This page was generated from unit-7-optimization/04_Topological_Derivative_Levelset.ipynb.
7.6 Topology Optimization based on the Topological DerivativeΒΆ
We are again interested in minimizing a shape function of the type
over all (admissible) shapes \(\Omega \subset \mathsf{D}\) with \(\mathsf{D}\) a given hold-all domain and \(f \in C(\overline{\mathsf{D}})\) a given function.
# module to generate the 2D geometry
from interpolations import InterpolateLevelSetToElems
The file interpolations.py can contains a routine to compute the volume ratio of each element with respect to a given level set function. The file can be downloaded from interpolations.py .
We define the domain \(\mathsf{D} = [-2, 2]^2\):
myMAXH = 0.05
R = 2
## add a rectangle
geo.AddRectangle(p1=(-R,-R),
                 p2=(R,R),
                 bc="rectangle",
                 leftdomain=1,
                 rightdomain=0)
mesh = Mesh(geo.GenerateMesh(maxh=myMAXH))
We represent the level set function \(\psi\) as a GridFunction on the mesh of \(\mathsf{D}\) and visualize the zero level set of the function \(f\).
fes = H1(mesh, order=1) # C0 conforming finite element space
pwc = L2(mesh)   # piecewise constant (on each element) space
psi = GridFunction(fes)       # level set function
psi.vec[:]=1
psi_new = GridFunction(fes)   # grid function for line search
a = 4.0/5.0
b = 2
e = 0.001
                * (sqrt(b * x**2 + (y + a)**2) - 1) - e) )
Draw(IfPos(f,0,1), mesh)
EPS = myMAXH * 1e-6      #variable defining when a point is on the interface and when not
def Cost(psi):
    return IfPos(psi,0,f)*dx
print("initial cost = ", Integrate(Cost(psi), mesh))
initial cost =  0.0
The evolution of the level set function is guided by the \(\textbf{topological derivative}\). We define and draw the topological derivative in \(\Omega\), \(\mathsf{D}\setminus \Omega\) and the generalized topological derivative \(g\).
TD_pwc = GridFunction(pwc)
CutRatio = GridFunction(pwc)
TD_node = GridFunction(fes)
scene1 = Draw(TD_node, mesh, "TD_node")
scene2 = Draw(TD_pwc, mesh, "TD_pwc")
kappaMax = 1
kappa = 0.1*kappaMax
We define \(\mathsf{NegPos}\) and \(\mathsf{PosNeg}\) as the topological derivative in \(\Omega\) and \(\mathsf{D}\setminus\overline{\Omega}\), respectively:
and the level set update function (also called generalized topological derivative)
TDNegPos_pwc.Set(f)
TDPosNeg_pwc.Set(f)
InterpolateLevelSetToElems(psi, 1, 0, CutRatio, mesh, EPS)
    TD_pwc.vec[j] = CutRatio.vec[j] * TDNegPos_pwc.vec[j] + (1-CutRatio.vec[j])*TDPosNeg_pwc.vec[j]
TD_node.Set(TD_pwc)
NormTD = sqrt(Integrate(TD_node**2*dx, mesh)) # L2 norm of TD_node
TD_node.vec.data = 1/NormTD * TD_node.vec
scene1.Redraw()
scene2.Redraw()
The idea now is to make a fixed point iteration for \(\ell\ge 0\)
Let us do one iteration:
scene3 = Draw(CutRatio, mesh)
kappaTest = 0.8
for k in range(3):
    psi.vec.data =  (1-kappaTest)*psi.vec + kappaTest * TD_node.vec
scene3.Redraw()
Now, let us repeat the procedure in the following iterative algorithm:
psi.Set(1)
scene_cr = Draw(CutRatio, mesh)
iter_max = 20
scene_cr.Redraw()
psi_new.vec.data = psi.vec
for k in range(iter_max):
        # copy new levelset data from psi_new into psi
        psi.vec.data = psi_new.vec
        scene_cr.Redraw()
        # current cost function value
        J_current = Integrate(Cost(psi),mesh)
        # level set update function
        TDPosNeg_pwc.Set(f)
        TDNegPos_pwc.Set(f)
        # get fraction of intersecting elements (for psi<0)
        # weight the topological derivative with CutRatio
        TD_node.Set(TD_pwc)
        psi.vec.data  =  (1-kappa)*psi.vec + kappa * TD_node.vec
        for j in range(10):
            psi_new.vec.data  =  (1-kappa)*psi.vec + kappa * TD_node.vec
            Jnew = Integrate(Cost(psi_new), mesh)
            print("----------- Jnew in  iteration ", k, " = ", Jnew, "(kappa = ", kappa, ")")
            print('')
            if Jnew <= J_current+1e-10:
                print("----------------------------")
                print("======= step accepted ======")
                kappa = min(1.1*kappa, kappaMax)
                break
                kappa = kappa*0.8
        print("iter" + str(k) + ", Jnew = " + str(Jnew) + "(kappa = ", kappa, ")")
================ iteration  0 ===================
cost in beginning of iteration 0 : Cost =  0.0
----------- Jnew in  iteration  0  =  0.0 (kappa =  0.1 )
iter0, Jnew = 0.0(kappa =  0.11000000000000001 )
end of iter 0
================ iteration  1 ===================
cost in beginning of iteration 1 : Cost =  0.0
----------- Jnew in  iteration  1  =  0.0 (kappa =  0.11000000000000001 )
iter1, Jnew = 0.0(kappa =  0.12100000000000002 )
end of iter 1
================ iteration  2 ===================
cost in beginning of iteration 2 : Cost =  0.0
----------- Jnew in  iteration  2  =  0.0 (kappa =  0.12100000000000002 )
iter2, Jnew = 0.0(kappa =  0.13310000000000002 )
end of iter 2
================ iteration  3 ===================
cost in beginning of iteration 3 : Cost =  0.0
----------- Jnew in  iteration  3  =  0.0 (kappa =  0.13310000000000002 )
iter3, Jnew = 0.0(kappa =  0.14641000000000004 )
end of iter 3
================ iteration  4 ===================
cost in beginning of iteration 4 : Cost =  0.0
----------- Jnew in  iteration  4  =  0.0 (kappa =  0.14641000000000004 )
iter4, Jnew = 0.0(kappa =  0.16105100000000006 )
end of iter 4
================ iteration  5 ===================
cost in beginning of iteration 5 : Cost =  0.0
----------- Jnew in  iteration  5  =  0.0 (kappa =  0.16105100000000006 )
iter5, Jnew = 0.0(kappa =  0.17715610000000007 )
end of iter 5
================ iteration  6 ===================
cost in beginning of iteration 6 : Cost =  0.0
----------- Jnew in  iteration  6  =  0.0 (kappa =  0.17715610000000007 )
iter6, Jnew = 0.0(kappa =  0.1948717100000001 )
end of iter 6
================ iteration  7 ===================
cost in beginning of iteration 7 : Cost =  0.0
----------- Jnew in  iteration  7  =  0.0 (kappa =  0.1948717100000001 )
iter7, Jnew = 0.0(kappa =  0.2143588810000001 )
end of iter 7
================ iteration  8 ===================
cost in beginning of iteration 8 : Cost =  0.0
----------- Jnew in  iteration  8  =  0.0 (kappa =  0.2143588810000001 )
iter8, Jnew = 0.0(kappa =  0.23579476910000013 )
end of iter 8
================ iteration  9 ===================
cost in beginning of iteration 9 : Cost =  0.0
----------- Jnew in  iteration  9  =  0.0 (kappa =  0.23579476910000013 )
iter9, Jnew = 0.0(kappa =  0.25937424601000014 )
end of iter 9
================ iteration  10 ===================
cost in beginning of iteration 10 : Cost =  0.0
----------- Jnew in  iteration  10  =  -0.05669364161907429 (kappa =  0.25937424601000014 )
iter10, Jnew = -0.05669364161907429(kappa =  0.28531167061100016 )
end of iter 10
================ iteration  11 ===================
cost in beginning of iteration 11 : Cost =  -0.05669364161907429
----------- Jnew in  iteration  11  =  -0.09395828820090642 (kappa =  0.28531167061100016 )
iter11, Jnew = -0.09395828820090642(kappa =  0.3138428376721002 )
end of iter 11
================ iteration  12 ===================
cost in beginning of iteration 12 : Cost =  -0.09395828820090642
----------- Jnew in  iteration  12  =  -0.10873188545899315 (kappa =  0.3138428376721002 )
iter12, Jnew = -0.10873188545899315(kappa =  0.3452271214393102 )
end of iter 12
================ iteration  13 ===================
cost in beginning of iteration 13 : Cost =  -0.10873188545899315
----------- Jnew in  iteration  13  =  -0.11398841292489859 (kappa =  0.3452271214393102 )
iter13, Jnew = -0.11398841292489859(kappa =  0.37974983358324127 )
end of iter 13
================ iteration  14 ===================
cost in beginning of iteration 14 : Cost =  -0.11398841292489859
----------- Jnew in  iteration  14  =  -0.11559719262617797 (kappa =  0.37974983358324127 )
iter14, Jnew = -0.11559719262617797(kappa =  0.41772481694156544 )
end of iter 14
================ iteration  15 ===================
cost in beginning of iteration 15 : Cost =  -0.11559719262617797
----------- Jnew in  iteration  15  =  -0.11600233851477758 (kappa =  0.41772481694156544 )
iter15, Jnew = -0.11600233851477758(kappa =  0.45949729863572203 )
end of iter 15
================ iteration  16 ===================
cost in beginning of iteration 16 : Cost =  -0.11600233851477758
----------- Jnew in  iteration  16  =  -0.11608384153972257 (kappa =  0.45949729863572203 )
iter16, Jnew = -0.11608384153972257(kappa =  0.5054470284992942 )
end of iter 16
================ iteration  17 ===================
cost in beginning of iteration 17 : Cost =  -0.11608384153972257
----------- Jnew in  iteration  17  =  -0.11613377612863536 (kappa =  0.5054470284992942 )
iter17, Jnew = -0.11613377612863536(kappa =  0.5559917313492238 )
end of iter 17
================ iteration  18 ===================
cost in beginning of iteration 18 : Cost =  -0.11613377612863536
----------- Jnew in  iteration  18  =  -0.11613635207766497 (kappa =  0.5559917313492238 )
iter18, Jnew = -0.11613635207766497(kappa =  0.6115909044841462 )
end of iter 18
================ iteration  19 ===================
cost in beginning of iteration 19 : Cost =  -0.11613635207766497
----------- Jnew in  iteration  19  =  -0.11613642191697138 (kappa =  0.6115909044841462 )
iter19, Jnew = -0.11613642191697138(kappa =  0.6727499949325609 )
end of iter 19
