Schäfer-Turek benchmark¶
mesh.Curve(3); Draw(mesh)
# viscosity
nu = 0.001
Boundary mesh done, np = 72
CalcLocalH: 72 Points 0 Elements 0 Surface Elements
Meshing domain 1 / 1
load internal triangle rules
Surface meshing done
Edgeswapping, topological
Smoothing
Split improve
Combine improve
Smoothing
Edgeswapping, metric
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
Update mesh topology
Update clusters
Curve elements, order = 3
Update clusters
Curving edges
Curving faces
k = 3
Q = H1(mesh,order=k-1)
X = FESpace([V,Q])
with boundary conditions:
gfu = GridFunction(X)
velocity = gfu.components[0]
Draw(velocity,mesh,"u",sd=3)
# parabolic inflow at bc=1:
setvalues element 72/72
inflow profile plot:¶
%matplotlib inline
bvs = 6*s*(0.41-s)/(0.41)**2
plt.plot(s, bvs)
plt.grid(True)
(u,p), (v,q) = X.TnT()
a = BilinearForm(X)
a += stokes
f = LinearForm(X)
assemble VOL element 360/360
call pardiso ... done
IMEX time discretization¶
dt = 0.001
mstar = BilinearForm(X)
mstar.Assemble()
conv = LinearForm(X)
tend = 0
tend += 1
while t < tend-0.5*dt:
print ("\rt=", t, end="")
conv.Assemble()
t = t + dt
drag_x_test = GridFunction(X)
drag_y_test = GridFunction(X)
time_vals = []
drag_x_vals = []
drag_y_vals = []
# restoring initial data
tend = 0
tend += 1
conv.Assemble()
t = t + dt
time_vals.append( t )
#print(drag)
# Plot drag force over time
# Plot lift force over time
