7.2 PDE-Constrained Shape Optimization in NGSolve
We want to solve the PDE-constrained shape optimization problem :nbsphinx-math:`begin{equation}
underset{Omegasubset mathsf{D}}{mbox{min}} ; J(u) := int_Omega |u-u_d|^2 ; dx
end{equation}` subject to that \((\Omega,u)\) satisfy :nbsphinx-math:`begin{equation}
int_Omega nabla u cdot nabla v ; dx = int_Omega f v ; dx ; quad text{ for all } v in H_0^1(Omega),
end{equation}` where \(\Omega \subset \mathbb R^2\) for given \(u_d, f \in C^1(\mathbb R^2)\).
geo.AddRectangle( (0.2, 0.2), (0.8, 0.8), bcs = ('b','r','t','l'))
mesh = Mesh(geo.GenerateMesh(maxh = 0.1))
ud = x*(1-x)*y*(1-y)
State equation
u, v = fes.TnT()
scene = Draw (gfu, mesh, "state")
a += grad(u)*grad(v)*dx
fstate = LinearForm(fes)
fstate += f*v*dx
def SolveStateEquation():
    rhs = gfu.vec.CreateVector()
    gfu.vec.data += update
fstate.Assemble()
Adjoint equation
We set up the adjoint equation :nbsphinx-math:`begin{align*}
mbox{Find } p in H_0^1(Omega): int_Omega nabla w cdot nabla p , mbox dx = - partial_u J(u)(w) quad text{ for all } w in H_0^1(Omega)
end{align*}` where \(u\) is the solution to the state equation. For \(J(u) = \int_\Omega |u-u_d|^2 \mbox dx\), we get :nbsphinx-math:`begin{align*}
partial_u J(u)(w) = -2 int_Omega (u-u_d)w ,mbox dx.
end{align*}` However, we can also use the Diff(…) command:
def Cost(u):
    return (u-ud)**2*dx
p, w = fes.TnT()
gfp = GridFunction(fes)
fadjoint = LinearForm(fes)
def SolveAdjointEquation():
    rhs = gfp.vec.CreateVector()
    gfp.vec.data += update
fadjoint.Assemble()
Shape derivative
The shape derivative of the shape function
\[\mathcal{J}(\Omega):= \int_\Omega |u-u_d|^2\;dx\]
at \(\Omega\) in direction \(X\) is given by the formula :nbsphinx-math:`begin{align*}
dmathcal J(Omega; X) =&int_{Omega} mbox{div}(X) |u-u_d|^2 - 2(u-u_d)nabla u_d cdot X , dx \
& + int_{Omega} (mbox{div}(X) I - D X - D X^top )nabla u cdot nabla p , dx \ &- int_Omega (nabla fcdot X + f mbox{div}(X)) p, dx.
end{align*}` We now assemble this shape derivaitve in NGSolve as follows:
PHI, X = VEC.TnT()
dJOmega = LinearForm(VEC)
dJOmega += SymbolicLFI(div(X)*( (gfu-ud)**2 - f*gfp + InnerProduct(grad(gfu),grad(gfp))))
dJOmega += SymbolicLFI(-2*(gfu-ud)*InnerProduct(grad_ud,X) - InnerProduct(grad_f,X)*gfp)
dJOmega += SymbolicLFI(-InnerProduct(X.Deriv()*grad(gfu),grad(gfp))-InnerProduct(grad(gfu),X.Deriv()*grad(gfp)))
Descent Direction
  • Next, we want to find a vector field \(X\) which yields a decrease of the objective function, i.e. we want to find a vector field \(X\) such that
    \[d \mathcal J(\Omega;X)<0.\]
  • This can be achieved by solving an auxiliary boundary value problem of the type :nbsphinx-math:`begin{align*}
    mbox{Find } X in H: qquad b(X, Phi) = dmathcal J(Omega; Phi) ; text{ for all } Phi in H
    end{align*}` for a suitable Hilbert space \(H\) (e.g. \(H=H^1(\Omega)^2\)). Here, \(b(\cdot, \cdot): H \times H \rightarrow \mathbb R\) is a positive definite bilinear form which we are free to choose. Then, \(-X\) is a descent direction since
    \[d\mathcal J(\Omega; -X) = -d\mathcal J(\Omega; X) = - b(X, X) < 0.\]
b = BilinearForm(VEC)
gfX = GridFunction(VEC)
gfset = GridFunction(VEC)
gfset.Set((0,0))
def SolveDeformationEquation():
    rhs = gfX.vec.CreateVector()
    rhs.data = dJOmega.vec - b.mat * gfX.vec
    gfX.vec.data += update
b.Assemble()
dJOmega.Assemble()
Draw(-gfX, mesh, "gfX")
Now let us update the geometry in the direction of \(-X\). Here, we need to choose the step size accordingly (a descent is only guaranteed for this step size being sufficiently small)
print('Cost at initial design', Integrate (Cost(gfu), mesh))
gfset.Set((0,0))
scale = 0.5 / Norm(gfX.vec)
Cost at initial design 0.0004865785615789076
Let us now update the design and compute the new value of the cost function:
scene = Draw(gfset)
mesh.SetDeformation(gfset)
fstate.Assemble()
print('Cost at new design', Integrate (Cost(gfu), mesh))
Cost at new design 0.00032579700603296667
#reset the design
gfset.Set((0,0))
#check if initial value of cost function 0.000486578350214552 is recovered
fstate.Assemble()
Cost at new design 0.00048657856157890755
Finally, this can be applied in an iterative algorithm with a line search for choosing the step size:
scene = Draw(gfset)
gfset.Set((0,0))
fstate.Assemble()
LineSearch = True
iter_max = 600
Jold = Integrate(Cost(gfu), mesh)
converged = False
# input("Press enter to start optimization")
for k in range(iter_max):
    fstate.Assemble()
    fadjoint.Assemble()
    b.Assemble()
    dJOmega.Assemble()
    scale = 0.01 / Norm(gfX.vec)
    gfsetOld = gfset
    if LineSearch:
            #input('a')
            scale = scale / 2
            print("scale = ", scale)
            if scale <= 1e-12:
                converged = True
                break
            fstate.Assemble()
    if converged==True:
        print("No more descent can be found")
        break
    Jold = Jnew
cost at iteration 0 :  0.0004865785615789076
scale =  5.0172940372132
cost at iteration 1 :  0.0004834070731679915
scale =  4.76812536166299
cost at iteration 2 :  0.00048011519918462055
scale =  4.534231415136698
cost at iteration 3 :  0.0004766971686029878
scale =  4.316155256294001
cost at iteration 4 :  0.00047314803597050544
scale =  4.11377184307069
cost at iteration 5 :  0.0004694636491068565
scale =  3.926524963094991
cost at iteration 6 :  0.000465640600243633
scale =  3.75360331502335
cost at iteration 7 :  0.0004616761696387511
scale =  3.594064615563144
cost at iteration 8 :  0.00045756826770020255
scale =  3.4469191638143335
cost at iteration 9 :  0.0004533153793088772
scale =  3.3111835819313975
cost at iteration 10 :  0.0004489165123594056
scale =  3.1859135216674592
cost at iteration 11 :  0.00044437115142822135
scale =  3.070222024991224
cost at iteration 12 :  0.00043967921678626044
scale =  2.9632883913475636
cost at iteration 13 :  0.0004348410285717398
scale =  2.8643609572773268
cost at iteration 14 :  0.00042985727572691
scale =  2.772756118957971
cost at iteration 15 :  0.0004247289892105181
scale =  2.687855158813637
cost at iteration 16 :  0.0004194575189767934
cost at iteration 17 :  0.00041939467924363054
cost at iteration 18 :  0.0004157449768855941
cost at iteration 19 :  0.00041203301501048853
cost at iteration 20 :  0.00040825945184834087
cost at iteration 21 :  0.000404424995366182
cost at iteration 22 :  0.0004005304019577407
cost at iteration 23 :  0.000396576475251238
cost at iteration 24 :  0.00039256406502438375
cost at iteration 25 :  0.00038849406621653087
cost at iteration 26 :  0.00038436741802880004
cost at iteration 27 :  0.00038018510310376143
cost at iteration 28 :  0.0003759481467770181
cost at iteration 29 :  0.00037165761639371993
cost at iteration 30 :  0.00036731462068367117
cost at iteration 31 :  0.0003629203091892907
cost at iteration 32 :  0.00035847587174120746
cost at iteration 33 :  0.00035398253797677324
cost at iteration 34 :  0.0003494415768972088
cost at iteration 35 :  0.00034485429645951136
cost at iteration 36 :  0.0003402220431996079
cost at iteration 37 :  0.00033554620188357083
cost at iteration 38 :  0.0003308281951840142
cost at iteration 39 :  0.00032606948337904595
cost at iteration 40 :  0.00032127156407140415
cost at iteration 41 :  0.0003164359719256182
cost at iteration 42 :  0.00031156427842122364
cost at iteration 43 :  0.00030665809162024635
cost at iteration 44 :  0.00030171905594732364
cost at iteration 45 :  0.00029674885198096917
cost at iteration 46 :  0.00029174919625461694
cost at iteration 47 :  0.00028672184106619454
cost at iteration 48 :  0.0002816685742950742
cost at iteration 49 :  0.0002765912192253451
cost at iteration 50 :  0.0002714916343744222
cost at iteration 51 :  0.00026637171332609324
cost at iteration 52 :  0.0002612333845671558
cost at iteration 53 :  0.0002560786113268586
cost at iteration 54 :  0.00025090939141841456
cost at iteration 55 :  0.000245727757081893
cost at iteration 56 :  0.0002405357748278317
cost at iteration 57 :  0.00023533554528095698
cost at iteration 58 :  0.00023012920302341265
cost at iteration 59 :  0.00022491891643692898
cost at iteration 60 :  0.00021970688754338494
cost at iteration 61 :  0.00021449535184322118
cost at iteration 62 :  0.00020928657815118376
cost at iteration 63 :  0.000204082868428873
cost at iteration 64 :  0.00019888655761358032
cost at iteration 65 :  0.00019370001344289149
cost at iteration 66 :  0.00018852563627451988
cost at iteration 67 :  0.00018336585890083409
cost at iteration 68 :  0.00017822314635750365
cost at iteration 69 :  0.00017309999572568627
cost at iteration 70 :  0.00016799893592712246
cost at iteration 71 :  0.00016292252751148238
cost at iteration 72 :  0.00015787336243524693
cost at iteration 73 :  0.0001528540638313514
cost at iteration 74 :  0.00014786728576874343
cost at iteration 75 :  0.000142915713000922
cost at iteration 76 :  0.00013800206070241727
cost at iteration 77 :  0.00013312907419205217
cost at iteration 78 :  0.00012829952864166661
cost at iteration 79 :  0.0001235162287688251
cost at iteration 80 :  0.00011878200851179958
cost at iteration 81 :  0.00011409973068487521
cost at iteration 82 :  0.00010947228661172123
cost at iteration 83 :  0.00010490259573420047
cost at iteration 84 :  0.00010039360519354301
cost at iteration 85 :  9.594828938027915e-05
cost at iteration 86 :  9.156964944866153e-05
cost at iteration 87 :  8.726071279050268e-05
cost at iteration 88 :  8.302453246236872e-05
cost at iteration 89 :  7.88641865588312e-05
cost at iteration 90 :  7.478277752295763e-05
cost at iteration 91 :  7.078343138330423e-05
cost at iteration 92 :  6.686929690425183e-05
cost at iteration 93 :  6.304354463345361e-05
cost at iteration 94 :  5.9309365826231996e-05
cost at iteration 95 :  5.56699712216729e-05
cost at iteration 96 :  5.212858963855236e-05
cost at iteration 97 :  4.868846635053011e-05
cost at iteration 98 :  4.535286118848774e-05
cost at iteration 99 :  4.212504630238634e-05
cost at iteration 100 :  3.900830349396327e-05
cost at iteration 101 :  3.6005921002635226e-05
cost at iteration 102 :  3.3121189586640336e-05
cost at iteration 103 :  3.0357397684400822e-05
cost at iteration 104 :  2.7717825359129206e-05
cost at iteration 105 :  2.5205736609887297e-05
cost at iteration 106 :  2.2824369453801957e-05
cost at iteration 107 :  2.057692291262757e-05
cost at iteration 108 :  1.8466539614314582e-05
cost at iteration 109 :  1.6496282045939547e-05
cost at iteration 110 :  1.4669099387971241e-05
cost at iteration 111 :  1.298777998794354e-05
cost at iteration 112 :  1.145488125568711e-05
cost at iteration 113 :  1.007262281355575e-05
cost at iteration 114 :  8.842717496818089e-06
cost at iteration 115 :  7.766092693004397e-06
cost at iteration 116 :  6.842409434732994e-06
cost at iteration 117 :  6.069193282153669e-06
cost at iteration 118 :  5.440208221421094e-06
cost at iteration 119 :  4.9424681388560335e-06
cost at iteration 120 :  4.551896484353182e-06
cost at iteration 121 :  4.233417833116078e-06
cost at iteration 122 :  3.956971777491831e-06
cost at iteration 123 :  3.7061649322349903e-06
cost at iteration 124 :  3.470244162683972e-06
cost at iteration 125 :  3.2445866632841836e-06
cost at iteration 126 :  3.027910220569668e-06
cost at iteration 127 :  2.8198554430473946e-06
cost at iteration 128 :  2.6202877787151928e-06
cost at iteration 129 :  2.429126284894742e-06
cost at iteration 130 :  2.2463040550243446e-06
cost at iteration 131 :  2.0717602007679695e-06
cost at iteration 132 :  1.9054383669070406e-06
cost at iteration 133 :  1.7472862760882225e-06
cost at iteration 134 :  1.5972553054360095e-06
cost at iteration 135 :  1.4552999490466279e-06
cost at iteration 136 :  1.32137709932866e-06
cost at iteration 137 :  1.1954450982857e-06
cost at iteration 138 :  1.0774624297453983e-06
cost at iteration 139 :  9.673859611144226e-07
cost at iteration 140 :  8.651684020082804e-07
cost at iteration 141 :  7.70754908723486e-07
cost at iteration 142 :  6.840777119752722e-07
cost at iteration 143 :  6.050498938933369e-07
cost at iteration 144 :  5.33551888448009e-07
cost at iteration 145 :  4.6943036500608073e-07
cost at iteration 146 :  4.1246301529351296e-07
cost at iteration 147 :  3.6343181510421024e-07
cost at iteration 148 :  3.3856392909400196e-07
cost at iteration 149 :  3.2774413393563646e-07
cost at iteration 150 :  3.1829363965946713e-07
cost at iteration 151 :  3.0721003489110865e-07
cost at iteration 152 :  2.989651852576779e-07
cost at iteration 153 :  2.8899411214234657e-07
cost at iteration 154 :  2.8171138616899657e-07
cost at iteration 155 :  2.7268166895265493e-07
cost at iteration 156 :  2.661980533481267e-07
cost at iteration 157 :  2.57970719548692e-07
cost at iteration 158 :  2.5216528948974876e-07
cost at iteration 159 :  2.446263051437108e-07
cost at iteration 160 :  2.3940412326028583e-07
cost at iteration 161 :  2.324592809429861e-07
cost at iteration 162 :  2.2774334931668095e-07
cost at iteration 163 :  2.21314419971787e-07
cost at iteration 164 :  2.1704106842657958e-07
cost at iteration 165 :  2.110627977140854e-07
cost at iteration 166 :  2.0717872969058573e-07
cost at iteration 167 :  2.0159644801141513e-07
cost at iteration 168 :  1.980566786919977e-07
cost at iteration 169 :  1.92824380213092e-07
cost at iteration 170 :  1.8959070560123464e-07
cost at iteration 171 :  1.8466949564320423e-07
cost at iteration 172 :  1.8170930691420843e-07
cost at iteration 173 :  1.7706614286558312e-07
cost at iteration 174 :  1.7435148233958673e-07
cost at iteration 175 :  1.6995815028675377e-07
cost at iteration 176 :  1.674649462965877e-07
cost at iteration 177 :  1.632972277727086e-07
cost at iteration 178 :  1.6100466747324407e-07
cost at iteration 179 :  1.5704165995428115e-07
cost at iteration 180 :  1.5493167149874422e-07
cost at iteration 181 :  1.511552334499089e-07
cost at iteration 182 :  1.4921205649143035e-07
cost at iteration 183 :  1.4560635344090982e-07
cost at iteration 184 :  1.4381618181979e-07
cost at iteration 185 :  1.4036731446480155e-07
cost at iteration 186 :  1.3871799833663546e-07
cost at iteration 187 :  1.3541369732043512e-07
cost at iteration 188 :  1.3389449445913393e-07
cost at iteration 189 :  1.3072386938285008e-07
cost at iteration 190 :  1.293252372806717e-07
cost at iteration 191 :  1.262785698736442e-07
cost at iteration 192 :  1.249919917441193e-07
cost at iteration 193 :  1.2206056502275454e-07
cost at iteration 194 :  1.2087840400438844e-07
cost at iteration 195 :  1.1805436079099762e-07
cost at iteration 196 :  1.1696973762152907e-07
cost at iteration 197 :  1.1424596304197864e-07
cost at iteration 198 :  1.1325265327289772e-07
cost at iteration 199 :  1.1062267686193647e-07
cost at iteration 200 :  1.0971502434537597e-07
cost at iteration 201 :  1.0717293820671682e-07
cost at iteration 202 :  1.0634578213701091e-07
cost at iteration 203 :  1.0388617226850391e-07
cost at iteration 204 :  1.0313478551864953e-07
cost at iteration 205 :  1.0075267395068628e-07
cost at iteration 206 :  1.0007271082519713e-07
cost at iteration 207 :  9.776350665685512e-08
cost at iteration 208 :  9.715095850001704e-08
cost at iteration 209 :  9.491041627160415e-08
cost at iteration 210 :  9.436157363437631e-08
cost at iteration 211 :  9.218575776265983e-08
cost at iteration 212 :  9.169717805129789e-08
cost at iteration 213 :  8.95824322873811e-08
cost at iteration 214 :  8.915091199953692e-08
cost at iteration 215 :  8.709383305927959e-08
cost at iteration 216 :  8.671638386505517e-08
cost at iteration 217 :  8.471379853642762e-08
cost at iteration 218 :  8.438762658780106e-08
cost at iteration 219 :  8.243657174525482e-08
cost at iteration 220 :  8.215905970170576e-08
cost at iteration 221 :  8.025676475998065e-08
cost at iteration 222 :  8.002545610469774e-08
cost at iteration 223 :  7.816932752786989e-08
cost at iteration 224 :  7.798191282063738e-08
cost at iteration 225 :  7.616952037017834e-08
cost at iteration 226 :  7.602382514240063e-08
cost at iteration 227 :  7.4252889603437e-08
cost at iteration 228 :  7.414686364995029e-08
cost at iteration 229 :  7.241524582019547e-08
cost at iteration 230 :  7.234695368319328e-08
cost at iteration 231 :  7.065264444598434e-08
cost at iteration 232 :  7.062025692009145e-08
cost at iteration 233 :  6.896136825320757e-08
scale =  53.59239366683971
scale =  26.796196833419856
scale =  13.398098416709928
scale =  6.699049208354964
scale =  3.349524604177482
scale =  1.674762302088741
scale =  0.8373811510443705
scale =  0.41869057552218525
scale =  0.20934528776109262
scale =  0.10467264388054631
scale =  0.052336321940273156
scale =  0.026168160970136578
scale =  0.013084080485068289
scale =  0.0065420402425341445
scale =  0.0032710201212670723
scale =  0.0016355100606335361
scale =  0.0008177550303167681
scale =  0.00040887751515838403
scale =  0.00020443875757919202
scale =  0.00010221937878959601
scale =  5.1109689394798004e-05
scale =  2.5554844697399002e-05
scale =  1.2777422348699501e-05
scale =  6.3887111743497505e-06
scale =  3.1943555871748752e-06
scale =  1.5971777935874376e-06
scale =  7.985888967937188e-07
scale =  3.992944483968594e-07
scale =  1.996472241984297e-07
scale =  9.982361209921485e-08
scale =  4.9911806049607426e-08
scale =  2.4955903024803713e-08
scale =  1.2477951512401856e-08
scale =  6.238975756200928e-09
scale =  3.119487878100464e-09
scale =  1.559743939050232e-09
scale =  7.79871969525116e-10
scale =  3.89935984762558e-10
scale =  1.94967992381279e-10
scale =  9.74839961906395e-11
scale =  4.874199809531975e-11
scale =  2.4370999047659876e-11
scale =  1.2185499523829938e-11
scale =  6.092749761914969e-12
scale =  3.0463748809574845e-12
scale =  1.5231874404787422e-12
scale =  7.615937202393711e-13
