Navier Stokes Equation¶
we use the P3/P2 Taylor-Hood mixed finite element pairing
and perform operator splitting time-integration with the non-linear term explicit, but time-dependent Stokes fully implicit.
Download navierstokes.py
# viscosity
nu = 0.001
# timestepping parameters
tau = 0.001
tend = 10
mesh.Curve(3)
Q = H1(mesh,order=2)
X = V*Q
u,p = X.TrialFunction()
v,q = X.TestFunction()
a += stokes*dx
# nothing here ...
f = LinearForm(X)
gfu = GridFunction(X)
# parabolic inflow at inlet:
# matrix for implicit Euler
mstar.Assemble()
# the non-linear term
# for visualization
        print ("t=", t, end="\r")
        conv.Apply (gfu.vec, res)
        res.data += a.mat*gfu.vec
        t = t + tau
