This page was generated from unit-7-optimization/03b_Shape_Derivative_Laplace_FullyAuto.ipynb.
7.5 PDE-Constrained Shape Optimization (fully automated)¶
where \(\Omega \subset \mathbb R^2\) for given \(u_d, f \in C^1(\mathbb R^2)\).
Again, we want to compute the shape derivative by differentiation of a suitably defined perturbed Lagrangian using automated differentiation. Here this is accounted for automatically by NGSolve. For details we refer to
- Gangl, K. Sturm, M. Neunteufel, J. Schöberl. Fully and Semi-Automated Shape Differentiation in NGSolve, Struct. Multidisc. Optim., 63, pp.1579-1607, 2021.
from ngsolve.solvers import *
ud = x*(1-x)*y*(1-y)
gfp = GridFunction(fes)
- \(T_t(x)=x+tX(x)=y\)
- \(F_t = DT_t = I+t DX\)
- \(u_d^t = u_d \circ T_t\)
- \(f^t = f \circ T_t\)
The integrand depends on the parameter \(t\) only via \(F_t\) and \(T_t\). We define the Lagrangian in this form, involving a parameter t that has the value 0.
In order to define the perturbed Lagrangian for a given problem, one needs to know transformation rules of differential operators, e.g.,
for \(u \in H^1\).¶
Since these transformation rules are known by NGSolve for all implemented differential operators, also the step of defining the perturbed Lagrangian can be automated.¶
PHI, X = VEC.TnT()
def EquationFA(u,v):
    return ( grad(u)*grad(v)-f*v)*dx
q=4
def CostAutoFA(u):
    return (u-ud)**q*dx
def CostAuto2(u):
    return CostAutoFA(u)
LagrangianFA = CostAutoFA(gfu) + EquationFA(gfu,gfp)
State equation¶
Equation can also be used to define the bilinear form. The following defines left and right hand side of the PDE in a “BilinearForm”:
u, v = fes.TnT()
aAuto += EquationFA(u,v)
gfu.vec[:]=0
scene_u.Redraw()
Newton iteration  0
err =  0.13042435973102348
Newton iteration  1
err =  1.1032913546772452e-16
Adjoint equation¶
where \(u\) is the solution to the state equation. For \(J(u) = \int_\Omega |u-u_d|^2 \mbox dx\), we get
p, w = fes.TnT()
fadjoint = LinearForm(fes)
fadjoint += -1*(CostAutoFA(gfu)).Diff(gfu,w)
def SolveAdjointEquation():
    rhs = gfp.vec.CreateVector()
    gfp.vec.data += update
fadjoint.Assemble()
scene_p.Redraw()
Denoting the integrand by \(G^{u,p}\), the shape derivative is given by
The command .DiffShape(…) computes the shape derivative by automatically accounting for the corresponding transformations.
dJOmegaAuto = LinearForm(VEC)
dJOmegaAuto += LagrangianFA.DiffShape(X)
b = BilinearForm(VEC)
gfX = GridFunction(VEC)
    rhs = gfX.vec.CreateVector()
    gfX.vec.data += update
b.Assemble()
dJOmegaAuto.Assemble()
Draw(-gfX, mesh, "-gfX")
gfset = GridFunction(VEC)
gfset.Set((0,0))
mesh.SetDeformation(gfset)
gfset.Set((0,0))
scale = 0.5 / Norm(gfX.vec)
sceneSet.Redraw()
Cost at initial design 5.152244130814755e-09
gfu.vec[:]=0
Newton iteration  0
err =  0.1539571560737845
Newton iteration  1
err =  1.2635277035484454e-16
Cost at new design 9.793297083297818e-10
scene_u = Draw(gfu)
gfset.Set((0,0))
scene_u.Redraw()
gfu.vec[:]=0
LineSearch = False
iter_max = 600
converged = False
for k in range(iter_max):
    scene_u.Redraw()
    gfu.vec[:]=0
    fadjoint.Assemble()
    b.Assemble()
    scale = 0.01 / Norm(gfX.vec)
    gfsetOld = gfset
    if LineSearch:
            # input('a')
            scale = scale / 2
            if scale <= 1e-12:
                converged = True
                break
            gfu.vec[:]=0
    if converged==True:
        break
    Jold = Jnew
Newton iteration  0
Newton iteration  1
cost at iteration 0 :  5.152244130814755e-09
cost at iteration 1 :  4.942040315052278e-09
cost at iteration 2 :  4.585081411492748e-09
cost at iteration 3 :  4.249440980557088e-09
cost at iteration 4 :  3.934230926246944e-09
cost at iteration 5 :  3.6385762619912925e-09
cost at iteration 6 :  3.3616160503340724e-09
cost at iteration 7 :  3.1025043360794835e-09
cost at iteration 8 :  2.8604110705929723e-09
cost at iteration 9 :  2.6345230245966513e-09
cost at iteration 10 :  2.4240446863394626e-09
cost at iteration 11 :  2.2281991414270806e-09
cost at iteration 12 :  2.0462289298150803e-09
cost at iteration 13 :  1.8773968744302318e-09
cost at iteration 14 :  1.7209868744933654e-09
cost at iteration 15 :  1.5763046547393895e-09
cost at iteration 16 :  1.4426784591830562e-09
cost at iteration 17 :  1.3194596746124644e-09
cost at iteration 18 :  1.2060233642634607e-09
cost at iteration 19 :  1.1017686856714432e-09
cost at iteration 20 :  1.006119157883454e-09
cost at iteration 21 :  9.185227311982654e-10
cost at iteration 22 :  8.384515962699072e-10
cost at iteration 23 :  7.654016473209058e-10
cost at iteration 24 :  6.988914845968648e-10
cost at iteration 25 :  6.384608021036904e-10
cost at iteration 26 :  5.836679565498961e-10
cost at iteration 27 :  5.340864528118764e-10
cost at iteration 28 :  4.893000172852372e-10
cost at iteration 29 :  4.488958881947119e-10
cost at iteration 30 :  4.1245600135970885e-10
cost at iteration 31 :  3.7954606800853276e-10
cost at iteration 32 :  3.497035385815598e-10
cost at iteration 33 :  3.224279626838391e-10
cost at iteration 34 :  2.9718256556606e-10
cost at iteration 35 :  2.734241271728054e-10
cost at iteration 36 :  2.5068184304177957e-10
cost at iteration 37 :  2.286790598505091e-10
cost at iteration 38 :  2.0741713926515882e-10
cost at iteration 39 :  1.8711167400729794e-10
cost at iteration 40 :  1.6801624125408654e-10
cost at iteration 41 :  1.502955210288288e-10
cost at iteration 42 :  1.340064930638265e-10
cost at iteration 43 :  1.19130676829076e-10
cost at iteration 44 :  1.0560796580779415e-10
cost at iteration 45 :  9.335887914179761e-11
cost at iteration 46 :  8.229695729942483e-11
cost at iteration 47 :  7.233508979947753e-11
cost at iteration 48 :  6.338852880933332e-11
cost at iteration 49 :  5.53762094979999e-11
cost at iteration 50 :  4.8221248852235816e-11
cost at iteration 51 :  4.185106579754666e-11
cost at iteration 52 :  3.619733722937543e-11
cost at iteration 53 :  3.119588920801157e-11
cost at iteration 54 :  2.678656684957822e-11
cost at iteration 55 :  2.2913100695693302e-11
cost at iteration 56 :  1.952297596730753e-11
cost at iteration 57 :  1.656730628871613e-11
cost at iteration 58 :  1.4000711487116359e-11
cost at iteration 59 :  1.178119825449867e-11
cost at iteration 60 :  9.870042108059449e-12
cost at iteration 61 :  8.231668931388936e-12
cost at iteration 62 :  6.833534355412221e-12
cost at iteration 63 :  5.6459993089751435e-12
cost at iteration 64 :  4.642200293031801e-12
cost at iteration 65 :  3.797913225654571e-12
cost at iteration 66 :  3.091410276890533e-12
cost at iteration 67 :  2.5033094982807547e-12
cost at iteration 68 :  2.016418297374456e-12
cost at iteration 69 :  1.6155712170698355e-12
cost at iteration 70 :  1.2874668507720771e-12
cost at iteration 71 :  1.020499624339473e-12
cost at iteration 72 :  8.046147979342341e-13
cost at iteration 73 :  6.311813221604381e-13
cost at iteration 74 :  4.93956252135218e-13
cost at iteration 75 :  4.0069968796176774e-13
cost at iteration 76 :  3.6532623445353007e-13
cost at iteration 77 :  3.3593359233371227e-13
cost at iteration 78 :  3.0631953000974726e-13
cost at iteration 79 :  2.813141392558361e-13
cost at iteration 80 :  2.5730205363498936e-13
cost at iteration 81 :  2.362812098140028e-13
cost at iteration 82 :  2.1662119785427133e-13
cost at iteration 83 :  1.9907535315039381e-13
cost at iteration 84 :  1.8289671605245518e-13
cost at iteration 85 :  1.6830618822972515e-13
cost at iteration 86 :  1.5495410624076236e-13
cost at iteration 87 :  1.4284167840514353e-13
cost at iteration 88 :  1.3179948435191064e-13
cost at iteration 89 :  1.217465007635225e-13
cost at iteration 90 :  1.1259523680001342e-13
cost at iteration 91 :  1.0424243497871883e-13
cost at iteration 92 :  9.663764815316792e-14
cost at iteration 93 :  8.968086864764175e-14
cost at iteration 94 :  8.33382259691679e-14
cost at iteration 95 :  7.752294900328171e-14
cost at iteration 96 :  7.22084998919889e-14
cost at iteration 97 :  6.732431060963118e-14
cost at iteration 98 :  6.284703955285466e-14
cost at iteration 99 :  5.872210257639473e-14
cost at iteration 100 :  5.49274893967604e-14
cost at iteration 101 :  5.142299341319673e-14
cost at iteration 102 :  4.818706323822081e-14
cost at iteration 103 :  4.5191766532533105e-14
cost at iteration 104 :  4.24155839846094e-14
cost at iteration 105 :  3.9840711958843525e-14
cost at iteration 106 :  3.7445459175591916e-14
cost at iteration 107 :  3.522018518447113e-14
cost at iteration 108 :  3.3142952164439624e-14
cost at iteration 109 :  3.1210587469709204e-14
cost at iteration 110 :  2.940091441080398e-14
cost at iteration 111 :  2.771581952228771e-14
cost at iteration 112 :  2.61329456982612e-14
cost at iteration 113 :  2.465809684917647e-14
cost at iteration 114 :  2.326882024196241e-14
cost at iteration 115 :  2.1973927974535282e-14
cost at iteration 116 :  2.0750963539515396e-14
cost at iteration 117 :  1.961103437513113e-14
cost at iteration 118 :  1.8531764512889715e-14
cost at iteration 119 :  1.7526007672328436e-14
cost at iteration 120 :  1.657153470377385e-14
cost at iteration 121 :  1.568253362246902e-14
cost at iteration 122 :  1.4836963345957273e-14
cost at iteration 123 :  1.4050050486482587e-14
cost at iteration 124 :  1.3299954409550846e-14
cost at iteration 125 :  1.2602744567303449e-14
cost at iteration 126 :  1.1936763657242363e-14
cost at iteration 127 :  1.1318811579019632e-14
cost at iteration 128 :  1.072736939855704e-14
cost at iteration 129 :  1.0179907205394057e-14
cost at iteration 130 :  9.654968186252952e-15
cost at iteration 131 :  9.170601791713069e-15
cost at iteration 132 :  8.705283672875018e-15
cost at iteration 133 :  8.277358316187091e-15
cost at iteration 134 :  7.865086433789656e-15
cost at iteration 135 :  7.486597714807718e-15
cost at iteration 136 :  7.120161201993475e-15
cost at iteration 137 :  6.783380539341893e-15
cost at iteration 138 :  6.4554213613274076e-15
cost at iteration 139 :  6.153307032715954e-15
cost at iteration 140 :  5.857846171605797e-15
cost at iteration 141 :  5.585255421360014e-15
cost at iteration 142 :  5.318087733639911e-15
cost at iteration 143 :  5.0715029721533015e-15
cost at iteration 144 :  4.829601959465964e-15
cost at iteration 145 :  4.60642035050274e-15
cost at iteration 146 :  4.3873779720308446e-15
cost at iteration 147 :  4.185460324563698e-15
cost at iteration 148 :  3.987201654020076e-15
cost at iteration 149 :  3.804668869943904e-15
cost at iteration 150 :  3.625332712987106e-15
cost at iteration 151 :  3.4604830808710208e-15
cost at iteration 152 :  3.298373431603231e-15
cost at iteration 153 :  3.1496484517213518e-15
cost at iteration 154 :  3.003212523388029e-15
cost at iteration 155 :  2.8691805522983385e-15
cost at iteration 156 :  2.7369958749252393e-15
cost at iteration 157 :  2.6163416569510592e-15
cost at iteration 158 :  2.497105756609314e-15
cost at iteration 159 :  2.388621461381891e-15
cost at iteration 160 :  2.281141947864655e-15
cost at iteration 161 :  2.1837183644674698e-15
cost at iteration 162 :  2.0869029976199324e-15
cost at iteration 163 :  1.9995208356621336e-15
cost at iteration 164 :  1.9123679177196125e-15
cost at iteration 165 :  1.834089754534065e-15
cost at iteration 166 :  1.755679522617587e-15
cost at iteration 167 :  1.6856430604041145e-15
cost at iteration 168 :  1.6151306583341845e-15
cost at iteration 169 :  1.5525435351693323e-15
cost at iteration 170 :  1.489153516494799e-15
cost at iteration 171 :  1.4332889384971723e-15
cost at iteration 172 :  1.37631025286734e-15
cost at iteration 173 :  1.326501712394544e-15
cost at iteration 174 :  1.2752815739136015e-15
cost at iteration 175 :  1.230915176674395e-15
cost at iteration 176 :  1.1848513720004993e-15
cost at iteration 177 :  1.145356899951777e-15
cost at iteration 178 :  1.1038909947113941e-15
cost at iteration 179 :  1.068736099827871e-15
cost at iteration 180 :  1.031351380732268e-15
cost at iteration 181 :  1.000042412518301e-15
cost at iteration 182 :  9.662668218431575e-16
cost at iteration 183 :  9.383539293358188e-16
cost at iteration 184 :  9.07763429374051e-16
cost at iteration 185 :  8.828441551689815e-16
cost at iteration 186 :  8.550625974563028e-16
cost at iteration 187 :  8.327812584676045e-16
cost at iteration 188 :  8.074770468329984e-16
cost at iteration 189 :  7.875212308794483e-16
cost at iteration 190 :  7.644029236513191e-16
cost at iteration 191 :  7.464991155504614e-16
cost at iteration 192 :  7.253112095667482e-16
cost at iteration 193 :  7.092204830477113e-16
cost at iteration 194 :  6.897395570509903e-16
cost at iteration 195 :  6.752535365586823e-16
cost at iteration 196 :  6.572846420380502e-16
cost at iteration 197 :  6.442217674173144e-16
cost at iteration 198 :  6.275950288153354e-16
cost at iteration 199 :  6.157971486907068e-16
cost at iteration 200 :  6.003646065295487e-16
cost at iteration 201 :  5.896939147617833e-16
cost at iteration 202 :  5.753266529055541e-16
cost at iteration 203 :  5.656629648525032e-16
cost at iteration 204 :  5.522485432841758e-16
cost at iteration 205 :  5.434868970557214e-16
cost at iteration 206 :  5.309270903593028e-16
cost at iteration 207 :  5.229756520217333e-16
cost at iteration 208 :  5.111844788210232e-16
cost at iteration 209 :  5.039627265672815e-16
cost at iteration 210 :  4.928647464639906e-16
cost at iteration 211 :  4.863019062236491e-16
cost at iteration 212 :  4.758307566548698e-16
cost at iteration 213 :  4.69864460582065e-16
cost at iteration 214 :  4.599616049685518e-16
cost at iteration 215 :  4.545367447047628e-16
cost at iteration 216 :  4.451504041589872e-16
cost at iteration 217 :  4.402181523985649e-16
cost at iteration 218 :  4.313023952938707e-16
cost at iteration 219 :  4.2681937154120003e-16
cost at iteration 220 :  4.18333337841836e-16
cost at iteration 221 :  4.142608969441484e-16
cost at iteration 222 :  4.0616813697836937e-16
cost at iteration 223 :  4.0247176176108833e-16
cost at iteration 224 :  3.947396718474931e-16
cost at iteration 225 :  3.913884537896246e-16
cost at iteration 226 :  3.839877936637445e-16
cost at iteration 227 :  3.8095398793175445e-16
cost at iteration 228 :  3.7385846719914517e-16
cost at iteration 229 :  3.7111711046764604e-16
cost at iteration 230 :  3.6430303330924563e-16
cost at iteration 231 :  3.6183161462893858e-16
cost at iteration 232 :  3.552775737090254e-16
cost at iteration 233 :  3.53055750250636e-16
cost at iteration 234 :  3.467423622466467e-16
cost at iteration 235 :  3.4475171307783245e-16
cost at iteration 236 :  3.3866138949137253e-16
cost at iteration 237 :  3.36885201660068e-16
cost at iteration 238 :  3.310019496078094e-16
cost at iteration 239 :  3.294250317391147e-16
cost at iteration 240 :  3.2373428028973057e-16
cost at iteration 241 :  3.223427996808998e-16
cost at iteration 242 :  3.1683124802504406e-16
cost at iteration 243 :  3.1561258786948706e-16
cost at iteration 244 :  3.102680722082403e-16
cost at iteration 245 :  3.0921070611575404e-16
cost at iteration 246 :  3.0402208264853494e-16
cost at iteration 247 :  3.0311546407413413e-16
cost at iteration 248 :  2.980725058779456e-16
cost at iteration 249 :  2.973069704412481e-16
cost at iteration 250 :  2.924002763735764e-16
cost at iteration 251 :  2.917669553579092e-16
cost at iteration 252 :  2.8698786939843626e-16
cost at iteration 253 :  2.8647861297476477e-16
cost at iteration 254 :  2.8181915265626143e-16
cost at iteration 255 :  2.814264615905192e-16
cost at iteration 256 :  2.7687925436563357e-16
cost at iteration 257 :  2.765962191469185e-16
cost at iteration 258 :  2.721544457017867e-16
cost at iteration 259 :  2.719746921789176e-16
cost at iteration 260 :  2.6763203584253904e-16
cost at iteration 261 :  2.6754967658283687e-16
cost at iteration 262 :  2.633002780974808e-16
cost at iteration 263 :  2.6330986878848207e-16
cost at iteration 264 :  2.5914828580476315e-16
cost at iteration 265 :  2.5924478611010846e-16
cost at iteration 266 :  2.5516595685422155e-16
cost at iteration 267 :  2.5534469521196527e-16
cost at iteration 268 :  2.5134390584369694e-16
cost at iteration 269 :  2.5160054776114603e-16
cost at iteration 270 :  2.476734030026047e-16
cost at iteration 271 :  2.480039224580081e-16
cost at iteration 272 :  2.4414631912543074e-16
cost at iteration 273 :  2.445469727352708e-16
cost at iteration 274 :  2.4075507585161325e-16
cost at iteration 275 :  2.412223795040018e-16
cost at iteration 276 :  2.374926007091588e-16
cost at iteration 277 :  2.3802330839977447e-16
cost at iteration 278 :  2.3435228640930995e-16
cost at iteration 279 :  2.349433710476206e-16
cost at iteration 280 :  2.313279539403841e-16
cost at iteration 281 :  2.3197658992103472e-16
cost at iteration 282 :  2.2841381906186576e-16
cost at iteration 283 :  2.2911736641966854e-16
cost at iteration 284 :  2.2560446184583965e-16
cost at iteration 285 :  2.263604518335287e-16
cost at iteration 286 :  2.2289479895331227e-16
cost at iteration 287 :  2.2370092089920973e-16
cost at iteration 288 :  2.2028005836816057e-16
cost at iteration 289 :  2.211341476867625e-16
cost at iteration 290 :  2.177557563424833e-16
cost at iteration 291 :  2.1865578358484542e-16
cost at iteration 292 :  2.1531767633438008e-16
cost at iteration 293 :  2.1626173717744342e-16
cost at iteration 294 :  2.129618497429882e-16
cost at iteration 295 :  2.1394815582775739e-16
cost at iteration 296 :  2.106845382669325e-16
cost at iteration 297 :  2.117114088049377e-16
cost at iteration 298 :  2.084822177307495e-16
cost at iteration 299 :  2.0954807180667577e-16
cost at iteration 300 :  2.0635156324052146e-16
cost at iteration 301 :  2.074549127463097e-16
cost at iteration 302 :  2.0428943554432462e-16
cost at iteration 303 :  2.054288786867309e-16
cost at iteration 304 :  2.02292868486198e-16
cost at iteration 305 :  2.0346708381560452e-16
cost at iteration 306 :  2.003590574536323e-16
cost at iteration 307 :  2.0156679836722095e-16
cost at iteration 308 :  1.9848534872881043e-16
cost at iteration 309 :  1.9972543840580599e-16
cost at iteration 310 :  1.9666922966294682e-16
cost at iteration 311 :  1.9794055639382435e-16
cost at iteration 312 :  1.9490831960090889e-16
cost at iteration 313 :  1.9620983247620176e-16
cost at iteration 314 :  1.9320036149074642e-16
cost at iteration 315 :  1.9453106641831628e-16
cost at iteration 316 :  1.915432141189064e-16
cost at iteration 317 :  1.929021701416612e-16
cost at iteration 318 :  1.8993484491780614e-16
cost at iteration 319 :  1.91321160806339e-16
cost at iteration 320 :  1.8837332329740127e-16
cost at iteration 321 :  1.897861543945748e-16
cost at iteration 322 :  1.8685681445707627e-16
cost at iteration 323 :  1.882953597535833e-16
cost at iteration 324 :  1.8538357363818973e-16
cost at iteration 325 :  1.868470730601307e-16
cost at iteration 326 :  1.8395194078132165e-16
cost at iteration 327 :  1.8543967267257712e-16
cost at iteration 328 :  1.8256033555558716e-16
cost at iteration 329 :  1.840716143392266e-16
cost at iteration 330 :  1.8120725273024697e-16
cost at iteration 331 :  1.8274142673477357e-16
cost at iteration 332 :  1.7989125786168902e-16
cost at iteration 333 :  1.8144770729901766e-16
cost at iteration 334 :  1.7861098327105632e-16
cost at iteration 335 :  1.8018911835440922e-16
cost at iteration 336 :  1.7736512429008652e-16
cost at iteration 337 :  1.7896438348094528e-16
cost at iteration 338 :  1.7615243575469994e-16
cost at iteration 339 :  1.7777228412889254e-16
cost at iteration 340 :  1.7497172872751006e-16
cost at iteration 341 :  1.7661165645140957e-16
cost at iteration 342 :  1.7382186743219116e-16
cost at iteration 343 :  1.7548138834067222e-16
cost at iteration 344 :  1.7270176638394794e-16
cost at iteration 345 :  1.7438041665255903e-16
cost at iteration 346 :  1.716103877017322e-16
cost at iteration 347 :  1.7330772460607335e-16
cost at iteration 348 :  1.705467385889892e-16
cost at iteration 349 :  1.7226233934491907e-16
cost at iteration 350 :  1.6950986897084905e-16
cost at iteration 351 :  1.7124332964960203e-16
cost at iteration 352 :  1.6849886927655137e-16
cost at iteration 353 :  1.7024980378942255e-16
cost at iteration 354 :  1.6751286835698694e-16
cost at iteration 355 :  1.6928090750454317e-16
cost at iteration 356 :  1.6655103152777893e-16
cost at iteration 357 :  1.6833582210904976e-16
cost at iteration 358 :  1.6561255872933702e-16
cost at iteration 359 :  1.6741376270676612e-16
cost at iteration 360 :  1.6469668279581655e-16
cost at iteration 361 :  1.6651397651204292e-16
cost at iteration 362 :  1.6380266782560876e-16
cost at iteration 363 :  1.6563574126849188e-16
cost at iteration 364 :  1.6292980764649788e-16
cost at iteration 365 :  1.6477836375909592e-16
cost at iteration 366 :  1.6207742436926169e-16
cost at iteration 367 :  1.6394117840163404e-16
cost at iteration 368 :  1.612448670237781e-16
cost at iteration 369 :  1.6312354592379231e-16
cost at iteration 370 :  1.6043151027230589e-16
cost at iteration 371 :  1.6232485211282463e-16
cost at iteration 372 :  1.5963675319490105e-16
cost at iteration 373 :  1.6154450663488603e-16
cost at iteration 374 :  1.5886001814236088e-16
cost at iteration 375 :  1.607819419196419e-16
cost at iteration 376 :  1.581007496523423e-16
cost at iteration 377 :  1.600366121059598e-16
cost at iteration 378 :  1.573584134247284e-16
cost at iteration 379 :  1.5930799204487625e-16
cost at iteration 380 :  1.5663249535246758e-16
cost at iteration 381 :  1.5859557635625164e-16
cost at iteration 382 :  1.5592250060449067e-16
cost at iteration 383 :  1.578988785358092e-16
cost at iteration 384 :  1.5522795275746197e-16
cost at iteration 385 :  1.5721743010943196e-16
cost at iteration 386 :  1.545483929733887e-16
cost at iteration 387 :  1.5655077983190013e-16
cost at iteration 388 :  1.5388337922034422e-16
cost at iteration 389 :  1.5589849292733725e-16
cost at iteration 390 :  1.5323248553364327e-16
cost at iteration 391 :  1.5526015036890363e-16
cost at iteration 392 :  1.5259530131514328e-16
cost at iteration 393 :  1.5463534819539692e-16
cost at iteration 394 :  1.519714306683414e-16
cost at iteration 395 :  1.5402369686257138e-16
cost at iteration 396 :  1.5136049176720607e-16
cost at iteration 397 :  1.5342482062719942e-16
cost at iteration 398 :  1.507621162567934e-16
cost at iteration 399 :  1.5283835696191118e-16
cost at iteration 400 :  1.5017594868376105e-16
cost at iteration 401 :  1.522639559991077e-16
cost at iteration 402 :  1.4960164595511616e-16
cost at iteration 403 :  1.5170128000223407e-16
cost at iteration 404 :  1.490388768235791e-16
cost at iteration 405 :  1.511500028629215e-16
cost at iteration 406 :  1.4848732139803188e-16
cost at iteration 407 :  1.5060980962249925e-16
cost at iteration 408 :  1.4794667067769754e-16
cost at iteration 409 :  1.5008039601653875e-16
cost at iteration 410 :  1.4741662610867683e-16
cost at iteration 411 :  1.4956146804116271e-16
cost at iteration 412 :  1.4689689916166778e-16
cost at iteration 413 :  1.4905274153992265e-16
cost at iteration 414 :  1.4638721092964152e-16
cost at iteration 415 :  1.4855394181009474e-16
cost at iteration 416 :  1.4588729174445549e-16
cost at iteration 417 :  1.4806480322741804e-16
cost at iteration 418 :  1.4539688081132964e-16
cost at iteration 419 :  1.4758506888820118e-16
cost at iteration 420 :  1.4491572586027806e-16
cost at iteration 421 :  1.4711449026791168e-16
cost at iteration 422 :  1.4444358281352863e-16
cost at iteration 423 :  1.466528268954105e-16
cost at iteration 424 :  1.4398021546816736e-16
cost at iteration 425 :  1.461998460419411e-16
cost at iteration 426 :  1.4352539519314843e-16
cost at iteration 427 :  1.4575532242416232e-16
cost at iteration 428 :  1.4307890063993644e-16
cost at iteration 429 :  1.4531903792045772e-16
cost at iteration 430 :  1.4264051746609958e-16
cost at iteration 431 :  1.448907812998836e-16
cost at iteration 432 :  1.422100380711507e-16
cost at iteration 433 :  1.4447034796307567e-16
cost at iteration 434 :  1.4178726134406617e-16
cost at iteration 435 :  1.4405753969450002e-16
cost at iteration 436 :  1.4137199242182229e-16
cost at iteration 437 :  1.4365216442554282e-16
cost at iteration 438 :  1.4096404245845823e-16
cost at iteration 439 :  1.4325403600781014e-16
cost at iteration 440 :  1.4056322840410944e-16
cost at iteration 441 :  1.4286297399620154e-16
cost at iteration 442 :  1.4016937279350806e-16
cost at iteration 443 :  1.4247880344123527e-16
cost at iteration 444 :  1.3978230354352747e-16
cost at iteration 445 :  1.4210135469018721e-16
cost at iteration 446 :  1.3940185375926494e-16
cost at iteration 447 :  1.4173046319662653e-16
cost at iteration 448 :  1.3902786154831572e-16
cost at iteration 449 :  1.413659693379161e-16
cost at iteration 450 :  1.3866016984278686e-16
cost at iteration 451 :  1.4100771824031117e-16
cost at iteration 452 :  1.3829862622871232e-16
cost at iteration 453 :  1.4065555961131503e-16
cost at iteration 454 :  1.3794308278250947e-16
cost at iteration 455 :  1.4030934757888363e-16
cost at iteration 456 :  1.3759339591412937e-16
cost at iteration 457 :  1.3996894053725365e-16
cost at iteration 458 :  1.372494262166191e-16
cost at iteration 459 :  1.396342009989731e-16
cost at iteration 460 :  1.3691103832175165e-16
cost at iteration 461 :  1.3930499545295854e-16
cost at iteration 462 :  1.3657810076149127e-16
cost at iteration 463 :  1.3898119422820164e-16
cost at iteration 464 :  1.3625048583497612e-16
cost at iteration 465 :  1.3866267136293565e-16
cost at iteration 466 :  1.3592806948080087e-16
cost at iteration 467 :  1.3834930447898601e-16
cost at iteration 468 :  1.3561073115434817e-16
cost at iteration 469 :  1.3804097466106014e-16
cost at iteration 470 :  1.3529835370992833e-16
cost at iteration 471 :  1.3773756634076635e-16
cost at iteration 472 :  1.349908232875301e-16
cost at iteration 473 :  1.3743896718516934e-16
cost at iteration 474 :  1.3468802920395347e-16
cost at iteration 475 :  1.3714506798963718e-16
cost at iteration 476 :  1.3438986384816206e-16
cost at iteration 477 :  1.3685576257482293e-16
cost at iteration 478 :  1.340962225806319e-16
cost at iteration 479 :  1.3657094768758964e-16
cost at iteration 480 :  1.3380700363653734e-16
cost at iteration 481 :  1.3629052290570662e-16
cost at iteration 482 :  1.335221080326269e-16
cost at iteration 483 :  1.3601439054614782e-16
cost at iteration 484 :  1.3324143947758831e-16
cost at iteration 485 :  1.357424555768486e-16
cost at iteration 486 :  1.329649042857834e-16
cost at iteration 487 :  1.3547462553175412e-16
cost at iteration 488 :  1.3269241129419542e-16
cost at iteration 489 :  1.3521081042904474e-16
cost at iteration 490 :  1.3242387178245578e-16
cost at iteration 491 :  1.349509226923719e-16
cost at iteration 492 :  1.321591993958086e-16
cost at iteration 493 :  1.3469487707500356e-16
cost at iteration 494 :  1.318983100709203e-16
cost at iteration 495 :  1.3444259058675092e-16
cost at iteration 496 :  1.3164112196436877e-16
cost at iteration 497 :  1.3419398242353657e-16
cost at iteration 498 :  1.3138755538373685e-16
cost at iteration 499 :  1.33948973899536e-16
cost at iteration 500 :  1.3113753272119213e-16
cost at iteration 501 :  1.3370748838175338e-16
cost at iteration 502 :  1.3089097838942666e-16
cost at iteration 503 :  1.3346945122694313e-16
cost at iteration 504 :  1.306478187599296e-16
cost at iteration 505 :  1.3323478972077395e-16
cost at iteration 506 :  1.3040798210338768e-16
cost at iteration 507 :  1.330034330191658e-16
cost at iteration 508 :  1.3017139853223004e-16
cost at iteration 509 :  1.3277531209168492e-16
cost at iteration 510 :  1.2993799994518185e-16
cost at iteration 511 :  1.3255035966692186e-16
cost at iteration 512 :  1.2970771997374511e-16
cost at iteration 513 :  1.3232851017978625e-16
cost at iteration 514 :  1.2948049393054262e-16
cost at iteration 515 :  1.3210969972062944e-16
cost at iteration 516 :  1.2925625875944803e-16
cost at iteration 517 :  1.3189386598612122e-16
cost at iteration 518 :  1.290349529874296e-16
cost at iteration 519 :  1.3168094823182291e-16
cost at iteration 520 :  1.2881651667803647e-16
cost at iteration 521 :  1.3147088722637322e-16
cost at iteration 522 :  1.286008913864787e-16
cost at iteration 523 :  1.3126362520724488e-16
cost at iteration 524 :  1.2838802011620766e-16
cost at iteration 525 :  1.310591058379922e-16
cost at iteration 526 :  1.2817784727698272e-16
cost at iteration 527 :  1.3085727416693645e-16
cost at iteration 528 :  1.2797031864432607e-16
cost at iteration 529 :  1.3065807658725124e-16
cost at iteration 530 :  1.2776538132033747e-16
cost at iteration 531 :  1.3046146079836233e-16
cost at iteration 532 :  1.275629836957966e-16
cost at iteration 533 :  1.3026737576864075e-16
cost at iteration 534 :  1.2736307541354184e-16
cost at iteration 535 :  1.3007577169932687e-16
cost at iteration 536 :  1.2716560733303227e-16
cost at iteration 537 :  1.2988659998963976e-16
cost at iteration 538 :  1.2697053149606043e-16
cost at iteration 539 :  1.296998132030165e-16
cost at iteration 540 :  1.2677780109360725e-16
cost at iteration 541 :  1.2951536503448535e-16
cost at iteration 542 :  1.2658737043375712e-16
cost at iteration 543 :  1.2933321027905036e-16
cost at iteration 544 :  1.263991949106369e-16
cost at iteration 545 :  1.2915330480114482e-16
cost at iteration 546 :  1.2621323097436112e-16
cost at iteration 547 :  1.289756055050115e-16
cost at iteration 548 :  1.2602943610194526e-16
cost at iteration 549 :  1.2880007030608464e-16
cost at iteration 550 :  1.2584776876912253e-16
cost at iteration 551 :  1.2862665810325036e-16
cost at iteration 552 :  1.2566818842306723e-16
cost at iteration 553 :  1.2845532875197454e-16
cost at iteration 554 :  1.2549065545598273e-16
cost at iteration 555 :  1.2828604303832207e-16
cost at iteration 556 :  1.253151311794774e-16
cost at iteration 557 :  1.281187626537424e-16
cost at iteration 558 :  1.2514157779980502e-16
cost at iteration 559 :  1.2795345017066977e-16
cost at iteration 560 :  1.2496995839381993e-16
cost at iteration 561 :  1.2779006901888796e-16
cost at iteration 562 :  1.2480023688568032e-16
cost at iteration 563 :  1.276285834626022e-16
cost at iteration 564 :  1.246323780243079e-16
cost at iteration 565 :  1.2746895857823128e-16
cost at iteration 566 :  1.2446634736149463e-16
cost at iteration 567 :  1.2731116023288032e-16
cost at iteration 568 :  1.2430211123069375e-16
cost at iteration 569 :  1.2715515506348184e-16
cost at iteration 570 :  1.24139636726456e-16
cost at iteration 571 :  1.270009104565412e-16
cost at iteration 572 :  1.2397889168448994e-16
cost at iteration 573 :  1.2684839452852892e-16
cost at iteration 574 :  1.2381984466231338e-16
cost at iteration 575 :  1.2669757610683443e-16
cost at iteration 576 :  1.2366246492048602e-16
cost at iteration 577 :  1.2654842471131812e-16
cost at iteration 578 :  1.2350672240440974e-16
cost at iteration 579 :  1.264009105363968e-16
cost at iteration 580 :  1.2335258772666456e-16
cost at iteration 581 :  1.2625500443365685e-16
cost at iteration 582 :  1.2320003214986123e-16
cost at iteration 583 :  1.2611067789500826e-16
cost at iteration 584 :  1.2304902757001123e-16
cost at iteration 585 :  1.2596790303631015e-16
cost at iteration 586 :  1.228995465003705e-16
cost at iteration 587 :  1.258266525814797e-16
cost at iteration 588 :  1.2275156205576463e-16
cost at iteration 589 :  1.2568689984709218e-16
cost at iteration 590 :  1.2260504793737093e-16
cost at iteration 591 :  1.2554861872738436e-16
cost at iteration 592 :  1.2245997841792659e-16
cost at iteration 593 :  1.254117836797367e-16
cost at iteration 594 :  1.223163283273915e-16
cost at iteration 595 :  1.25276369710546e-16
cost at iteration 596 :  1.2217407303898194e-16
cost at iteration 597 :  1.2514235236152074e-16
cost at iteration 598 :  1.2203318845564876e-16
cost at iteration 599 :  1.2500970769635225e-16
