2.10 Dual basis functions¶
We use dual basis functions to define interpolation operators, define transfer operators between different finite element spaces, and auxiliar space preconditioners.
Canonical interpolation¶
Boundary mesh done, np = 4
CalcLocalH: 4 Points 0 Elements 0 Surface Elements
Meshing domain 1 / 1
load internal triangle rules
Surface meshing done
Edgeswapping, topological
Smoothing
Split improve
Combine improve
Smoothing
Edgeswapping, metric
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
Update mesh topology
Update clusters
The NGSolve ‘Set’ function does local projection, and simple averaging. In particular, this does not respect point values in mesh vertices.
func = x*x*x*x
gfu.Set(func)
Draw (gfu)
print (gfu.vec)
setvalues element 2/2
-0.0223792
0.991843
0.977621
-0.00815655
3.34984
2.19912
3.34984
2
0.00660131
8.91822e-18
0.00660131
-3.19744e-14
3.34984
-1.80088
-2.17601
1.82399
Most NGSolve finite element spaces provide now a “dual” operator, which delivers the moments (i.e. the dual space basis functions) instead of function values. The integrals over faces, edges and also vertices are defined by co-dimension 1 (=BND), co-dimension 2 (=BBND) or co-dimension 3 (=BBBND) integrals over the volume elements. We define a variational problem for canonical interpolaion:
vdual = v.Operator("dual")
u*vdual*dx(element_vb=BBND)
print (gfu.vec)
Draw (gfu)
assemble VOL element 2/2
call pardiso ... done
1
2
3.6
2
-6.93335e-32
-1.66533e-15
3.6
-2
-2
2
The vertex degrees of freedom vanish for edge and element basis functions, and the edge degrees of freedom vanish for element basis functions, but not vise versa. Thus, the obtained matrix A is block-triangular:
import scipy.sparse as sp
plt.spy(A)
print (vblocks)
print (eblocks)
print (fblocks)
vinv.Smooth(gfu.vec, f.vec)
einv.Smooth(gfu.vec, f.vec)
finv.Smooth(gfu.vec, f.vec)
print (gfu.vec)
[(0,), (1,), (2,), (3,)]
[(14,), (15,)]
BlockJacobi Preconditioner, constructor called, #blocks = 4
BlockJacobi Preconditioner built
BlockJacobi Preconditioner, constructor called, #blocks = 5
BlockJacobi Preconditioner, constructor called, #blocks = 2
1
2
3.6
2
-6.93335e-32
-1.66533e-15
3.6
-2
-2
2
feshdiv = HDiv(mesh, order=2)
gfuh1 = GridFunction(fesh1)
gfuh1.Set ( (x*x,y*y) )
Boundary mesh done, np = 20
CalcLocalH: 20 Points 0 Elements 0 Surface Elements
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
Update clusters
setvalues element 54/54
ahdiv = BilinearForm(feshdiv)
u,v = feshdiv.TnT()
uh1 = fesh1.TrialFunction()
ahdiv.Assemble()
amixed.Assemble()
Draw (gfuh1)
Draw (gfuhdiv)
assemble VOL element 54/54
assemble mixed bilinearform
self.mat = mat
def CreateRowVector(self):
def CreateColVector(self):
def Mult(self, x, y):
# y[:] = 0
# self.einv.Smooth(y,x) # y = y + A_E^-1 (x - A y)
# self.finv.Smooth(y,x) # y = y + A_E^-1 (x - A y)
y.data = self.einv * x
y.data += finv * self.res
def MultTrans(self, x, y):
y.data = self.finv.T * x
y.data += einv.T * self.res
BlockJacobi Preconditioner, constructor called, #blocks = 91
BlockJacobi Preconditioner, constructor called, #blocks = 54
Boundary mesh done, np = 40
CalcLocalH: 40 Points 0 Elements 0 Surface Elements
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
Update clusters
The DG discretization:
order=4
u,v = fesDG.TnT()
aDG = BilinearForm(fesDG)
jump_u = u-u.Other()
jump_v = v-v.Other()
alpha = 4
aDG += grad(u)*grad(v) * dx
aDG.Assemble()
fDG = LinearForm(fesDG)
fDG += 1*v * dx
fDG.Assemble()
gfuDG = GridFunction(fesDG)
assemble VOL element 232/232
assemble inner facet 368/368
u,v = fesH1.TnT()
aH1 = BilinearForm(fesH1)
aH1 += grad(u)*grad(v)*dx
aH1.Assemble()
call wirebasket inverse ( with 97 free dofs out of 505 )
<ngsolve.comp.BilinearForm at 0x7efc4026d6b0>
has inverse
maxsteps=200)
Draw (gfuDG)
WARNING: maxsteps is deprecated, use maxiter instead!
CG iteration 1, residual = 0.25330526037462214
CG iteration 2, residual = 0.03309624603764888
CG iteration 3, residual = 0.008611208192689282
CG iteration 4, residual = 0.004161316791286879
CG iteration 5, residual = 0.001415316775298487
CG iteration 6, residual = 0.0010294082919072218
CG iteration 7, residual = 0.0009409975524653672
CG iteration 8, residual = 0.0011150588025100898
CG iteration 9, residual = 0.0009072553532028414
CG iteration 10, residual = 0.0007005597437154782
CG iteration 11, residual = 0.000582509156346896
CG iteration 12, residual = 0.00045806716363981637
CG iteration 13, residual = 0.00035013587591175617
CG iteration 14, residual = 0.0003389579426000695
CG iteration 15, residual = 0.00030092880363367204
CG iteration 16, residual = 0.00024917896162954354
CG iteration 17, residual = 0.00020393153941205568
CG iteration 18, residual = 0.00015750033322040405
CG iteration 19, residual = 0.00011665450896385117
CG iteration 20, residual = 8.6938679008443e-05
CG iteration 21, residual = 7.785593301103466e-05
CG iteration 22, residual = 6.884157007377496e-05
CG iteration 23, residual = 5.580418759770179e-05
CG iteration 24, residual = 4.6587301525772524e-05
CG iteration 25, residual = 3.993871204144708e-05
CG iteration 26, residual = 3.2688650819518946e-05
CG iteration 27, residual = 2.9155421446683702e-05
CG iteration 28, residual = 2.895026601282905e-05
CG iteration 29, residual = 2.715175136736939e-05
CG iteration 30, residual = 2.289443567207669e-05
CG iteration 31, residual = 1.929409730319713e-05
CG iteration 32, residual = 1.7144300959958314e-05
CG iteration 33, residual = 1.2932552421849395e-05
CG iteration 34, residual = 1.1175658200042096e-05
CG iteration 35, residual = 9.9917396712219e-06
CG iteration 36, residual = 9.638491358213154e-06
CG iteration 37, residual = 7.788256388277177e-06
CG iteration 38, residual = 5.884638389080975e-06
CG iteration 39, residual = 4.820256415954196e-06
CG iteration 40, residual = 4.147719419989104e-06
CG iteration 41, residual = 3.657280709670656e-06
CG iteration 42, residual = 3.528176840424435e-06
CG iteration 43, residual = 3.361345329993449e-06
CG iteration 44, residual = 2.639834599746304e-06
CG iteration 45, residual = 2.052806670694827e-06
CG iteration 46, residual = 1.6586528592918677e-06
CG iteration 47, residual = 1.5557962073561936e-06
CG iteration 48, residual = 1.5199816456620328e-06
CG iteration 49, residual = 1.3586105439929994e-06
CG iteration 50, residual = 1.1159673333145435e-06
CG iteration 51, residual = 8.81051509261864e-07
CG iteration 52, residual = 7.223412178035554e-07
CG iteration 53, residual = 6.222439482911498e-07
CG iteration 54, residual = 5.869599045064579e-07
CG iteration 55, residual = 5.271249619741238e-07
CG iteration 56, residual = 4.2764208617537953e-07
CG iteration 57, residual = 3.4667665202657366e-07
CG iteration 58, residual = 2.7731146438096837e-07
CG iteration 59, residual = 2.3651662650178128e-07
CG iteration 60, residual = 1.930755493226456e-07
CG iteration 61, residual = 1.7433218742336493e-07
CG iteration 62, residual = 1.482442347701461e-07
CG iteration 63, residual = 1.2078390884614032e-07
CG iteration 64, residual = 9.286997836191626e-08
CG iteration 65, residual = 7.361889492185091e-08
CG iteration 66, residual = 6.103212513708734e-08
CG iteration 67, residual = 5.798412053460437e-08
CG iteration 68, residual = 4.7542824816526435e-08
CG iteration 69, residual = 3.9342554015081707e-08
CG iteration 70, residual = 3.153221445660914e-08
CG iteration 71, residual = 2.537873519362536e-08
CG iteration 72, residual = 1.9774243888045684e-08
CG iteration 73, residual = 1.7227572525763587e-08
CG iteration 74, residual = 1.649611376816606e-08
CG iteration 75, residual = 1.3873935096531471e-08
CG iteration 76, residual = 1.1981419446349633e-08
CG iteration 77, residual = 9.062624764972401e-09
CG iteration 78, residual = 7.533728348561578e-09
CG iteration 79, residual = 6.284361609897162e-09
CG iteration 80, residual = 5.779857448757864e-09
CG iteration 81, residual = 5.494762265325293e-09
CG iteration 82, residual = 4.496812819192624e-09
CG iteration 83, residual = 3.4170851007009615e-09
CG iteration 84, residual = 2.651345421290276e-09
CG iteration 85, residual = 2.321262595809717e-09
CG iteration 86, residual = 2.0742023432736374e-09
CG iteration 87, residual = 1.9733080572511028e-09
CG iteration 88, residual = 1.657600682506191e-09
CG iteration 89, residual = 1.2279553139617935e-09
CG iteration 90, residual = 9.174883038303481e-10
CG iteration 91, residual = 7.771196379122454e-10
CG iteration 92, residual = 6.922557378801707e-10
CG iteration 93, residual = 6.512710147575285e-10
CG iteration 94, residual = 5.651786199025267e-10
CG iteration 95, residual = 4.5071510795188225e-10
CG iteration 96, residual = 3.2512764230663943e-10
CG iteration 97, residual = 2.6747000469160404e-10
CG iteration 98, residual = 2.5564028631362375e-10
CG iteration 99, residual = 2.3795491625580587e-10
CG iteration 100, residual = 2.059193058926649e-10
CG iteration 101, residual = 1.603623814709048e-10
CG iteration 102, residual = 1.2318695265473402e-10
CG iteration 103, residual = 1.0109612980541768e-10
CG iteration 104, residual = 9.240017487664454e-11
CG iteration 105, residual = 8.836581620122911e-11
CG iteration 106, residual = 7.445196703328861e-11
CG iteration 107, residual = 5.711509865025669e-11
CG iteration 108, residual = 4.153014244751465e-11
CG iteration 109, residual = 3.482566094563307e-11
CG iteration 110, residual = 3.055245280700286e-11
CG iteration 111, residual = 2.7765807934553452e-11
CG iteration 112, residual = 2.503722443340592e-11
CG iteration 113, residual = 1.993773132220523e-11
CG iteration 114, residual = 1.5556079955409725e-11
CG iteration 115, residual = 1.2671080260134683e-11
CG iteration 116, residual = 1.0816851399082464e-11
CG iteration 117, residual = 1.018944388742323e-11
CG iteration 118, residual = 9.322135166212803e-12
CG iteration 119, residual = 7.487394128449176e-12
CG iteration 120, residual = 6.266845000152114e-12
CG iteration 121, residual = 5.0519245317264404e-12
CG iteration 122, residual = 3.999836916965542e-12
CG iteration 123, residual = 3.541465296946124e-12
CG iteration 124, residual = 3.1454036436953364e-12
CG iteration 125, residual = 2.531498942780815e-12
CG iteration 126, residual = 2.134030829318548e-12
CG iteration 127, residual = 1.7360401836112073e-12
CG iteration 128, residual = 1.435925047176203e-12
CG iteration 129, residual = 1.202776516935352e-12
CG iteration 130, residual = 1.0451774434525685e-12
CG iteration 131, residual = 9.291700818740193e-13
CG iteration 132, residual = 8.162479828820459e-13
CG iteration 133, residual = 6.78573989252929e-13
CG iteration 134, residual = 5.381859741200152e-13
CG iteration 135, residual = 4.1814641770809927e-13
CG iteration 136, residual = 3.6056697171066795e-13
CG iteration 137, residual = 3.369633834103298e-13
CG iteration 138, residual = 3.084384472691259e-13
CG iteration 139, residual = 2.75582309512028e-13
CG iteration 140, residual = 2.1523203625467158e-13
