This page was generated from unit-5.4-fetidp_edge/feti-dp-iii.ipynb.
5.6.3 FETI-DP in NGSolve III: Using Non-Point Constraints¶
num_procs = '40'
stop_cluster()
start_cluster(num_procs)
connect_cluster()
nref = 0
dim=3
ngmesh.Load('cube.vol')
for l in range(nref):
    ngmesh.Refine()
comm = MPI_Init()
f += SymbolicLFI(x*y*v)
pardofs = fes.ParallelDofs()
if comm.rank==0:
[stdout:31]
avg DOFs per core:  2260.7
A new dual-primal space¶
pythonic = True
if pythonic:
    faces = []
    edges = []
    for f1 in faces:
        for f2 in faces:
            if f1 is not f2:
                if len(edge) > 1:
                    if not edge in edges:
    vertices = set()
    for e1 in edges:
        for e2 in edges:
            if e1 is not e2:
                vertices = vertices.union(vs)
    vertices = sorted(vertices)
vec = f.vec.CreateVector()
vec.local_vec[:] = 0.0
for v in vertices:
    vec.local_vec[v] = 1
vec.Cumulate()
- we do not want any subdomain vertices do be included in the edges
- (for consistency) we want neither subdomain vertices nor subdomain edge-DOFs in the faces
if comm.rank==0:
[stdout:31]
# primal dofs global:  122
Setting up the Edge-Constraint Matrix¶
ParallelDofs for w¶
if comm.rank==0:
[stdout:31]
# edge constraints global:  227
min, avg, max:  9   17.025   29
Getting the Dual-Primal Inverse¶
DPSpace_Inverse needs:
- the original matrix matrix
- a freedofs-BitArray
- a BitArray for the point-constraints
- the constraint matrix, and paralleldofs for \(w\)
- the inversetype to use for local problems
- the inversetype to use for the global coarse grid problem
                           c_points=primal_dofs, \
                           invtype_glob='masterinverse')
num_procs = '100'
stop_cluster()
connect_cluster()
def load_mesh(nref=0):
        ngmesh.Refine()
    return Mesh(ngmesh)
    comm = MPI_Init()
    if comm.rank==0:
    return [fes, a, f]
def setup_FETIDP(fes, a):
    if comm.rank==0:
    if comm.rank==0:
    F = B @ A_dp_inv @ B.T
    A = a.mat.local_mat
def prep(B, Ainv, f):
    rhs.data = (B @ Ainv) * f.vec
    return rhs
    t = comm.WTime()
    return comm.WTime() - t
def post(B, Ainv, gfu, lam):
    hv = B.CreateRowVector()
    hv.data = f.vec - B.T * lam
    gfu.vec.data = Ainv * hv
    jump = lam.CreateVector()
    jump.data = B * gfu.vec
    norm_jump = Norm(jump)
    if comm.rank==0:
comm = MPI_Init()
mesh = load_mesh(nref=1)
rhs = B.CreateColVector()
lam = B.CreateColVector()
prep(B, A_dp_inv, f)
if comm.rank==0:
    print('')
t = solve(F,  Fhat,  rhs, lam)
if comm.rank==0:
    print('\ntime solve: ', t)
post(B, A_dp_inv, gfu, lam)
[stdout:16]
avg DOFs per core:  6607.56
# of global primal dofs:  399
it =  0  err =  0.12130848690672913
it =  1  err =  0.02390767825931742
it =  2  err =  0.00825023321167997
it =  3  err =  0.002729895619289229
it =  4  err =  0.0008641121927087105
it =  5  err =  0.0003048442822355854
it =  6  err =  9.712889856412031e-05
it =  7  err =  3.3730326402392145e-05
it =  8  err =  1.0925387588517252e-05
it =  9  err =  3.32252185091653e-06
it =  10  err =  1.067131618337071e-06
it =  11  err =  3.318060576723047e-07
time solve:  0.5276237779762596
dofs per core and second:  10933.491326199415
norm jump u:  2.0337283556173004e-06
%%px --target 1
SparseCholesky<d,d,d>::MultAdd :   1.095705270767212
SparseCholesky<d,d,d>::MultAdd fac1 :   0.6547586917877197
if t_chol['time'] == maxt:
[stdout:2]
timers from rank  13 :
SparseCholesky<d,d,d>::MultAdd :   1.214454174041748
SparseCholesky<d,d,d>::MultAdd fac1 :   0.7252676486968994
SparseCholesky<d,d,d>::MultAdd fac2 :   0.47362494468688965
SparseCholesky - total :   0.42598485946655273
stop_cluster()
