netgen drawsolution.py
For proper parallel execution, Netgen/NGSolve must be configured with -DUSE_MPI=ON. Recent binaries for Linux and Mac are built with MPI support (?). If you are unsure, when your Netgen/NGSolve supports MPI, look for outputs like "Including MPI version 3.1" during Netgen startup.
We start an MPI server:
from mpi4py.MPI import COMM_WORLD as comm
print (comm.rank, comm.size)
[stdout:1] 1 4
[stdout:3] 3 4
[stdout:0] 0 4
[stdout:2] 2 4
if comm.rank == 0:
print (mesh.GetNE(VOL))
[stdout:1] 73
[stdout:3] 78
[stdout:2] 79
[stdout:0] 0
inv = CGSolver(a.mat, pre.mat, printrates=comm.rank==0, maxiter=200, tol=1e-8)
gfu.vec.data = inv*f.vec
[stdout:0] CG iteration 1, residual = 0.05313636107212468
CG iteration 2, residual = 0.07324483851673459
CG iteration 3, residual = 0.06077337326925863
CG iteration 4, residual = 0.04965675927264464
CG iteration 5, residual = 0.04628399294099898
CG iteration 6, residual = 0.030515633315404585
CG iteration 7, residual = 0.02589831756935774
CG iteration 8, residual = 0.016994550808865805
CG iteration 9, residual = 0.013010287656153165
CG iteration 10, residual = 0.011432088760998946
CG iteration 11, residual = 0.007816924495134882
CG iteration 12, residual = 0.0035098066609772476
CG iteration 13, residual = 0.0017387130849062802
CG iteration 14, residual = 0.0011502309396829045
CG iteration 15, residual = 0.0008184957095722674
CG iteration 16, residual = 0.000541963076272076
CG iteration 17, residual = 0.00038670700524591413
CG iteration 18, residual = 0.0002836742157757889
CG iteration 19, residual = 0.00017773436149414384
CG iteration 20, residual = 0.00013341157334192922
CG iteration 21, residual = 9.379683067760112e-05
CG iteration 22, residual = 6.550835827505408e-05
CG iteration 23, residual = 5.123579298412055e-05
CG iteration 24, residual = 3.536225147414034e-05
CG iteration 25, residual = 2.2782716580339533e-05
CG iteration 26, residual = 1.567745927863846e-05
CG iteration 27, residual = 1.1117149587134172e-05
CG iteration 28, residual = 7.7094511597251e-06
CG iteration 29, residual = 5.474421176424848e-06
CG iteration 30, residual = 3.687679665740649e-06
CG iteration 31, residual = 2.083369575095347e-06
CG iteration 32, residual = 1.6564423874702285e-06
CG iteration 33, residual = 1.3736999959995924e-06
CG iteration 34, residual = 8.53963124375084e-07
CG iteration 35, residual = 4.6174975273232617e-07
CG iteration 36, residual = 2.9507200081463723e-07
CG iteration 37, residual = 1.9900657697865168e-07
CG iteration 38, residual = 1.4268161595529428e-07
CG iteration 39, residual = 9.868137345833924e-08
CG iteration 40, residual = 7.020839769079577e-08
CG iteration 41, residual = 4.5770714733193415e-08
CG iteration 42, residual = 2.9622799205882014e-08
CG iteration 43, residual = 1.9267023819964885e-08
CG iteration 44, residual = 1.3684980860578855e-08
CG iteration 45, residual = 9.117459310013975e-09
CG iteration 46, residual = 5.918193053268375e-09
CG iteration 47, residual = 3.739344480334424e-09
CG iteration 48, residual = 2.413369403627396e-09
CG iteration 49, residual = 1.7270530804331813e-09
CG iteration 50, residual = 1.118033585986379e-09
CG iteration 51, residual = 7.628606216200344e-10
CG iteration 52, residual = 5.294659181238074e-10
gfu = c[:]["gfu"]
Draw (gfu[0]);
Draw (gfu[3]);
fesL2 = L2(mesh, order=0)
gfL2 = GridFunction(fesL2)
gfL2 = c[:]["gfL2"]
Draw (gfL2[0]);
