3.6 DG/HDG splitting¶
For a problem of the form
order = 3
mesh.Curve(order)
Boundary mesh done, np = 72
CalcLocalH: 72 Points 0 Elements 0 Surface Elements
Meshing domain 1 / 1
load internal triangle rules
Surface meshing done
Edgeswapping, topological
Smoothing
Split improve
Combine improve
Smoothing
Edgeswapping, metric
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
Update mesh topology
Update clusters
Curve elements, order = 3
Update clusters
Curving edges
Curving faces
HDG spaces¶
V = FESpace ([V1,V2,Q])
v, vhat, q = V.TestFunction()
nu = 0.001 # viscosity
def tang(vec):
return vec - (vec*n)*n
Stokes discretization¶
alpha = 4 # SIP parameter
assemble VOL element 360/360
<ngsolve.comp.BilinearForm at 0x7f26ac054f70>
The mass matrix is simply
m += u * v * dx
<ngsolve.comp.BilinearForm at 0x7f26d82c58b0>
Initial conditions¶
gfu = GridFunction(V)
U0 = 1.5
setvalues element 72/72
call umfpack ... done
Application of convection¶
mixed mass matrices¶
uL2, vL2 = VL2.TnT()
bfmixed += vL2*u*dx
bfmixedT += uL2*v*dx
convection operator¶
vel = gfu.components[0]
un = InnerProduct(vel,n)
def __init__(self,tau,steps):
def Mult(self, x, y):
for i in range(self.steps):
def CreateColVector(self):
return CreateVVector(self.h)
Setup of \(M^*\):
t = 0; tend = 0
tau = 0.01; substeps = 10
The time loop:
%%time
tend += 1
res = gfu.vec.CreateVector()
t += tau
print ("\r t =", t, end="")
t = 1.0000000000000007CPU times: user 9.34 s, sys: 73.2 ms, total: 9.41 s
Wall time: 9.31 s
ConvertL2Operator¶
def NewMult(self, x, y):
The time loop:
%%time
tend += 1
t += tau
t = 2.0000000000000013CPU times: user 9.11 s, sys: 39.7 ms, total: 9.15 s
Wall time: 9.07 s
