netgen drawsolution.py
On my notebook I have created the profile once by the command
ipython profile create –parallel –profile=mpi
Since I have only two physical cores, I edited the file .ipython/profile_mpi/ipcluster_config.py to allow for oversubscription:
c.MPILauncher.mpi_args = [‘–oversubscribe’]
I start the cluster via
ipcluster start –engines=MPI -n 4 –profile=mpi
In jupyter, we can then connect to the cluster via a Client object of ipyparallel.
c = Client(profile='mpi')
c.ids
[0, 1, 2, 3]
from mpi4py import MPI
comm = MPI.COMM_WORLD
print (comm.rank, comm.size)
[stdout:2] 2 4
[stdout:0] 0 4
[stdout:3] 3 4
[stdout:1] 1 4
if comm.rank == 0:
print (mesh.GetNE(VOL))
[stdout:2] 81
[stdout:0] 0
[stdout:3] 75
[stdout:1] 76
inv = CGSolver(a.mat, pre.mat, printing=comm.rank==0, maxsteps=200, tol=1e-8)
gfu.vec.data = inv*f.vec
[stdout:2] WARNING: maxsteps is deprecated, use maxiter instead!
[stdout:0] WARNING: printing is deprecated, use printrates instead!
CG iteration 1, residual = 0.0531207003733573
CG iteration 2, residual = 0.07374408660622353
CG iteration 3, residual = 0.06613575382258267
CG iteration 4, residual = 0.050564282985203636
CG iteration 5, residual = 0.048118728884873806
CG iteration 6, residual = 0.03171133576546557
CG iteration 7, residual = 0.026339954640005568
CG iteration 8, residual = 0.018867600495310295
CG iteration 9, residual = 0.013856359824532939
CG iteration 10, residual = 0.011508956583247314
CG iteration 11, residual = 0.008869710488825623
CG iteration 12, residual = 0.004854287485627618
CG iteration 13, residual = 0.0022162679463868917
CG iteration 14, residual = 0.0015615896552425461
CG iteration 15, residual = 0.0011065170423390227
CG iteration 16, residual = 0.0007171571458209736
CG iteration 17, residual = 0.0005251131240243119
CG iteration 18, residual = 0.0003498383890375572
CG iteration 19, residual = 0.00022463539798289107
CG iteration 20, residual = 0.0001592318115618978
CG iteration 21, residual = 0.00012412243193313203
CG iteration 22, residual = 8.768140471147995e-05
CG iteration 23, residual = 5.820850555540186e-05
CG iteration 24, residual = 4.0545678293521785e-05
CG iteration 25, residual = 3.0221249909169026e-05
CG iteration 26, residual = 2.2281511256913374e-05
CG iteration 27, residual = 1.5466555984921558e-05
CG iteration 28, residual = 1.0276039906232418e-05
CG iteration 29, residual = 6.856538971345465e-06
CG iteration 30, residual = 4.775824481043983e-06
CG iteration 31, residual = 3.1094353975493625e-06
CG iteration 32, residual = 2.308970147700432e-06
CG iteration 33, residual = 1.6644528884649138e-06
CG iteration 34, residual = 1.1420780176195693e-06
CG iteration 35, residual = 7.667709514061562e-07
CG iteration 36, residual = 4.845080009208966e-07
CG iteration 37, residual = 3.548946011540788e-07
CG iteration 38, residual = 2.426963050278122e-07
CG iteration 39, residual = 1.602381789666029e-07
CG iteration 40, residual = 1.029137408537242e-07
CG iteration 41, residual = 6.809889912101365e-08
CG iteration 42, residual = 4.656201912591468e-08
CG iteration 43, residual = 3.42805995298198e-08
CG iteration 44, residual = 2.3419466928295755e-08
CG iteration 45, residual = 1.4564354581502226e-08
CG iteration 46, residual = 8.73321716660204e-09
CG iteration 47, residual = 5.684444002805568e-09
CG iteration 48, residual = 4.136624311756414e-09
CG iteration 49, residual = 2.9795076726749184e-09
CG iteration 50, residual = 2.012474167744149e-09
CG iteration 51, residual = 1.2237905564761717e-09
CG iteration 52, residual = 7.854711295756782e-10
CG iteration 53, residual = 6.170296480272248e-10
CG iteration 54, residual = 4.909037899677378e-10
[stdout:3] WARNING: maxsteps is deprecated, use maxiter instead!
[stdout:1] WARNING: maxsteps is deprecated, use maxiter instead!
gfu = c[:]["gfu"]
Draw (gfu[0])
Draw (gfu[3])
fesL2 = L2(mesh, order=0)
gfL2 = GridFunction(fesL2)
gfL2 = c[:]["gfL2"]
Draw (gfL2[0])
