5.5.2 Discontinuous Galerkin for the Wave Equation¶
universal element-matrices for the differntial operator \(B\)
cheaply invertible mass matrices (orthogonal polynomials, sum-factorization)
from time import time
sp = Sphere((0.5,0,0), 0.2)
shape = box-sp
geo = OCCGeometry(shape)
h = 0.1
mesh.Curve(3)
Draw(mesh);
order = 4
gfu = GridFunction(fes_u)
gfp = GridFunction(fes_p)
gftr = GridFunction(fes_tr)
ndof_p = 577150 + 522210 , ndof_u = 1731450
p = fes_p.TrialFunction()
v = fes_u.TestFunction()
phat = fes_tr.TrialFunction()
Bel.Assemble()
Btr.Assemble();
gfu.vec[:] = 0
scene = Draw (gftr, draw_vol=False, order=3, min=-0.05, max=0.05);
dt = 0.3 * h / (order+1)**2
tend = 1
op1 = dt * invmassu @ B
op2 = dt * invmassp @ B.T
cnt = 0
t = t+dt
gfu.vec.data += op1 * gfp.vec
gfp.vec.data -= op2 * gfu.vec
cnt = cnt+1
if cnt%10 == 0:
Time-stepping on the device¶
try:
import ngsolve.ngscuda
except:
gfu.vec[:] = 0
tend = 0.1
cnt = 0
t = t+dt
devu += op1 * devp
devp -= op2 * devu
cnt = cnt+1
if cnt%10 == 0:
gfp.vec.data = devp
print (op1.GetOperatorInfo())
ProductMatrix, h = 1731450, w = 577150
ScaleMatrix, scale = 0.001, h = 1731450, w = 1731450
SumMatrix, h = 1731450, w = 1731450
BlockDiagonalMatrixSoA (bs = 3x3, nze = 9, blocks = 577150), h = 1731450, w = 1731450
ProductMatrix, h = 1731450, w = 1731450
ProductMatrix, h = 1731450, w = 20250
Transpose, h = 1731450, w = 20250
ConstantEBEMatrix (blocks = 162, bs = 125x35), h = 20250, w = 1731450
BlockDiagonalMatrixSoA (bs = 3x3, nze = 9, blocks = 6750), h = 20250, w = 20250
ProductMatrix, h = 1731450, w = 20625
Transpose, h = 1731450, w = 20625
ConstantEBEMatrix (blocks = 165, bs = 125x35), h = 20625, w = 1731450
BlockDiagonalMatrixSoA (bs = 3x3, nze = 9, blocks = 6875), h = 20625, w = 20625
SumMatrix, h = 1731450, w = 577150
ConstantEBEMatrix (blocks = 8215, bs = 105x35), h = 1731450, w = 577150
ConstantEBEMatrix (blocks = 8275, bs = 105x35), h = 1731450, w = 577150
SumMatrix, h = 1731450, w = 522210
ConstantEBEMatrix (blocks = 8215, bs = 105x60), h = 1731450, w = 522210
ConstantEBEMatrix (blocks = 8275, bs = 105x60), h = 1731450, w = 522210
ProductMatrix, h = 522210, w = 577150
N4ngla14DiagonalMatrixIdEE, h = 522210, w = 522210
SumMatrix, h = 522210, w = 577150
ConstantEBEMatrix (blocks = 8215, bs = 60x35), h = 522210, w = 577150
ConstantEBEMatrix (blocks = 8275, bs = 60x35), h = 522210, w = 577150
ts = time()
steps = 10
for i in range(steps):
devu += op1 * devp
devp -= op2 * devu
te = time()
ndof = 577150 + 1731450 , time per step = 0.1222506046295166
On the A-100:
ndof = 651035 + 1953105 , time per step = 0.0023579835891723634Time-domain PML¶
tend = 15
tau = 2e-4
i = 0
sigma = 10 # pml damping parameter
t += tau
i += 1
if i%20 == 0:
ConstantEBEMatrix (blocks = 497, bs = 20x15), h = 18560, w = 13920
ConstantEBEMatrix (blocks = 431, bs = 20x15), h = 18560, w = 13920
ConstantEBEMatrix (blocks = 497, bs = 20x15), h = 18560, w = 7165
ConstantEBEMatrix (blocks = 431, bs = 20x15), h = 18560, w = 7165
ConstantEBEMatrix (blocks = 497, bs = 15x15), h = 7165, w = 13920
ConstantEBEMatrix (blocks = 431, bs = 15x15), h = 7165, w = 13920
