Mesh of (only) the surface:¶
Start Findpoints
main-solids: 1
Found points 0
Analyze spec points
Find edges
0 edges found
Check intersecting edges
CalcLocalH: 2 Points 0 Elements 0 Surface Elements
Start Findpoints
main-solids: 1
Found points 0
Analyze spec points
Find edges
0 edges found
Start Findpoints
main-solids: 1
Found points 0
Analyze spec points
Find edges
0 edges found
Surface 1 / 1
load internal triangle rules
Surface meshing done
0 illegal triangles
Optimize Surface
Edgeswapping, topological
Smoothing
Combine improve
Smoothing
Edgeswapping, metric
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
126 elements, 65 points
SplitSeparateFaces
Update mesh topology
Update clusters
order = 4
if order > 0:
mesh.Curve(order)
Curve elements, order = 4
Update clusters
Curving edges
Curving faces
Tangential velocity field:¶
t = Parameter(0.)
Draw (b, mesh, "b")
eps = 5e-5
some local quantities¶
bn = InnerProduct(b,con)
Discretization¶
Surface FESpaces:¶
u,uE = fes.TrialFunction()
v,vE = fes.TestFunction()
gradu = u.Trace().Deriv()
gradv = v.Trace().Deriv()
jumpu = u - uE
jumpv = v - vE
# diffusion
alpha = 10*(order+1)**2
a += eps*gradu * gradv * ds
a += - eps*dudn * jumpv * dr
a += - eps*dvdn * jumpu * dr
outflow |
inflow |
assemble BND element 124/124
<ngsolve.comp.BilinearForm at 0x7f4524dd9c30>
Mass matrix:¶
m = BilinearForm(fes)
m += u*v*ds
<ngsolve.comp.BilinearForm at 0x7f4524e03230>
dt = 0.02
mstarinv = mstar.Inverse()
T = 8*pi
call pardiso ... done
Time stepping¶
res = gfu.vec.CreateVector()
setvalues element 124/124
The time loop¶
t.Set(0)
for i in range(int(T/dt)):
res.data = m.mat * gfu.vec
gfu.vec.data = mstarinv * res
t.Set(t.Get()+dt)
Remark:¶
