5.1 Poisson Equation in Parallel
netgen drawsolution.py
For proper parallel execution, Netgen/NGSolve must be configured with -DUSE_MPI=ON. Recent binaries for Linux and Mac are built with MPI support (?). If you are unsure, when your Netgen/NGSolve supports MPI, look for outputs like "Including MPI version 3.1" during Netgen startup.
MPI-parallel execution using ipyparallel
We start an MPI server:
from mpi4py.MPI import COMM_WORLD as comm
print (comm.rank, comm.size)
[stdout:1] 1 4
[stdout:0] 0 4
[stdout:3] 3 4
[stdout:2] 2 4
if comm.rank == 0:
print (mesh.GetNE(VOL))
[stdout:0] 56
[stdout:2] 62
[stdout:3] 57
[stdout:1] 55
inv = CGSolver(a.mat, pre.mat, printrates=comm.rank==0, maxiter=200, tol=1e-8)
gfu.vec.data = inv*f.vec
[stdout:0] CG iteration 1, residual = 0.05313636107212468
CG iteration 2, residual = 0.0732448385167346
CG iteration 3, residual = 0.06077337326925862
CG iteration 4, residual = 0.04965675927264466
CG iteration 5, residual = 0.046283992940999
CG iteration 6, residual = 0.0305156333154046
CG iteration 7, residual = 0.02589831756935775
CG iteration 8, residual = 0.016994550808865833
CG iteration 9, residual = 0.013010287656153193
CG iteration 10, residual = 0.011432088760998972
CG iteration 11, residual = 0.007816924495134901
CG iteration 12, residual = 0.0035098066609772546
CG iteration 13, residual = 0.0017387130849062836
CG iteration 14, residual = 0.001150230939682907
CG iteration 15, residual = 0.0008184957095722697
CG iteration 16, residual = 0.0005419630762720774
CG iteration 17, residual = 0.00038670700524591527
CG iteration 18, residual = 0.0002836742157757897
CG iteration 19, residual = 0.0001777343614941445
CG iteration 20, residual = 0.0001334115733419296
CG iteration 21, residual = 9.379683067760124e-05
CG iteration 22, residual = 6.550835827505403e-05
CG iteration 23, residual = 5.123579298412037e-05
CG iteration 24, residual = 3.536225147414007e-05
CG iteration 25, residual = 2.2782716580339245e-05
CG iteration 26, residual = 1.567745927863819e-05
CG iteration 27, residual = 1.111714958713394e-05
CG iteration 28, residual = 7.709451159724915e-06
CG iteration 29, residual = 5.474421176424685e-06
CG iteration 30, residual = 3.6876796657405144e-06
CG iteration 31, residual = 2.0833695750952362e-06
CG iteration 32, residual = 1.6564423874701038e-06
CG iteration 33, residual = 1.3736999959994751e-06
CG iteration 34, residual = 8.539631243749955e-07
CG iteration 35, residual = 4.6174975273227715e-07
CG iteration 36, residual = 2.9507200081461124e-07
CG iteration 37, residual = 1.9900657697862889e-07
CG iteration 38, residual = 1.426816159552515e-07
CG iteration 39, residual = 9.868137345829035e-08
CG iteration 40, residual = 7.020839769074936e-08
CG iteration 41, residual = 4.577071473315556e-08
CG iteration 42, residual = 2.9622799205858555e-08
CG iteration 43, residual = 1.9267023819949877e-08
CG iteration 44, residual = 1.368498086058468e-08
CG iteration 45, residual = 9.117459310034992e-09
CG iteration 46, residual = 5.918193053300161e-09
CG iteration 47, residual = 3.739344480396658e-09
CG iteration 48, residual = 2.413369403749435e-09
CG iteration 49, residual = 1.727053080611952e-09
CG iteration 50, residual = 1.1180335861724978e-09
CG iteration 51, residual = 7.628606217887044e-10
CG iteration 52, residual = 5.294659182819207e-10
The solution is distributed over the processes. Gather() is a collective operation that assembles the whole mesh and solution on the process with rank=0, while pickling (what c[:][...] does) transfers the local parts:
gfu_global = gfu.Gather()   # collective: whole solution on rank 0, None elsewhere
We pull the gathered solution from rank 0 to the client and draw it:
Draw (c[0]["gfu_global"]);
Pulling gfu from all engines gives the local parts; drawing gfu[n] shows the part that the process with rank=n possesses.
gfu = c[:]["gfu"]   # the local parts
Draw (gfu[3]);
fesL2 = L2(mesh, order=0)
gfL2 = GridFunction(fesL2)
gfL2_global = gfL2.Gather()
Draw (c[0]["gfL2_global"]);
