netgen drawsolution.py
On my notebook I have created the profile once by the command
ipython profile create –parallel –profile=mpi
Since I have only two physical cores, I edited the file .ipython/profile_mpi/ipcluster_config.py to allow for oversubscription:
c.MPILauncher.mpi_args = [‘–oversubscribe’]
I start the cluster via
ipcluster start –engines=MPI -n 4 –profile=mpi
In jupyter, we can then connect to the cluster via a Client object of ipyparallel.
c = Client(profile='mpi')
c.ids
[0, 1, 2, 3]
from mpi4py import MPI
comm = MPI.COMM_WORLD
print (comm.rank, comm.size)
[stdout:0] 0 4
[stdout:2] 2 4
[stdout:1] 1 4
[stdout:3] 3 4
if comm.rank == 0:
print (mesh.GetNE(VOL))
[stdout:2] 79
[stdout:0] 0
[stdout:1] 73
[stdout:3] 78
inv = CGSolver(a.mat, pre.mat, printing=comm.rank==0, maxsteps=200, tol=1e-8)
gfu.vec.data = inv*f.vec
[stdout:1] WARNING: maxsteps is deprecated, use maxiter instead!
[stdout:3] WARNING: maxsteps is deprecated, use maxiter instead!
[stdout:2] WARNING: maxsteps is deprecated, use maxiter instead!
[stdout:0] WARNING: printing is deprecated, use printrates instead!
CG iteration 1, residual = 0.053126041648229295
CG iteration 2, residual = 0.07344287617289662
CG iteration 3, residual = 0.06110786204339784
CG iteration 4, residual = 0.049294272666440334
CG iteration 5, residual = 0.04641237052420435
CG iteration 6, residual = 0.030446095751156133
CG iteration 7, residual = 0.025763981457526706
CG iteration 8, residual = 0.016975392921489908
CG iteration 9, residual = 0.012989664894467545
CG iteration 10, residual = 0.011308228515895673
CG iteration 11, residual = 0.007800282946410086
CG iteration 12, residual = 0.003524698587117304
CG iteration 13, residual = 0.0017401033251838
CG iteration 14, residual = 0.0011366587144063154
CG iteration 15, residual = 0.0008035602552022152
CG iteration 16, residual = 0.0005243481976976639
CG iteration 17, residual = 0.0003741983982428153
CG iteration 18, residual = 0.00027497275542884286
CG iteration 19, residual = 0.0001722947196498317
CG iteration 20, residual = 0.00012857735127167933
CG iteration 21, residual = 8.997393301231656e-05
CG iteration 22, residual = 6.195695703999047e-05
CG iteration 23, residual = 4.865877020420862e-05
CG iteration 24, residual = 3.387607816378531e-05
CG iteration 25, residual = 2.2199678719710126e-05
CG iteration 26, residual = 1.5023055764553777e-05
CG iteration 27, residual = 1.0581004609879279e-05
CG iteration 28, residual = 7.3557518572924645e-06
CG iteration 29, residual = 5.352395923297321e-06
CG iteration 30, residual = 3.6339266638961192e-06
CG iteration 31, residual = 2.0444337740669425e-06
CG iteration 32, residual = 1.5751267049433527e-06
CG iteration 33, residual = 1.3159605053740326e-06
CG iteration 34, residual = 8.346360401330136e-07
CG iteration 35, residual = 4.6043838009577006e-07
CG iteration 36, residual = 2.945004617259998e-07
CG iteration 37, residual = 1.9185646830449405e-07
CG iteration 38, residual = 1.3661842726572128e-07
CG iteration 39, residual = 9.497862727053461e-08
CG iteration 40, residual = 6.613160428773548e-08
CG iteration 41, residual = 4.228230865738215e-08
CG iteration 42, residual = 2.7713291458349878e-08
CG iteration 43, residual = 1.8141562264858647e-08
CG iteration 44, residual = 1.27279033041476e-08
CG iteration 45, residual = 8.504452240284736e-09
CG iteration 46, residual = 5.564358237230814e-09
CG iteration 47, residual = 3.6807848439137528e-09
CG iteration 48, residual = 2.3751444014589703e-09
CG iteration 49, residual = 1.6993731516376926e-09
CG iteration 50, residual = 1.0657829474396408e-09
CG iteration 51, residual = 7.154229520918308e-10
CG iteration 52, residual = 5.014272479607597e-10
gfu = c[:]["gfu"]
Draw (gfu[0])
Draw (gfu[3])
fesL2 = L2(mesh, order=0)
gfL2 = GridFunction(fesL2)
gfL2 = c[:]["gfL2"]
Draw (gfL2[0])
