3.5 Scalar PDE on surfaces (with HDG)
In [1]:
%gui tk
Mesh of (only) the surface:
In [2]:
Out[2]:
In [3]:
In [4]:
order = 4
if order > 0:
    mesh.Curve(order)
Tangential velocity field:
In [5]:
Draw (b, mesh, "b")
eps = 5e-5
some local quantities
In [6]:
bn = InnerProduct(b,con)
Discretization
Surface FESpaces:
In [7]:
u,uE = fes.TrialFunction()
v,vE = fes.TestFunction()
surface gradients, co-normal derivatives and jumps:
In [8]:
gradu = u.Trace().Deriv()
gradv = v.Trace().Deriv()
jumpu = u - uE
jumpv = v - vE
Diffusion formulation (Hybrid Interior Penalty on Surface):
\[ \sum_T \int_T \nabla u \nabla v - \sum_T \int_{\partial T} n \nabla u (v-\widehat v) - \sum_T \int_{\partial T} n \nabla u (u-\widehat u) + \frac{\alpha p^2}{h} \sum_F \int_F (u-\widehat u)(v-\widehat v)\]
In [9]:
# diffusion
alpha = 10*(order+1)**2
a += SymbolicBFI(eps*gradu * gradv, VOL_or_BND = BND)
a += SymbolicBFI(- eps*dudn * jumpv,element_boundary=True, VOL_or_BND = BND)
a += SymbolicBFI(- eps*dvdn * jumpu,element_boundary=True, VOL_or_BND = BND)
a += SymbolicBFI(eps*alpha/h * jumpu * jumpv,element_boundary=True, VOL_or_BND = BND)
Convection formulation (Hybrid Upwinding):
\[ \sum_T \int_T - u \mathbf{w} \cdot \nabla v + \sum_T \int_{\partial T} (\mathbf{w} \cdot \mathbf{n}) u^{hyb-upw} v + \sum_T \int_{\partial T_{out}} (\mathbf{w} \cdot \mathbf{n}) (\hat{u} - u) \hat{v}\]
alt alt
In [10]:
# convection (surface version of Egger+Schöberl formulation:
a += SymbolicBFI(- u * InnerProduct(b,gradv), VOL_or_BND = BND)
a += SymbolicBFI(IfPos(bn, bn*u, bn*uE) * v, element_boundary = True, VOL_or_BND = BND)
a += SymbolicBFI(IfPos(bn, bn, 0) * (uE - u) * vE, element_boundary = True, VOL_or_BND = BND)
Mass matrix:
In [11]:
m = BilinearForm(fes)
\(M^\ast\)-matrix for implicit Euler
In [12]:
dt = 0.02
mstarinv = mstar.Inverse()
T = 8*pi
Time stepping
Visualization of solution (Deformation in normal direction)
In [13]:
res = gfu.vec.CreateVector()
The time loop
In [14]:
for i in range(int(T/dt)):
    res.data = m.mat * gfu.vec
    gfu.vec.data = mstarinv * res
Remark:
  • We can apply static condensation as in the volume
