration 278 : 1.3320679183290574e-23
cost at iteration 279 : 1.2779399457219643e-23
cost at iteration 280 : 1.2763781002148366e-23
cost at iteration 281 : 1.2050388523562375e-23
cost at iteration 282 : 1.2111505169117867e-23
cost at iteration 283 : 1.1630533017587965e-23
cost at iteration 284 : 1.1833451799451589e-23
cost at iteration 285 : 1.1534373713669273e-23
cost at iteration 286 : 1.1834351887488427e-23
cost at iteration 287 : 1.1933075148206947e-23
cost at iteration 288 : 1.2489687509675813e-23
cost at iteration 289 : 1.1978723954676334e-23
cost at iteration 290 : 1.1902405876440085e-23
cost at iteration 291 : 1.1293114112044156e-23
cost at iteration 292 : 1.1393372585971244e-23
cost at iteration 293 : 1.0919854429287095e-23
cost at iteration 294 : 1.1190886902384681e-23
cost at iteration 295 : 1.0816532363383678e-23
cost at iteration 296 : 1.1227423025891488e-23
cost at iteration 297 : 1.112426874328301e-23
cost at iteration 298 : 1.2247664134227464e-23
cost at iteration 299 : 1.1287065349962467e-23
cost at iteration 300 : 1.1601083904146732e-23
cost at iteration 301 : 1.0659633359064409e-23
cost at iteration 302 : 1.1011679090487227e-23
cost at iteration 303 : 1.0276542282306946e-23
cost at iteration 304 : 1.0786841799329992e-23
cost at iteration 305 : 1.0217932807980545e-23
cost at iteration 306 : 1.085618443717523e-23
cost at iteration 307 : 1.0697193170538286e-23
cost at iteration 308 : 1.1548713849308983e-23
cost at iteration 309 : 1.0679149550476446e-23
cost at iteration 310 : 1.0941303432461675e-23
cost at iteration 311 : 9.99594468223365e-24
cost at iteration 312 : 1.0532433932092573e-23
cost at iteration 313 : 9.678976653253665e-24
cost at iteration 314 : 1.0395644370185222e-23
cost at iteration 315 : 9.618050591199124e-24
cost at iteration 316 : 1.050258748104773e-23
cost at iteration 317 : 1.0004656269817083e-23
cost at iteration 318 : 1.164855195743573e-23
cost at iteration 319 : 1.0066945932649875e-23
cost at iteration 320 : 1.0870352757422424e-23
cost at iteration 321 : 9.412311744839899e-24
cost at iteration 322 : 1.0411963780544195e-23
cost at iteration 323 : 9.084432639285375e-24
cost at iteration 324 : 1.0267871563182153e-23
cost at iteration 325 : 9.06876914329089e-24
cost at iteration 326 : 1.0429996593816103e-23
cost at iteration 327 : 9.632782875092007e-24
cost at iteration 328 : 1.0979505367406287e-23
cost at iteration 329 : 9.597420758038034e-24
cost at iteration 330 : 1.0330822546235426e-23
cost at iteration 331 : 8.892426973423345e-24
cost at iteration 332 : 1.0025507619932131e-23
cost at iteration 333 : 8.633468888154614e-24
cost at iteration 334 : 9.946797267075141e-24
cost at iteration 335 : 8.59862181908322e-24
cost at iteration 336 : 1.0089314618700312e-23
cost at iteration 337 : 8.95465286705703e-24
cost at iteration 338 : 1.132145294587281e-23
cost at iteration 339 : 9.115970110403257e-24
cost at iteration 340 : 1.0330785397973145e-23
cost at iteration 341 : 8.504083175762081e-24
cost at iteration 342 : 9.946652342561255e-24
cost at iteration 343 : 8.211228481613843e-24
cost at iteration 344 : 9.84050670910775e-24
cost at iteration 345 : 8.208984830450342e-24
cost at iteration 346 : 1.0026418388259385e-23
cost at iteration 347 : 8.731511444115689e-24
cost at iteration 348 : 1.0600447907674031e-23
cost at iteration 349 : 8.761542717558988e-24
cost at iteration 350 : 9.891163630652536e-24
cost at iteration 351 : 8.072581195395307e-24
cost at iteration 352 : 9.631930708882944e-24
cost at iteration 353 : 7.844710770295713e-24
cost at iteration 354 : 9.572099316626102e-24
cost at iteration 355 : 7.815640387211613e-24
cost at iteration 356 : 9.685113847109637e-24
cost at iteration 357 : 8.045710768739058e-24
cost at iteration 358 : 1.0883221413120963e-23
cost at iteration 359 : 8.539974977123017e-24
cost at iteration 360 : 9.638913819315315e-24
cost at iteration 361 : 8.154771249003732e-24
cost at iteration 362 : 9.209018236409027e-24
cost at iteration 363 : 7.841008246653165e-24
cost at iteration 364 : 9.07586404832825e-24
cost at iteration 365 : 7.81842303461709e-24
cost at iteration 366 : 9.231817152092396e-24
cost at iteration 367 : 8.29747822684273e-24
cost at iteration 368 : 9.93459987225626e-24
cost at iteration 369 : 8.321183693496991e-24
cost at iteration 370 : 9.282289444490032e-24
cost at iteration 371 : 7.68682119521807e-24
cost at iteration 372 : 9.007581388543708e-24
cost at iteration 373 : 7.452173406737666e-24
cost at iteration 374 : 8.948379958903469e-24
cost at iteration 375 : 7.42850808074847e-24
cost at iteration 376 : 9.088372878564049e-24
cost at iteration 377 : 7.73192506260621e-24
cost at iteration 378 : 1.037815114516161e-23
cost at iteration 379 : 8.019633996526406e-24
cost at iteration 380 : 9.252294033870088e-24
cost at iteration 381 : 7.526588381064314e-24
cost at iteration 382 : 8.902055052118287e-24
cost at iteration 383 : 7.256650227592732e-24
cost at iteration 384 : 8.807623903581307e-24
cost at iteration 385 : 7.260653097629175e-24
cost at iteration 386 : 9.009479399573244e-24
cost at iteration 387 : 7.786655569357279e-24
cost at iteration 388 : 9.562791655899362e-24
cost at iteration 389 : 7.795922726142582e-24
cost at iteration 390 : 8.941677535253814e-24
cost at iteration 391 : 7.147628223222845e-24
cost at iteration 392 : 8.715633737063657e-24
cost at iteration 393 : 6.948139355580128e-24
cost at iteration 394 : 8.674741787624684e-24
cost at iteration 395 : 6.933338620444929e-24
cost at iteration 396 : 8.803920686483971e-24
cost at iteration 397 : 7.179268319489373e-24
cost at iteration 398 : 1.0064132522088596e-23
cost at iteration 399 : 7.614307582247838e-24
cost at iteration 400 : 8.791999698051505e-24
cost at iteration 401 : 7.232109476225701e-24
cost at iteration 402 : 8.433748700425876e-24
cost at iteration 403 : 6.960997276418647e-24
cost at iteration 404 : 8.330886076484285e-24
cost at iteration 405 : 6.955901002858187e-24
cost at iteration 406 : 8.516156243110765e-24
cost at iteration 407 : 7.450933588417603e-24
cost at iteration 408 : 9.147161090804125e-24
cost at iteration 409 : 7.452672122606545e-24
cost at iteration 410 : 8.551341423533812e-24
cost at iteration 411 : 6.834779373891781e-24
cost at iteration 412 : 8.323790875824765e-24
cost at iteration 413 : 6.634988238041849e-24
cost at iteration 414 : 8.283038266361125e-24
cost at iteration 415 : 6.620786734383163e-24
cost at iteration 416 : 8.413652803047697e-24
cost at iteration 417 : 6.87242636260015e-24
cost at iteration 418 : 9.680592080135566e-24
cost at iteration 419 : 7.282039231245959e-24
cost at iteration 420 : 8.443044706506522e-24
cost at iteration 421 : 6.898586998016659e-24
cost at iteration 422 : 8.10427845675107e-24
cost at iteration 423 : 6.640487820970361e-24
cost at iteration 424 : 8.008655965184816e-24
cost at iteration 425 : 6.638893791127154e-24
cost at iteration 426 : 8.19847432777444e-24
cost at iteration 427 : 7.13266099994163e-24
cost at iteration 428 : 8.813450788810622e-24
cost at iteration 429 : 7.12575693235306e-24
cost at iteration 430 : 8.24490093950721e-24
cost at iteration 431 : 6.521544701626422e-24
cost at iteration 432 : 8.029943602279015e-24
cost at iteration 433 : 6.331727070867868e-24
cost at iteration 434 : 7.992523437678648e-24
cost at iteration 435 : 6.319058401772008e-24
cost at iteration 436 : 8.115095525139363e-24
cost at iteration 437 : 6.548183216175099e-24
cost at iteration 438 : 9.338548597571828e-24
cost at iteration 439 : 7.020284989845682e-24
cost at iteration 440 : 8.091573987385667e-24
cost at iteration 441 : 6.683481507393328e-24
cost at iteration 442 : 7.745606242246334e-24
cost at iteration 443 : 6.426712785413992e-24
cost at iteration 444 : 7.644986327127153e-24
cost at iteration 445 : 6.419629665446264e-24
cost at iteration 446 : 7.82221803102281e-24
cost at iteration 447 : 6.891996406197759e-24
cost at iteration 448 : 8.483085782786756e-24
cost at iteration 449 : 6.872663355516796e-24
cost at iteration 450 : 7.93978991068416e-24
cost at iteration 451 : 6.2934319233761366e-24
cost at iteration 452 : 7.723851387419873e-24
cost at iteration 453 : 6.103841545733789e-24
cost at iteration 454 : 7.684732480818174e-24
cost at iteration 455 : 6.090312561984804e-24
cost at iteration 456 : 7.802819074890294e-24
cost at iteration 457 : 6.3153012350942715e-24
cost at iteration 458 : 9.001316617653475e-24
cost at iteration 459 : 6.792338777920051e-24
cost at iteration 460 : 7.795649350120196e-24
cost at iteration 461 : 6.467488414751643e-24
cost at iteration 462 : 7.452842012787995e-24
cost at iteration 463 : 6.2168662161539765e-24
cost at iteration 464 : 7.351884304597701e-24
cost at iteration 465 : 6.2081087759378004e-24
cost at iteration 466 : 7.521392452278999e-24
cost at iteration 467 : 6.664289438442955e-24
cost at iteration 468 : 8.207369201028601e-24
cost at iteration 469 : 6.63711227450942e-24
cost at iteration 470 : 7.682292568858357e-24
cost at iteration 471 : 6.078038944290194e-24
cost at iteration 472 : 7.468946998593508e-24
cost at iteration 473 : 5.8912561155811065e-24
cost at iteration 474 : 7.428305865745571e-24
cost at iteration 475 : 5.8766859415367255e-24
cost at iteration 476 : 7.536770372100718e-24
cost at iteration 477 : 6.083888849997398e-24
cost at iteration 478 : 8.671149711798181e-24
cost at iteration 479 : 6.619711770748954e-24
cost at iteration 480 : 7.500693668773032e-24
cost at iteration 481 : 6.3270689774924616e-24
cost at iteration 482 : 7.14319318645881e-24
cost at iteration 483 : 6.0766776294826304e-24
cost at iteration 484 : 7.034589734463783e-24
cost at iteration 485 : 6.061478996000898e-24
cost at iteration 486 : 7.18652034279084e-24
cost at iteration 487 : 6.488441816458684e-24
cost at iteration 488 : 7.924336342956603e-24
cost at iteration 489 : 6.453087575159728e-24
cost at iteration 490 : 7.417562432507218e-24
cost at iteration 491 : 5.924870159822573e-24
cost at iteration 492 : 7.197254758036459e-24
cost at iteration 493 : 5.735412810834412e-24
cost at iteration 494 : 7.151335827901673e-24
cost at iteration 495 : 5.718259592149862e-24
cost at iteration 496 : 7.25221016928398e-24
cost at iteration 497 : 5.9204438809769524e-24
cost at iteration 498 : 8.338975505433222e-24
cost at iteration 499 : 6.4706335768835386e-24
cost at iteration 500 : 7.240075080740121e-24
cost at iteration 501 : 6.186879036962017e-24
cost at iteration 502 : 6.875852775281236e-24
cost at iteration 503 : 5.940525577833924e-24
cost at iteration 504 : 6.762678358181417e-24
cost at iteration 505 : 5.921967386162586e-24
cost at iteration 506 : 6.900564194777842e-24
cost at iteration 507 : 6.324721297187015e-24
cost at iteration 508 : 7.67077272466372e-24
cost at iteration 509 : 6.286186867712765e-24
cost at iteration 510 : 7.178804614576916e-24
cost at iteration 511 : 5.786533845768938e-24
cost at iteration 512 : 6.953116125770666e-24
cost at iteration 513 : 5.5962210363833585e-24
cost at iteration 514 : 6.901803173420225e-24
cost at iteration 515 : 5.576522836194125e-24
cost at iteration 516 : 6.992433574386917e-24
cost at iteration 517 : 5.767199462786628e-24
cost at iteration 518 : 8.005197076661049e-24
cost at iteration 519 : 6.363009847787615e-24
cost at iteration 520 : 6.98394440102342e-24
cost at iteration 521 : 6.0946987118799275e-24
cost at iteration 522 : 6.602861120710012e-24
cost at iteration 523 : 5.8500457759857605e-24
cost at iteration 524 : 6.481032920963027e-24
cost at iteration 525 : 5.8258963809094766e-24
cost at iteration 526 : 6.599551742601858e-24
cost at iteration 527 : 6.1955160017882605e-24
cost at iteration 528 : 7.400271361605044e-24
cost at iteration 529 : 6.163533648028605e-24
cost at iteration 530 : 6.925570696777066e-24
cost at iteration 531 : 5.703517188441395e-24
cost at iteration 532 : 6.685308946382521e-24
cost at iteration 533 : 5.509732051908086e-24
cost at iteration 534 : 6.624407775410228e-24
cost at iteration 535 : 5.486156515726543e-24
cost at iteration 536 : 6.703831251179752e-24
cost at iteration 537 : 5.671104923684911e-24
cost at iteration 538 : 7.640825654019231e-24
cost at iteration 539 : 6.2939623641372816e-24
cost at iteration 540 : 6.734600251919796e-24
cost at iteration 541 : 6.028277816262892e-24
cost at iteration 542 : 6.336076061299235e-24
cost at iteration 543 : 5.786935092338169e-24
cost at iteration 544 : 6.2049386424210845e-24
cost at iteration 545 : 5.7585877697606215e-24
cost at iteration 546 : 6.303521711305813e-24
cost at iteration 547 : 6.0964997305058916e-24
cost at iteration 548 : 7.111466133960234e-24
cost at iteration 549 : 6.082143521443679e-24
cost at iteration 550 : 6.663375386327756e-24
cost at iteration 551 : 5.664720490481885e-24
cost at iteration 552 : 6.402599240003653e-24
cost at iteration 553 : 5.4684374086120706e-24
cost at iteration 554 : 6.328751944638474e-24
cost at iteration 555 : 5.440818152914326e-24
cost at iteration 556 : 6.3939117825933344e-24
cost at iteration 557 : 5.619225379933156e-24
cost at iteration 558 : 7.233346659097984e-24
cost at iteration 559 : 6.2828747378327885e-24
cost at iteration 560 : 6.474237376299736e-24
cost at iteration 561 : 6.013634180374391e-24
cost at iteration 562 : 6.050945791105637e-24
cost at iteration 563 : 5.775537543049518e-24
cost at iteration 564 : 5.907275368490487e-24
cost at iteration 565 : 5.7427306914301795e-24
cost at iteration 566 : 5.981518739342273e-24
cost at iteration 567 : 6.042281546853413e-24
cost at iteration 568 : 6.759617852777244e-24
cost at iteration 569 : 6.08044308253958e-24
cost at iteration 570 : 6.361287869837448e-24
cost at iteration 571 : 5.713921959339261e-24
cost at iteration 572 : 6.0627444862989004e-24
cost at iteration 573 : 5.5164953876381166e-24
cost at iteration 574 : 5.967522263559739e-24
cost at iteration 575 : 5.4842388871431e-24
cost at iteration 576 : 6.010848408361779e-24
cost at iteration 577 : 5.65062858043241e-24
cost at iteration 578 : 6.694750556909345e-24
cost at iteration 579 : 6.4117888580924886e-24
cost at iteration 580 : 6.15789949786028e-24
cost at iteration 581 : 6.117320398024805e-24
cost at iteration 582 : 5.693557113256429e-24
cost at iteration 583 : 5.8809627352119746e-24
cost at iteration 584 : 5.531037969881588e-24
cost at iteration 585 : 5.841917790867759e-24
cost at iteration 586 : 5.5709350072212974e-24
cost at iteration 587 : 6.082137760327701e-24
cost at iteration 588 : 6.213086465190103e-24
cost at iteration 589 : 6.319809360019276e-24
cost at iteration 590 : 5.938247646386718e-24
cost at iteration 591 : 6.000786454991736e-24
cost at iteration 592 : 5.5517780879314946e-24
cost at iteration 593 : 5.806650178102642e-24
cost at iteration 594 : 5.4180733974240266e-24
cost at iteration 595 : 5.767109790569192e-24
cost at iteration 596 : 5.41902913067814e-24
cost at iteration 597 : 5.877540380527908e-24
cost at iteration 598 : 5.734996111060928e-24
cost at iteration 599 : 6.941111364069962e-24
