This page was generated from unit-2.1.3-bddc/bddc.ipynb.
Let us start with a simple description of the element-wise BDDC in the context of Lagrange finite element space \(V\). Here the BDDC preconditoner is constructed on an auxiliary space \(\widetilde{V}\) obtained by connecting only element vertices (leaving edge and face shape functions discontinuous). Although larger, the auxiliary space allows local elimination of edge and face variables. Hence an analogue of the original matrix \(A\) on this space, named \(\widetilde A\), is less expensive to invert. This inverse is used to construct a preconditioner for \(A\) as follows:
SetHeapSize(100*1000*1000)
Start Findpoints
main-solids: 1
Found points 8
Analyze spec points
Find edges
12 edges found
Check intersecting edges
CalcLocalH: 20 Points 0 Elements 0 Surface Elements
Start Findpoints
Analyze spec points
Find edges
12 edges found
Start Findpoints
Analyze spec points
Find edges
12 edges found
Surface 1 / 6
load internal triangle rules
Surface meshing done
0 illegal triangles
Optimize Surface
Edgeswapping, topological
Smoothing
Combine improve
Smoothing
Edgeswapping, metric
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
6 elements, 20 points
Surface 2 / 6
0 illegal triangles
Optimize Surface
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Surface 3 / 6
0 illegal triangles
Optimize Surface
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Surface 4 / 6
0 illegal triangles
Optimize Surface
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Surface 5 / 6
0 illegal triangles
Optimize Surface
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Surface 6 / 6
0 illegal triangles
Optimize Surface
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
SplitSeparateFaces
Check subdomain 1 / 1
Meshing subdomain 1 of 1
Use internal rules
Delaunay meshing
number of points: 20
blockfill local h
number of points: 29
Elements: 142
Tree data entries per element: 1.40845
Tree nodes per element: 0.0211268
SwapImprove
SwapImprove
SwapImprove
SwapImprove
0 degenerated elements removed
Remove intersecting
Remove outer
29 points, 64 elements
start tetmeshing
Use internal rules
Success !
29 points, 83 elements
Remove Illegal Elements
Volume Optimization
CombineImprove
ImproveMesh
SplitImprove
ImproveMesh
SwapImprove
SwapImprove2
ImproveMesh
CombineImprove
ImproveMesh
SplitImprove
ImproveMesh
SwapImprove
SwapImprove2
ImproveMesh
CombineImprove
ImproveMesh
SplitImprove
ImproveMesh
SwapImprove
SwapImprove2
ImproveMesh
Update mesh topology
Update clusters
Built-in options¶
Effect of condensation¶
c = Preconditioner(a, "bddc")
lams = TestPreconditioner(5)
assemble VOL element 63/63
call wirebasket inverse ( with 136 free dofs out of 1576 )
has inverse
1.00228
1.0408
1.13959
7.43053
7.57517
7.66553
eigen-it 0/200
eigen-it 1/200
eigen-it 2/200
eigen-it 3/200
eigen-it 4/200
eigen-it 5/200
eigen-it 6/200
eigen-it 7/200
eigen-it 8/200
eigen-it 9/200
eigen-it 10/200
eigen-it 11/200
eigen-it 12/200
eigen-it 13/200
eigen-it 14/200
eigen-it 15/200
eigen-it 16/200
eigen-it 17/200
eigen-it 18/200
eigen-it 19/200
eigen-it 20/200
eigen-it 21/200
eigen-it 22/200
eigen-it 23/200
eigen-it 24/200
has inverse
1.00137
1.03997
1.11644
6.92348
7.01741
7.29845
eigen-it 0/200
eigen-it 1/200
eigen-it 2/200
eigen-it 3/200
eigen-it 4/200
eigen-it 5/200
eigen-it 6/200
eigen-it 7/200
eigen-it 8/200
eigen-it 9/200
eigen-it 10/200
eigen-it 11/200
eigen-it 12/200
eigen-it 13/200
eigen-it 14/200
eigen-it 15/200
eigen-it 16/200
eigen-it 17/200
eigen-it 18/200
eigen-it 19/200
eigen-it 20/200
eigen-it 21/200
eigen-it 22/200
eigen-it 23/200
Tuning the auxiliary space¶
wb_fulledges |
wb_withedges |
2D |
3D |
True |
any value |
all |
all |
False/Undefined |
Undefined |
none |
first |
False/Undefined |
False |
none |
none |
False/Undefined |
True |
first |
first |
wb_withedges=False)
call wirebasket inverse ( with 28 free dofs out of 1576 )
has inverse
1.00412
1.09464
1.33392
31.0804
33.0369
33.6461
eigen-it 0/200
eigen-it 1/200
eigen-it 2/200
eigen-it 3/200
eigen-it 4/200
eigen-it 5/200
eigen-it 6/200
eigen-it 7/200
eigen-it 8/200
eigen-it 9/200
eigen-it 10/200
eigen-it 11/200
eigen-it 12/200
eigen-it 13/200
eigen-it 14/200
eigen-it 15/200
eigen-it 16/200
eigen-it 17/200
eigen-it 18/200
eigen-it 19/200
eigen-it 20/200
eigen-it 21/200
eigen-it 22/200
eigen-it 23/200
eigen-it 24/200
eigen-it 25/200
eigen-it 26/200
eigen-it 27/200
eigen-it 28/200
eigen-it 29/200
eigen-it 30/200
eigen-it 31/200
Customize¶
fes = H1(mesh, order=10)
for ed in mesh.edges:
dofs = fes.GetDofNrs(ed)
for d in dofs:
max(lams)/min(lams)
call wirebasket inverse ( with 244 free dofs out of 11476 )
has inverse
eigen-it 0/200
eigen-it 1/200
eigen-it 2/200
eigen-it 3/200
eigen-it 4/200
eigen-it 5/200
eigen-it 6/200
eigen-it 7/200
eigen-it 8/200
eigen-it 9/200
eigen-it 10/200
eigen-it 11/200
eigen-it 12/200
eigen-it 13/200
eigen-it 14/200
eigen-it 15/200
eigen-it 16/200
eigen-it 17/200
eigen-it 18/200
eigen-it 19/200
eigen-it 20/200
eigen-it 21/200
eigen-it 22/200
eigen-it 23/200
eigen-it 24/200
eigen-it 25/200
eigen-it 26/200
eigen-it 27/200
eigen-it 28/200
eigen-it 29/200
18.178677170664105
max(lams)/min(lams)
call wirebasket inverse ( with 136 free dofs out of 11476 )
has inverse
27.35966282226837
eigen-it 0/200
eigen-it 1/200
eigen-it 2/200
eigen-it 3/200
eigen-it 4/200
eigen-it 5/200
eigen-it 6/200
eigen-it 7/200
eigen-it 8/200
eigen-it 9/200
eigen-it 10/200
eigen-it 11/200
eigen-it 12/200
eigen-it 13/200
eigen-it 14/200
eigen-it 15/200
eigen-it 16/200
eigen-it 17/200
eigen-it 18/200
eigen-it 19/200
eigen-it 20/200
eigen-it 21/200
eigen-it 22/200
eigen-it 23/200
eigen-it 24/200
eigen-it 25/200
eigen-it 26/200
eigen-it 27/200
eigen-it 28/200
eigen-it 29/200
eigen-it 30/200
p = 5
wb_withedges=False)
print("NDOF = ", fes.ndof)
f += v*dx
pre=pre, maxsteps=500)
Draw(gfu)
Start Findpoints
main-solids: 1
Found points 8
Analyze spec points
Find edges
12 edges found
CalcLocalH: 236 Points 0 Elements 0 Surface Elements
Start Findpoints
Analyze spec points
Find edges
12 edges found
Start Findpoints
Analyze spec points
Find edges
12 edges found
Surface 1 / 6
0 illegal triangles
Optimize Surface
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
922 elements, 658 points
Surface 2 / 6
0 illegal triangles
Optimize Surface
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
964 elements, 1101 points
Surface 3 / 6
0 illegal triangles
Optimize Surface
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
970 elements, 1547 points
Surface 4 / 6
0 illegal triangles
Optimize Surface
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
946 elements, 1981 points
Surface 5 / 6
0 illegal triangles
Optimize Surface
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
970 elements, 2427 points
Surface 6 / 6
0 illegal triangles
Optimize Surface
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
Smoothing
Combine improve
Smoothing
970 elements, 2873 points
SplitSeparateFaces
Use internal rules
Delaunay meshing
number of points: 2827
blockfill local h
number of points: 12268
Elements: 71430
Tree data entries per element: 1.69537
Tree nodes per element: 0.0338933
SwapImprove
SwapImprove
SwapImprove
SwapImprove
Remove intersecting
Remove outer
12268 points, 65567 elements
start tetmeshing
Use internal rules
Success !
Volume Optimization
CombineImprove
ImproveMesh
SplitImprove
ImproveMesh
SwapImprove
SwapImprove2
ImproveMesh
CombineImprove
ImproveMesh
SplitImprove
ImproveMesh
SwapImprove
SwapImprove2
ImproveMesh
CombineImprove
ImproveMesh
SplitImprove
ImproveMesh
SwapImprove
SwapImprove2
ImproveMesh
NDOF = 1170736
Update clusters
WARNING: kwarg 'coarsetype' is an undocumented flags option for class <class 'ngsolve.comp.Preconditioner'>, maybe there is a typo?
Create H1AMG
assemble VOL element 54420/54420
call wirebasket preconditioner finalize ( with 9346 free dofs out of 1170736 )
H1AMG: level = 0, num_edges = 58513, nv = 1170736
BlockJacobi Preconditioner, constructor called, #blocks = 4842
BlockJacobi Preconditioner built
H1AMG: level = 1, num_edges = 30950, nv = 4842
BlockJacobi Preconditioner, constructor called, #blocks = 2529
H1AMG: level = 2, num_edges = 16576, nv = 2529
BlockJacobi Preconditioner, constructor called, #blocks = 1328
H1AMG: level = 3, num_edges = 8692, nv = 1328
BlockJacobi Preconditioner, constructor called, #blocks = 696
H1AMG: level = 4, num_edges = 4505, nv = 696
BlockJacobi Preconditioner, constructor called, #blocks = 369
H1AMG: level = 5, num_edges = 2311, nv = 369
BlockJacobi Preconditioner, constructor called, #blocks = 192
H1AMG: level = 6, num_edges = 1133, nv = 192
BlockJacobi Preconditioner, constructor called, #blocks = 100
H1AMG: level = 7, num_edges = 553, nv = 100
BlockJacobi Preconditioner, constructor called, #blocks = 53
H1AMG: level = 8, num_edges = 271, nv = 53
BlockJacobi Preconditioner, constructor called, #blocks = 28
H1AMG: level = 9, num_edges = 126, nv = 28
BlockJacobi Preconditioner, constructor called, #blocks = 15
H1AMG: level = 10, num_edges = 54, nv = 15
BlockJacobi Preconditioner, constructor called, #blocks = 8
has inverse
WARNING: maxsteps is deprecated, use maxiter instead!
CG iteration 1, residual = 0.7094090868385201
CG iteration 2, residual = 0.277092354196473
CG iteration 3, residual = 0.2552141476493647
CG iteration 4, residual = 0.29760250572558
CG iteration 5, residual = 0.25515340506459033
CG iteration 6, residual = 0.19409338025273298
CG iteration 7, residual = 0.14466456735602215
CG iteration 8, residual = 0.11216525118555454
CG iteration 9, residual = 0.0795167297866193
CG iteration 10, residual = 0.05885836872647869
CG iteration 11, residual = 0.043432132001021806
CG iteration 12, residual = 0.03576010228039376
CG iteration 13, residual = 0.029804921900339124
CG iteration 14, residual = 0.021364235775509832
CG iteration 15, residual = 0.016395018482029945
CG iteration 16, residual = 0.013065067451515285
CG iteration 17, residual = 0.010281475047778715
CG iteration 18, residual = 0.0075161832386951115
CG iteration 19, residual = 0.005400599104160325
CG iteration 20, residual = 0.004159975246836071
CG iteration 21, residual = 0.0033356715080478648
CG iteration 22, residual = 0.0025567178563386563
CG iteration 23, residual = 0.0018863277812046933
CG iteration 24, residual = 0.0014480171690318302
CG iteration 25, residual = 0.0011583796766805852
CG iteration 26, residual = 0.0009066481187791878
CG iteration 27, residual = 0.0006879506314201771
CG iteration 28, residual = 0.0005269442608123841
CG iteration 29, residual = 0.0004011592733254342
CG iteration 30, residual = 0.0003150350082344221
CG iteration 31, residual = 0.0002498998602943328
CG iteration 32, residual = 0.00019082947428133485
CG iteration 33, residual = 0.0001431514175548389
CG iteration 34, residual = 0.0001117435655230187
CG iteration 35, residual = 8.567914626339054e-05
CG iteration 36, residual = 6.622157865058189e-05
CG iteration 37, residual = 5.077678888471302e-05
CG iteration 38, residual = 3.9347393964067174e-05
CG iteration 39, residual = 3.0699655930232356e-05
CG iteration 40, residual = 2.3329631346555676e-05
CG iteration 41, residual = 1.8101778951878397e-05
CG iteration 42, residual = 1.4422937256375272e-05
CG iteration 43, residual = 1.128070098701103e-05
CG iteration 44, residual = 8.67624883991305e-06
CG iteration 45, residual = 6.472767303048765e-06
CG iteration 46, residual = 5.003440601466715e-06
CG iteration 47, residual = 3.828388670957237e-06
CG iteration 48, residual = 2.928339674985158e-06
CG iteration 49, residual = 2.2656179101175973e-06
CG iteration 50, residual = 1.8273692600402287e-06
CG iteration 51, residual = 1.4226184082012495e-06
CG iteration 52, residual = 1.0818334558222385e-06
CG iteration 53, residual = 8.099502945603005e-07
CG iteration 54, residual = 6.09473074074458e-07
CG iteration 55, residual = 4.6194864798528714e-07
CG iteration 56, residual = 3.571209782788016e-07
CG iteration 57, residual = 2.7591527031657443e-07
CG iteration 58, residual = 2.182412897552229e-07
CG iteration 59, residual = 1.7485809206654988e-07
CG iteration 60, residual = 1.3431990604047457e-07
CG iteration 61, residual = 1.0077397347703597e-07
CG iteration 62, residual = 7.592589306656699e-08
CG iteration 63, residual = 5.952078091484223e-08
CG iteration 64, residual = 4.4861067028682956e-08
CG iteration 65, residual = 3.4204272871611885e-08
CG iteration 66, residual = 2.610924062797616e-08
CG iteration 67, residual = 1.9906599352018196e-08
CG iteration 68, residual = 1.5466948940629167e-08
CG iteration 69, residual = 1.1695566290271218e-08
CG iteration 70, residual = 8.963548384252506e-09
CG iteration 71, residual = 6.810820217702461e-09
CG iteration 72, residual = 5.212600493144689e-09
CG iteration 73, residual = 3.9848212512488375e-09
CG iteration 74, residual = 3.022515412432698e-09
CG iteration 75, residual = 2.299369048826489e-09
CG iteration 76, residual = 1.7707357293575882e-09
CG iteration 77, residual = 1.3495559669023768e-09
CG iteration 78, residual = 1.0254809347208245e-09
CG iteration 79, residual = 7.813152848881661e-10
CG iteration 80, residual = 6.02935469247742e-10
CG iteration 81, residual = 4.5959315327098883e-10
CG iteration 82, residual = 3.4386923428981863e-10
CG iteration 83, residual = 2.6574175505457817e-10
CG iteration 84, residual = 2.0321568056830468e-10
CG iteration 85, residual = 1.559833400122783e-10
CG iteration 86, residual = 1.2007149167737186e-10
CG iteration 87, residual = 9.753844388239724e-11
CG iteration 88, residual = 7.715165931082646e-11
CG iteration 89, residual = 5.86135120487688e-11
CG iteration 90, residual = 4.436208788493557e-11
CG iteration 91, residual = 3.399054505638281e-11
CG iteration 92, residual = 2.5650282759815758e-11
CG iteration 93, residual = 1.9751471755170407e-11
CG iteration 94, residual = 1.5010635692947355e-11
CG iteration 95, residual = 1.1254657180453063e-11
CG iteration 96, residual = 8.697086470015869e-12
CG iteration 97, residual = 6.646105916609159e-12
CG iteration 98, residual = 5.067918150282717e-12
CG iteration 99, residual = 3.791048771937065e-12
CG iteration 100, residual = 2.8942791634958148e-12
CG iteration 101, residual = 2.2093591918667863e-12
CG iteration 102, residual = 1.6751416406460215e-12
CG iteration 103, residual = 1.282319598981103e-12
CG iteration 104, residual = 9.832638543054068e-13
CG iteration 105, residual = 7.67093444418681e-13
CG iteration 106, residual = 6.068687645511326e-13
Postscript¶
fes = FESpace([fes_ho, fes_lo, fes_lam])
- 1*uho*dx
solvers.Newton(a=a, u=gfu)
Draw(gfu.components[0],deformation=True)
Boundary mesh done, np = 40
CalcLocalH: 40 Points 0 Elements 0 Surface Elements
Meshing domain 1 / 1
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
Smoothing
Split improve
Combine improve
Smoothing
Newton iteration 0
Update clusters
Assemble linearization
assemble VOL element 232/232
call umfpack ... done
err = 0.39392955469293095
Newton iteration 1
err = 1.7898870223932246e-15
