This page was generated from unit-7-optimization/03a_Shape_Derivative_Laplace_SemiAuto.ipynb.
7.4 PDE-Constrained Shape Optimization in NGSolve¶
- We want to solve the PDE-constrained shape optimization problem :nbsphinx-math:`begin{equation}
underset{Omegasubset mathsf{D}}{mbox{min}} ; J(u) := int_Omega |u-u_d|^q ; dx, quad qge 2
- end{equation}` subject to that
satisfy :nbsphinx-math:`begin{equation} int_Omega nabla u cdot nabla v ; dx = int_Omega f v ; dx ; quad text{ for all } v in H_0^1(Omega),
end{equation}` where
from ngsolve.solvers import *
#geo.AddRectangle( (0.2, 0.2), (0.8, 0.8), bcs = ('b','r','t','l'))
mesh = Mesh(geo.GenerateMesh(maxh = 0.1))
ud = x*(1-x)*y*(1-y)
gfp = GridFunction(fes)
- The formula for the shape derivative was derived as the partial derivative of the perturbed Lagrangian (brought back to the original domain): :nbsphinx-math:`begin{align*}
- dmathcal J(Omega; X) = frac{partial}{partial t} left( int_Omega |u - u_d^t|^q ,mbox{det}(F_t) mbox{d} x
int_{Omega} (F_t^{-top}nabla u) cdot (F_t^{-top} nabla p), mbox{det}(F_t) , dx - int_{Omega}f^t p ,mbox{det}(F_t) ,dx right)|_{t=0}
end{align*}` where
The integrand depends on the parameter
PHI, X = VEC.TnT()
#define symbolic parameter t=0 in order to allow differentiation w.r.t. t
t = Parameter(0)
F = Id(2) + t * grad(X).trans
def Equation(u,v):
return ( (Inv(F.trans)*grad(u))*(Inv(F.trans)*grad(v))-f*v)*Det(F)
q=6
def CostAuto(u):
return (u-ud)**q*Det(F)
def CostAuto2(u):
return (u-ud)**q
Lagrangian = CostAuto(gfu) + Equation(gfu,gfp)
State equation¶
Equation can also be used to define the bilinear form. The following defines left and right hand side of the PDE in a “BilinearForm”:
u, v = fes.TnT()
aAuto += Equation(u,v)*dx
gfu.vec[:]=0
scene_u.Redraw()
Newton iteration 0
err = 0.13016086186788947
Newton iteration 1
err = 9.481807124502225e-17
Adjoint equation¶
- We set up the adjoint equation :nbsphinx-math:`begin{align*}
mbox{Find } p in H_0^1(Omega): int_Omega nabla w cdot nabla p , mbox dx = - partial_u J(u)(w) quad text{ for all } w in H_0^1(Omega)
- end{align*}` where
is the solution to the state equation. For , we get :nbsphinx-math:`begin{align*} partial_u J(u)(w) = 2 int_Omega (u-u_d)w ,mbox dx.
end{align*}` However, we can also use the Diff(…) command:
p, w = fes.TnT()
fadjoint = LinearForm(fes)
fadjoint += -1*(CostAuto(gfu)*dx).Diff(gfu,w)
def SolveAdjointEquation():
rhs = gfp.vec.CreateVector()
gfp.vec.data += update
fadjoint.Assemble()
scene_p.Redraw()
- Denoting the integrand by
, the shape derivative is given by :nbsphinx-math:`begin{align*} dmathcal J(Omega; X) =& left( left. frac{partial G^{u,p}}{partial t} + frac{d G^{u,p}}{dy} cdot frac{d T_t}{dt}right)rightrvert_{t=0} \ =& left. frac{partial G^{u,p}}{partial t}rightrvert_{t=0} + frac{d G^{u,p}}{dy} cdot X
end{align*}`
dJOmegaAuto = LinearForm(VEC)
dJOmegaAuto += Lagrangian.Diff(t) * dx
dJOmegaAuto += (Lagrangian.Diff(x, X[0]) + Lagrangian.Diff(y, X[1])) * dx
b = BilinearForm(VEC)
gfX = GridFunction(VEC)
gfset = GridFunction(VEC)
gfset.Set((0,0))
scene=Draw(gfset,mesh,"gfset")
rhs = gfX.vec.CreateVector()
gfX.vec.data += update
b.Assemble()
dJOmegaAuto.Assemble()
Draw(-gfX, mesh, "-gfX")
gfset.Set((0,0))
scale = 0.5 / Norm(gfX.vec)
Cost at initial design 6.457553863133461e-13
mesh.SetDeformation(gfset)
gfu.vec[:]=0
Newton iteration 0
err = 0.1571174420960136
Newton iteration 1
err = 1.1609319199315723e-16
Cost at new design 1.5689143159982939e-13
scene_u = Draw(gfu)
gfset.Set((0,0))
gfu.vec[:]=0
LineSearch = True
iter_max = 600
converged = False
for k in range(iter_max):
scene_u.Redraw()
gfu.vec[:]=0
fadjoint.Assemble()
b.Assemble()
scale = 0.01 / Norm(gfX.vec)
gfsetOld = gfset
if LineSearch:
#input('a')
scale = scale / 2
if scale <= 1e-12:
converged = True
break
gfu.vec[:]=0
if converged==True:
break
Jold = Jnew
Newton iteration 0
Newton iteration 1
cost at iteration 0 : 6.457553863133461e-13
cost at iteration 1 : 5.983887299218896e-13
cost at iteration 2 : 5.335221619386397e-13
cost at iteration 3 : 4.750742838717911e-13
cost at iteration 4 : 4.224887358578915e-13
cost at iteration 5 : 3.7524777180142396e-13
cost at iteration 6 : 3.3287057919500564e-13
cost at iteration 7 : 2.9491159086510645e-13
cost at iteration 8 : 2.6095879603665375e-13
cost at iteration 9 : 2.3063205708646567e-13
cost at iteration 10 : 2.035814377293271e-13
cost at iteration 11 : 1.7948554798915158e-13
cost at iteration 12 : 1.5804991105732506e-13
cost at iteration 13 : 1.390053569757802e-13
cost at iteration 14 : 1.2210644796799573e-13
cost at iteration 15 : 1.0712994014784748e-13
cost at iteration 16 : 9.387328623151561e-14
cost at iteration 17 : 8.215318371514817e-14
cost at iteration 18 : 7.180417268866989e-14
cost at iteration 19 : 6.267728691993569e-14
cost at iteration 20 : 5.463876088363814e-14
cost at iteration 21 : 4.7568793746481066e-14
cost at iteration 22 : 4.136036852582171e-14
cost at iteration 23 : 3.591812007049436e-14
cost at iteration 24 : 3.115723823748801e-14
cost at iteration 25 : 2.7002381389221666e-14
cost at iteration 26 : 2.3386558633849078e-14
cost at iteration 27 : 2.0249916108851958e-14
cost at iteration 28 : 1.753833523841301e-14
cost at iteration 29 : 1.5201732827926245e-14
cost at iteration 30 : 1.3191992545794986e-14
cost at iteration 31 : 1.1460695749849676e-14
cost at iteration 32 : 9.957576406582612e-15
cost at iteration 33 : 8.632213301301494e-15
cost at iteration 34 : 7.442386197370637e-15
cost at iteration 35 : 6.3661987177662546e-15
cost at iteration 36 : 5.402363949733956e-15
cost at iteration 37 : 4.554359969711412e-15
cost at iteration 38 : 3.8192092703343004e-15
cost at iteration 39 : 3.1880716117992034e-15
cost at iteration 40 : 2.6497757284759458e-15
cost at iteration 41 : 2.192980672152958e-15
cost at iteration 42 : 1.807073039235905e-15
cost at iteration 43 : 1.4824524085938693e-15
cost at iteration 44 : 1.2105670389576063e-15
cost at iteration 45 : 9.8386230723172e-16
cost at iteration 46 : 7.956991898751652e-16
cost at iteration 47 : 6.402708251352465e-16
cost at iteration 48 : 5.125175552215949e-16
cost at iteration 49 : 4.080526005409263e-16
cost at iteration 50 : 3.2308490353689827e-16
cost at iteration 51 : 2.5436044958738657e-16
cost at iteration 52 : 1.9908817075715602e-16
cost at iteration 53 : 1.5490715358823715e-16
cost at iteration 54 : 1.1979726809862288e-16
cost at iteration 55 : 9.212807207889791e-17
cost at iteration 56 : 7.056068995185006e-17
cost at iteration 57 : 5.48598300413397e-17
cost at iteration 58 : 4.5620525712213855e-17
cost at iteration 59 : 4.0057472118834696e-17
cost at iteration 60 : 3.4702532171283616e-17
cost at iteration 61 : 3.037407306318569e-17
cost at iteration 62 : 2.6423128089062752e-17
cost at iteration 63 : 2.31418986707482e-17
cost at iteration 64 : 2.017942953154694e-17
cost at iteration 65 : 1.7699199067396037e-17
cost at iteration 66 : 1.5463241816146383e-17
cost at iteration 67 : 1.3585240797098516e-17
cost at iteration 68 : 1.1890357269593688e-17
cost at iteration 69 : 1.0464222098274457e-17
cost at iteration 70 : 9.174736905044622e-18
cost at iteration 71 : 8.088233597576724e-18
cost at iteration 72 : 7.10371850808119e-18
cost at iteration 73 : 6.273188400999334e-18
cost at iteration 74 : 5.518883715501759e-18
cost at iteration 75 : 4.881859065694522e-18
cost at iteration 76 : 4.301900055104616e-18
cost at iteration 77 : 3.8116153869111924e-18
cost at iteration 78 : 3.364123504576092e-18
cost at iteration 79 : 2.9854703797564188e-18
cost at iteration 80 : 2.6389590134674287e-18
cost at iteration 81 : 2.34550544821156e-18
cost at iteration 82 : 2.076233220445727e-18
cost at iteration 83 : 1.848022846562556e-18
cost at iteration 84 : 1.638036846255227e-18
cost at iteration 85 : 1.4599592095860127e-18
cost at iteration 86 : 1.295643557967857e-18
cost at iteration 87 : 1.1562237757843933e-18
cost at iteration 88 : 1.0272199524750795e-18
cost at iteration 89 : 9.177172945532354e-19
cost at iteration 90 : 8.161189943924632e-19
cost at iteration 91 : 7.298538412439378e-19
cost at iteration 92 : 6.496052580099691e-19
cost at iteration 93 : 5.814554792305476e-19
cost at iteration 94 : 5.179007907358631e-19
cost at iteration 95 : 4.639242007514461e-19
cost at iteration 96 : 4.1346972484571927e-19
cost at iteration 97 : 3.70620597959826e-19
cost at iteration 98 : 3.3048106493599525e-19
cost at iteration 99 : 2.963969430877318e-19
cost at iteration 100 : 2.6440463520760735e-19
cost at iteration 101 : 2.372457142368346e-19
cost at iteration 102 : 2.1170660861943507e-19
cost at iteration 103 : 1.9003446481002304e-19
cost at iteration 104 : 1.696195168733629e-19
cost at iteration 105 : 1.5230527370652611e-19
cost at iteration 106 : 1.359679725857099e-19
cost at iteration 107 : 1.2212251338461037e-19
cost at iteration 108 : 1.090360928276733e-19
cost at iteration 109 : 9.795681007809638e-20
cost at iteration 110 : 8.746619338228156e-20
cost at iteration 111 : 7.85961791016252e-20
cost at iteration 112 : 7.018100679592305e-20
cost at iteration 113 : 6.307764016567679e-20
cost at iteration 114 : 5.632367302210743e-20
cost at iteration 115 : 5.063433734347229e-20
cost at iteration 116 : 4.52112226787407e-20
cost at iteration 117 : 4.065445310144534e-20
cost at iteration 118 : 3.629835222580623e-20
cost at iteration 119 : 3.2649134532160286e-20
cost at iteration 120 : 2.914908379616561e-20
cost at iteration 121 : 2.622733558449903e-20
cost at iteration 122 : 2.3414490728912542e-20
cost at iteration 123 : 2.107599031769807e-20
cost at iteration 124 : 1.8815110740573947e-20
cost at iteration 125 : 1.694431678404717e-20
cost at iteration 126 : 1.512700123870333e-20
cost at iteration 127 : 1.3631341148759687e-20
cost at iteration 128 : 1.2170641758056992e-20
cost at iteration 129 : 1.0975949022874114e-20
cost at iteration 130 : 9.802075491719958e-21
cost at iteration 131 : 8.848932110333834e-21
cost at iteration 132 : 7.90582021728165e-21
cost at iteration 133 : 7.146616890740038e-21
cost at iteration 134 : 6.389181576826966e-21
cost at iteration 135 : 5.7857503347494835e-21
cost at iteration 136 : 5.177680113458935e-21
cost at iteration 137 : 4.699385935481947e-21
cost at iteration 138 : 4.21136681280123e-21
cost at iteration 139 : 3.833569483477622e-21
cost at iteration 140 : 3.441855861922309e-21
cost at iteration 141 : 3.1446727955247575e-21
cost at iteration 142 : 2.8299495204246234e-21
cost at iteration 143 : 2.597266196702026e-21
cost at iteration 144 : 2.3437657764262963e-21
cost at iteration 145 : 2.162453776838353e-21
cost at iteration 146 : 1.9572996450087074e-21
cost at iteration 147 : 1.816613241063529e-21
cost at iteration 148 : 1.6493516287711283e-21
cost at iteration 149 : 1.5404818931789125e-21
cost at iteration 150 : 1.4027492066767962e-21
cost at iteration 151 : 1.318514625569354e-21
cost at iteration 152 : 1.2037771004462694e-21
cost at iteration 153 : 1.1384090745979975e-21
cost at iteration 154 : 1.0417190669940193e-21
cost at iteration 155 : 9.906684523066128e-22
cost at iteration 156 : 9.084219266008396e-22
cost at iteration 157 : 8.681174510907018e-22
cost at iteration 158 : 7.978679870892573e-22
cost at iteration 159 : 7.654003911116294e-22
cost at iteration 160 : 7.058844769001284e-22
cost at iteration 161 : 6.78607123801438e-22
cost at iteration 162 : 6.303711206591396e-22
cost at iteration 163 : 6.053698260107228e-22
cost at iteration 164 : 5.713387159445664e-22
cost at iteration 165 : 5.438440714730507e-22
cost at iteration 166 : 5.217583948720182e-22
cost at iteration 167 : 4.909771009672683e-22
cost at iteration 168 : 4.757063605745574e-22
cost at iteration 169 : 4.452313250306558e-22
cost at iteration 170 : 4.345881717273167e-22
cost at iteration 171 : 4.0491712080306655e-22
cost at iteration 172 : 3.982523475627112e-22
cost at iteration 173 : 3.690175858589996e-22
cost at iteration 174 : 3.6668841420365605e-22
cost at iteration 175 : 3.3726716886980163e-22
